#101
I am looking forward to Pontiacs going a couple seconds quicker with the Tiger heads. Any one else want to compare a very well designed race head with a street head?
Have A Great Day |
#102
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by bmpmdf:
Bob, that is great news. Now for anyone who thinks the china cranks will live, this proves otherwise. At least you caught it and didn't mess anything up. </div></BLOCKQUOTE> Recently pulled a Chinese crank from my engine, and guess what? No runs, drips, or errors (and no cracks). The block looked great too. Only casualty from making upwards of 800-HP on spray (135-MPH @ 3850 lbs. race weight, you do the math)...if you want to call it a "casualty", was the front cap is cracked around the dowel pin hole (a common problem). I think the big difference between what happened to Bob's crank, and what didn't happen to mine is Bob's pistons were heavier (his 4.35" bore to my 4.181"), his rods were heavier (his steel to my aluminum), and his rpm's were higher (his 7200 to my 6500). Would the crank have lived had Bob ran aluminum rods? Hard to say. Eagle advertises their cranks for Ford and Chevy as being good up to 700-HP, but I know of 2 Ford racers in my area that are making upwards of 900-HP and they're living. Keep in mind though, that when making this kind of HP with a cast crank, you'll always be on the edge.
#103
The crankshaft is no doubt the weak link, but there are things that you can do prolong it's life. Heavy pistons and steel rods certainly do not help the situation. Would you rather hit that chinese crank with a steel or aluminum hammer? That is what happens every cycle. Our 467" (400 based) has more than 20 passes, running 150mph at little under 2900lbs naturally aspirated. Also shifted at 7500rpm. No problems so far. We use a light MGP aluminum rod with a very light JE piston. I don't expect the crank to be perfect when we freshen the motor up, so the customer is already planning to spend the big bucks on a IA2 block and billet crank, as well as the Tiger heads when they come out to the public. Just my 2 cents..
Wilson Manifolds Inc. 954-771-6216 www.wilsonmanifolds.com Induction Specialties Inc 305-303-8473 1992 Firebird (2350lbs) 467" stock block, E heads, Eagle crankshaft, single carb. 8.15 at 165.35mph, 5.22 @ 132.20 (1.140 60ft)---naturally aspirated on gasoline. 5.19 @ 133.45 (1.136 60ft)- best 1/8 mile in Cecil County |
#104
Can I chime in here? Scott looked at the Tiger. If you want something to compare it to, there's nothing in Pontiac-world. You must step up to BBC, and then only "Big Chief" can compare. That's the current race big block head, found on ProStock Pontiacs. Kinda cool, if you ask me! I've done some Big Chief work. AWESOME heads.
As for the Eagle crank, well, over 800 HP? Not bad for a $280 casting. Eagle does NOT list the Pontiac in the "competition" section of their catelog (where the aforementioned Ford and Chevy cranks are), just the "street/strip" section. It was never intended to take that kind of power. When we took Greg's Eagle stroker down, there was no wear on the bearings, no wear on the crank (including the thrust main) and there was still "crush" in the bearings. This after over 100 passes on 1/8 and 1/4 mile tracks, and a few thousand street miles. His car ('70 Firebird) went 11.22@122 with 3.50 gears on 93 octane. It dynoed at 479 RWHP (around 600 flywheel). The Eagle is just fine when used as intended. Actually, more than fine. FWIW |
#105
Bob, does the head come "dry" (ie. dry deck) like the blocks?
Erik
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 6.0L LS single turbo, 8.85 @155 mph 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.03@171 mph 2009 G8 GT |
#106
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Erik W:
Bob, does the head come "dry" (ie. dry deck) like the blocks? Erik </div></BLOCKQUOTE> Eric, the head will be cast with sand holes that are there to hold the water jacket in place. We will drill the holes out to a pipe plug tap size in production. It will be up to the customer to tap the holes to dry deck them. We are looking at adding a water input point between the two exhaust valves to cool the area. Bill Ceralli wants to try a few things on the dyno next time to bring the power up even higher. We will not do it by porting the head. Our second batch of heads are at the heat treat at this time. They will be machined and cut up to test the process. They all look so good, it is a crime to cut them up, but that’s what we have to do. We are Tig welding the AllPontiac/Butler IA IIA aluminum block deck to make them a dry deck block. This process is shorter than the drill, tap and plug process. The cylinder sleeves should be here on Friday and we will ship it to the Butlers in the middle of the week. I will post pictures of that project then. David said two to three weeks to the dyno from there.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads Boss Bird Funny Car Best pass to date 08/06/2016 [email protected] Allpontiac Big Chief Aluminum Engine Block http://www.AllPontiac.com |
#107
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Trans Am Bob:
[QUOTE]Originally posted by Erik W: Bob, does the head come "dry" (ie. dry deck) like the blocks? Erik </div></BLOCKQUOTE> Eric, the head will be cast with sand holes that are there to hold the water jacket in place. We will drill the holes out to a pipe plug tap size in production. It will be up to the customer to tap the holes to dry deck them. We are looking at adding a water input point between the two exhaust valves to cool the area. And we will have the heads in production in time for the engine master contest. They have to be in production by a certain date to be able to be used for the competition. And we will make that date. Bill Ceralli wants to try a few things on the dyno next time to bring the power up even higher. We will not do it by porting the head. Our second batch of heads are at the heat treat at this time. They will be machined and cut up to test the process. They all look so good, it is a crime to cut them up, but that’s what we have to do. We are Tig welding the AllPontiac/Butler IA IIA aluminum block deck to make them a dry deck block. This process is shorter than the drill, tap and plug process. The cylinder sleeves should be here on Friday and we will ship it to the Butlers in the middle of the week. I will post pictures of that project then. David said two to three weeks to the dyno from there.
#108
Any more news? Where do I send my deposit$$$?
Systems under stress fail catastrophically |
#109
Bob, hope u make the deadline on the engine masters challenge. A friend is involved in the judging process. Wesley Roberson. As a matter of fact he printed up the deadline form for products to be accepted. He is somewhat familiar with new Tiger head. I have been informing him on the progress. U can send me a set and I will run them by his shop so he can see it is available for sale to the public!
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car |
#110
I love it! A port cast to flow well! Who knew? Why do all that porting work when you can just cast it in? The future is looking awesome for the pontiac world. What's the smallest bore size for this head?
