Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Closed Thread
Old 11-25-2006, 06:23 PM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Hope you are right on that one.Its ashame everyone involved with these blocks is having to do all this extra work.Better to be safe than sorry.GOOD LUCK with the hardness test.Plus you should sonic check the cylinders to see what the minimum wall thickness is.That might well tell you if this batch of blocks was OK.If your wall thickness is good than hopefully the hardness checks out as well.
  #102
Old 11-25-2006, 06:45 PM
Tom Vaught's Avatar
Boost Engineer
Jim, can you look closer at Post number 98 pic number 3 at the bolt hole and bulkhead area?
Tom V.
  #103
Old 11-25-2006, 07:04 PM
7T2 7T2 is offline
tom,
5 o'clock on the perimeter, an inch or so down of z travel?
jim
  #104
Old 11-25-2006, 09:19 PM
Tom Vaught's Avatar
Boost Engineer
Yep about there. Start of a crack?
Tom V.
  #105
Old 11-25-2006, 09:33 PM
Mo's Avatar
Mo Mo is offline
Is this what you see? Optical illusion?
ID:	73090   Click image for larger version
Name:	mr1 crack.jpg
Systems under stress fail catastrophically
  #106
Old 11-25-2006, 09:36 PM
Tom Vaught's Avatar
Boost Engineer
I hope it is an optical illusion!
Tom V.
  #107
Old 11-25-2006, 09:53 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Just a simple observation,so dont make anything of this,but most all the threads in OMT's block look a whole lot better than most any of those from the "fubar" block pics posted thus far.
His block's threads all look nice and clean,no obvious or visible signs of problems that I see,that would make me feel a little better,but I'd still get the block magged,sonic checked,and the material tested for piece of mind.
  #108
Old 11-25-2006, 10:23 PM
Half-Inch Stud's Avatar
My first impressions are:
The Main Cap Outer Bolt holes need countersunk.
The webs appear fine. Optical illusion that was sited is creepy.
Overall appearance is fine.
  #109
Old 11-25-2006, 10:30 PM
7T2 7T2 is offline
good point screamingchief,
the first telltale sign would be thread deformation since thats where induced ksi stress loads would exhibit from continuous load due to bolt stretch. my opinion, thats where the system failure starts.
jim
  #110
Old 11-25-2006, 10:59 PM
Old Man Taylor's Avatar
Tom - I see what you are talking about in the picture, but I didn't see it when looking at it. Regardless, I will still be taking the block apart and checking it more closely. It will also get the hardness tests.
  #111
Old 11-25-2006, 11:01 PM
Tom Vaught's Avatar
Boost Engineer
His block looks far better than any of the other blocks to date but all we have seen in the past is failures.
Tom V.
  #112
Old 11-25-2006, 11:31 PM
ponchospidel's Avatar
ponchospidel ponchospidel is offline
hope everything checks out ok for you, glad to se no carnage.
  #113
Old 12-10-2006, 09:20 PM
chiefbigb chiefbigb is offline
Default Its been a while
What were the results?Brian
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
  #114
Old 12-11-2006, 01:26 AM
Nothing too unusual when the short block was disassembled, but it has not yet been tested. I am trying to find soneone who can test the Brinell Hardness without having to break a chunk off of the block.
  #115
Old 12-11-2006, 11:26 AM
BILTIT's Avatar
BILTIT BILTIT is offline
There are hand held hardness testers so don't ruin the block if not needed. How accurate are they? Good question.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
  #116
Old 12-11-2006, 07:11 PM
KenB KenB is offline
Default don't need a chunk of block
Equotip type portable hardness testers are industry proven.
That said, correct indenter must be used, and a standard block of similar expected hardness is always a good idea. As I've read this thread, the resolution of these units is more than sufficient to differentiate between 'butter' and 35 KSI, and can be conversion to Rockwell, Brinell, etc. is well understood.
Regards
Ken B
71 Firebird Esprit
94 TA - 396 LT1 powered - Bought new in 1993. Total money pit
Cars gone by - 76 Formula, 73 Esprit, 75 Esprit. 87 Buick WE4
  #117
Old 12-12-2006, 10:16 PM
Pontirag Pontirag is offline
Not to interject some more worthless leagal mumbo jumbo but.... If fraud was committed against them,KRE, then they still must make it right for the end user/ customer because they failed to ensure that the product they sold met the standard as represented in thier advertising. They failed to ensure on a case by case basis that each block was able to perform as advertised. Look at the Firestone tire/ Ford SUV delemma a few years back. Ford and Firestone bothe blamed each other and both were technically at fault. But the end user/ consumer had the condition corrected (recall) at no expense and those who experienced loss in one way or another were compensated for that loss as well. Hence the term "case in point".
Watch out though. Bankruptcy is an emergency exit stage left.
  #118
Old 12-16-2006, 12:53 PM
Brian Baker's Avatar
In light of two customers from Texas being made whole to their satisfaction, what's the latest on the two blocks Brad Spidel purchased? How about the racer from Ohio that wrecked his car (Tom Woods?)? Scott Roberts?
  #119
Old 12-16-2006, 07:19 PM
my dad is supposed to be recieving 2 new blocks before christmas.this is to replace the 2(inferior blocks) we originally purchased from KRE. as far as my dad's crankshaft being bent, and all of our troubles(time,money,wasted racing fuel,and trips to the track, rings, bearings, gaskets, rtv, engine oil)((all that crap adds up, especialy when you are retired!)) we went thru trying to seal my engine, and make the power my dad's should have, this past season, i hope some some type of an agreable resolution can be made between me and KRE. i believe my dad is just happy to be getting 2 new blocks, not gonna fly with me!! we shall se what happens!
  #120
Old 12-16-2006, 08:01 PM
fastgto fastgto is offline
Ponchospidel, hope things work out for you.
Closed Thread
Smilies are Off
