#1161
either do I, except cause more damage.
#1163
Grasping at Straws meaning: To be grasping at straws means to be willing to do, say, or believe anything that offers even the slightest hope in a desperate situation, even though there is almost no chance Running race fuel through it ain't helping Clay |
#1164
"QUICK-SILVER",
The guy that Jeff and Paul picked to check the motor out is a great guy and really knows his stuff. Paul was concerned that the fuel I had in the tank was bad. We ran it on race fuel today and the knocking noise was still present. Though this is frustrating, I do appreciate Paul and Jeff finding the guy to come here and check the motor out. At this point, the diagnosis of this motor is between Paul, Jeff and the guy they selected to look at this motor. Now that we have moved past fuel being the source of the knock, I'm hoping we can get closer to finding the real problem. I know the motor is still shaking around a little bit. That will get addressed as well. https://www.youtube.com/watch?v=mnHpmYka2mg https://www.youtube.com/watch?v=SEqz1ipiz1Q |
#1165
At this point all there is left to do is run it on a test stand to fully rule out any in-chassis variables. But I think we all know the tapping is internal to the engine and will require some form of exploratory surgery.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#1166
What's the difference between that and an engine run stand? |
#1167
, Its possible that the result of the selected engine tech not finding anything external to the engine to explain the knock will result in the tech pulling the engine followed by a free ride of the engine back to the Koerner Racing to be made right...![]() One can only hope
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
#1168
grivera,
I wish I had access to a stand. If we get to that point I'm hoping their guy can locate one to run this motor. MarkS57, The tech has a few more things to check. I guess we'll find out what will happens next but I do know that I prefer to keep this motor in Virginia! |
#1169
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
#1170
Steve C.,
Damn...I could have bought one of those test stands! I spent more money diagnosing this motor than the cost of one of those! |
#1171
[QUOTE
MarkS57, I do know that I prefer to keep this motor in Virginia![/QUOTE] I don't blame you one bit. In the end, I kind of suspect that might be the option they come back with though- hopefully they will take into account the time that has elapsed and the effort you and many others have put into this thing; not to mention the money, and solve this ASAP: for you.
#1172
Sooo...I'm really curious what a test stand....stands to prove???
#1173
Well for me ... zero chance of any kind of transmission, frame/exhaust clearance, accessories, engine mounts etc. etc. causing any kind of noise.
You have an almost immediate solution to the problem if it makes no noise on the stand. If it still makes the noise on the stand ... well then it's probably going to need to be pulled apart .... so it's nice to have it already out of the vehicle. |
#1174
MarkS57,
I'm hoping for that as well. I would love to get some drive time before another season is lost. STEELCITYFIREBIRD, I've had some pretty experienced guys looking at this motor. I'm confident they've looked at everything chassis related that could be causing the knocking. Honestly, I think thats a waste of time but I understand why they may want to do that. |
#1175
At least the shaking seems to have subsided quite a bit. Whats the idle rpms in the latest videos?
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
#1176
Sorry i haven't been following the whole time, does the knock increase with engine rpm or remain the same?
#1177
scott70,
It was a little higher than I would like but it was right around 1,000 rpm. |
#1178
slowbird,
I believe it does. The higher the rpm's the more it's drowned out by the motor but the knocking has always been the same. |
#1179
Joe, I’m not sure how far you are from CVM but have them tear it down for you, they know Pontiacs. If close enough, have them come listen to it or run it on a stand once it’s out.
http://centralvirginiamachine.com/ Best wishes and keep you head up.
The More People I Meet, The More I Love My Dogs! |
#1180
Is Jim "Mr P-body" LeHart still at CVM or did he retire? I got a set of custom pistons from him years ago for a 400 build. At the time he was very knowledgeable and passionate about Pontiac engines.
At this point, I'd let the local guy and the original builder work on diagnoses, but I'd review any changes they recommend. For example if it's piston slap, you could have the current pistons coated on the skirts instead of buying new pistons. If a wrist pin or single piston is damaged, you could replace just one piston and re-balance. Just depends on what they find.
I could explain all this to the girl at the parts store, but she'd probably call the asylum. White '67 LeMans 407/TH350/Ford 3.89... RIP Red '67 LeMans. 407/TH400/Ford 3.25 Last edited by chiphead; 08-20-2019 at 10:16 AM. |
| Closed Thread |
