Old 09-11-2007, 09:13 PM
matt carr matt carr is offline
RAIV-Z pm sent
  #102
Old 09-11-2007, 09:14 PM
drew1967 drew1967 is offline
ED,
IN YOUR MIDDLE PICTURE. the area im having trouble with is the front where it slants forward toward the drip rail. i cant find where the 1/4 ends and the roof begins with the drip rail.
  #103
Old 09-11-2007, 09:22 PM
67'7F6'Bird's Avatar
67'7F6'Bird 67'7F6'Bird is online now
Hello Drew:
In order to keep my post on track please start your own post and include pictures.
Steve
  #104
Old 10-07-2007, 12:17 AM
Let the welding begin!!!!!
My brother and I took a welding course last Friday and have been helping a friend over the past few weeks assemble/weld a 1967 F-body together. Now were back on track with more experience to get mine completed.
Here we are welding the rear inner valance panel, zinc primer was sprayed on the rear frame and butterfly pieces on the back shown in the second picture. We are plug welding all the panels together. I picked up a Roper Whitney Punch to help speed things along.
ID:	107061   Click image for larger version
ID:	107062   Click image for larger version
ID:	107063   Click image for larger version
ID:	107064   Click image for larger version
  #105
Old 10-07-2007, 12:16 PM
Here are the Trunk Drop Offs being welded on. We did place the wheel wells on once again for fitting, it never hurts to double check alignment. Most of the welds needed no grinding. I will scruff the welds today and get some paint on them, normally it is preferred to do this sooner, it just got too late to do it last night.
ID:	107082   Click image for larger version
ID:	107083   Click image for larger version
ID:	107084   Click image for larger version
ID:	107085   Click image for larger version
  #106
Old 10-07-2007, 11:37 PM
Final assembly completed for Trunk Drop-offs and Rear Inner Valance Panel.
ID:	107174   Click image for larger version
ID:	107175   Click image for larger version
ID:	107176   Click image for larger version
ID:	107177   Click image for larger version
  #107
Old 10-08-2007, 01:25 PM
Here is the drivers side NOS Wheel Well being fitted, clamped and welded on. The plug welds are getting better as we fine tune the welder for amps and wire speed. The amps were on the highest setting "D" and wire speed around 6/7 to get these welds.
The next MIG Welder we get will have the infinitely adjustable amperage.
ID:	107214   Click image for larger version
ID:	107215   Click image for larger version
ID:	107216   Click image for larger version
  #108
Old 10-08-2007, 01:29 PM
More pictures of the drivers side wheel well - welding completed.
ID:	107218   Click image for larger version
ID:	107219   Click image for larger version
ID:	107220   Click image for larger version
  #109
Old 10-08-2007, 09:20 PM
I wanted to let you all know the prep work done before the outer wheel wells got welded on.
1) Both Rocker Panels were vaccuum'ed out - My brother came up with the hose attachement and it worked out well.
2) All areas surrounding the wheel well in the rocker area were rust encapsulated and then sprayed with chssis black. I did paint about 6 inches inside the rocker too - we did pick up a long extension for our spray gun and will at a later date spray just about all the inside of the rocker panels with similar coatings.
3) The back of the wheel well lip got sprayed with weld through primer - we like the galvanized spray better but we ran out today.
ID:	107237   Click image for larger version
ID:	107238   Click image for larger version
ID:	107239   Click image for larger version
ID:	107240   Click image for larger version
  #110
Old 10-08-2007, 09:27 PM
Here are final assembly pictures of the passenger side wheel well.
All panels have been repainted wherever the paint was burned off by the plug welds; wire brushed or 3m Wheel used to clean the welds then picklex to clean the metal and rust encapsulator used for primer/sealer for the first 2 coats to match the rest of the body panels.
ID:	107250   Click image for larger version
ID:	107251   Click image for larger version
ID:	107252   Click image for larger version
  #111
Old 10-11-2007, 12:50 AM
fastwayfirebird400's Avatar
fastwayfirebird400 fastwayfirebird400 is offline
I just want to say you guys have done one he!! of a good job on that car ! Please share more on your spray wand and vacume you used in the rockers (how you made it) I need to do mine very soon and need to coat the inside of the rockers.. Thanks for sharing...
  #112
Old 10-15-2007, 06:27 PM
fastwayfirebird400: Thanks for the compliments!!!! There Motivating!!!
Here is the "3M Spray Gun" we'll be using to coat the inside of the rocker panels. As for the Vacuum to clean them out we used the step down attachment and just slipped into it about 8 feet of garden hose.
ID:	108092   Click image for larger version
  #113
Old 10-18-2007, 08:35 PM
I finally got a chance to cut the roof off. I used a sawzall, air saw and right angel grinder to get it done. I used a torch to remove the lead on the front pillars.
There was plenty of surface rust and some very thin metal on the back window lip. The only time consuming part was grinding the roof off in the drip rail area - took about an hour to cut it off. I am glad the roof came off after seeing all the areas were there was rust, it will make me happy knowing its going to be all new metal up there. There was a wrinkle in the original roof and that helped in deciding to just start cutting.
I will be changing the roof braces too.
ID:	108393   Click image for larger version
ID:	108394   Click image for larger version
ID:	108395   Click image for larger version
ID:	108396   Click image for larger version
  #114
Old 10-18-2007, 08:41 PM
Here are the areas you can't too unless the roof is off. You can see the surface rust, but normally the bad spots are around the drip rail area and front/rear windows.
ID:	108398   Click image for larger version
ID:	108399   Click image for larger version
  #115
Old 10-18-2007, 08:47 PM
I was able to remove the rust with the wire wheel then a quick one over witht the 3M sanding wheel. More sanding the paint hopefully over the weekend.
ID:	108401   Click image for larger version
ID:	108402   Click image for larger version
ID:	108403   Click image for larger version
ID:	108404   Click image for larger version
  #116
Old 10-22-2007, 07:16 PM
Here is the sanded area on the roof bracing and front pillar that I spayed with "weld through primer." I used my new Roper Whitney Hand Punch" for the plug weld Holes.
Before I welded each piece on I had the upper winshield brace secured tightly to make sure everything was aligned properly.
ID:	108812   Click image for larger version
ID:	108813   Click image for larger version
ID:	108814   Click image for larger version
ID:	108815   Click image for larger version
  #117
Old 10-22-2007, 07:23 PM
More Pictures!
ID:	108817   Click image for larger version
ID:	108818   Click image for larger version
  #118
Old 10-22-2007, 07:26 PM
Here is the Windshield Roof brace lined up - To be welded tomorrow.
ID:	108820   Click image for larger version
ID:	108821   Click image for larger version
  #119
Old 10-24-2007, 05:39 PM
The windshield/roof support brace is welded on, plenty of plug welds on these pieces so far. I dressed the welds, then wiped clean with picklex and painted with Rust encapsulator.
I removed the middle roof support brace and prepped each side and painted with weld through primer - the last 2 photos.
ID:	109005   Click image for larger version
ID:	109006   Click image for larger version
ID:	109007   Click image for larger version
ID:	109008   Click image for larger version
  #120
Old 10-31-2007, 08:09 PM
I got the midlle roof brace welded in today. I ran out of weld through primer and tried SEM's NEW "copper-weld" through primer, after trying this stuff I will say its the best stuff I've used to date minimal popping and nice clean welds. I punched holes in the rear roof brace and lined it up. So far its been an easy task.
ID:	109847   Click image for larger version
ID:	109848   Click image for larger version
ID:	109849   Click image for larger version
ID:	109850   Click image for larger version
