Old 11-13-2008, 05:57 PM
elevatorman51's Avatar
elevatorman51 elevatorman51 is offline
I replaced my PP sfi last week with the Power bond sfi "Jegs house brand" and I will say that although the balancer seems intact it slide easily off the crank. It measures crudly 4 thousanths bigger (inside calipers not a bore gage) and the PB unit took slight effort to slide it on.
69 GTO
67 Firebird 400
Old 11-16-2008, 02:05 PM
mr68's Avatar
mr68 mr68 is offline
WOW, talk about interesting timing. The last time I had the GTO out I noticed a vibration in the rear view mirrior that I did not have before. I did drive the car abot 45 miles and parked it. After checking things out and could not find anything I read this thread. In doing so I went down stairs and sure enough there is about half inch of play in the harmonic balancer ring......looks like I found my vibration. So whose balancer do I run on my 505 combo.
Just living the dream......
Old 11-24-2008, 04:14 PM
jimdavis jimdavis is offline
Default Issues with Professional Products Dampers
Hi. I am the chief operating officer and co-owner for Professional Products. For those of you who don't know me, let me give you a brief rundown of my background in this industry. Many years ago I started out as a drag racer and at one time held both ends of the NHRA national record in my class. I started two successful magazines back in the '60's; Super Stock Magazine and Stock Car Racing Magazine. I was president of B&M Racing & Performance Products for 18 years. President of Russell Performance Products for 2 years. In 1997, with two U.S. partners, we started Professional Products.
Now to the damper issue. We had a problem in the past with the bonding process that attaches the elastomer to the hub and ring. This problem existed well over a year ago and has since been resolved by going to a different process along with some other changes. I suspect that the damper failures that have occurred have all been on these older dampers. Even though a damper may have been purchased fairly recently, it could have come from older stock that was in our customer's warehouse. Since we changed the bonding process the number of spun dampers (bonding failure) has dropped to near zero. Our current warranty rate on failed dampers is less than 1% of what we sell. The industry average for an acceptable warranty rate is about 3%.
Obviously, we would like to see it at 0% and that is always the goal that we work towards. Realistically, no matter how well a product is made, you will never reach a 0% failure rate. Even a highly regarded damper like ATI has some failures.
I would like to address some other comments made in this forum. One member wrote that because our instructions suggested you line up your old damper TDC mark with the timing pointer, we were admitting that our timing marks were not accurate. This is not the case. Our timing marks are extremely accurate. This suggestion was made because both Ford and Chevy have used different timing marks on the damper (Ford) or different locations for the timing pointer (Ford and Chevy). By lining up the TDC mark on your old damper before removing it, it just makes it easier to install the new one. We have three sets of timing marks on our Ford damper and by doing what we suggest, it automatically tells you which set of marks are correct for your engine. On the Chevys, ALL aftermarket dampers use the '69 and later timing pointer location. So if your engine is pre '69, you have to use a different timing pointer. The forum member who made this post somehow interpreted our mention of using a different pointer as meaning our marks were in the wrong position. Every aftermarket damper manufacturer uses the later TDC mark.
Another member commented that Pro-Race and Pro-Street dampers are U.S. made. This is incorrect. This is an Australian company with a U.S. warehouse. Their Pro-Race line is made in Australia and the Pro-Street line is made in China.
Admittedly we have had some problems with our dampers. We feel confident that these issues have been resolved. We do stand 100% behind our products. While we have a one year warranty on all our dampers (many of our competitors do not warranty race dampers) we typically have replaced every failed damper even if it is out of warranty.
If any of you would like to communicate directly with me, my email address is: [email protected].
Old 11-24-2008, 06:16 PM
Me Notyou's Avatar
Me Notyou Me Notyou is offline
If you were having trouble with the old dampers, why not recall the older stock that could cause a catastrophic motor failure? I'm not trying to pitch a bitch here but if some of my customers work might have been compromised by fault of me or my employees
( Welding shop, heavy equipment ) I make sure the problem doesn't arise even though I'm not liable for "collateral damage".
Denn die toten reiten schnell
More doors = more love!
Old 11-24-2008, 04:34 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
http://forums.maxperformanceinc.com/...d.php?t=577458
Some more reading for ya Jim.
John Krull
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 11-24-2008, 06:56 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
I have one PP balancer, it sits in a pile of used auto parts... It's the only part that hasn’t been used.LOL…. After inspecting the piece and seeing the lack of craftsmanship plus seeing many units go bad and hurting possibly some motors I’ve come to the conclusion to never ever use one of your products. It was a complete waste of money, no doubt…… I don’t see how you’re going to fix the bad reputation this damper has.
KR
Old 11-24-2008, 07:11 PM
grandville455's Avatar
grandville455 grandville455 is offline
WEll I bought mine last yr and if its old stock I want my money refunded!.Thats Bs! I could have ruined my engine!. I got mine from cnc motor sports and of course he said he would work with me and replace it especially after i told them pp would atleast exchange it! well Guess what they wouldnt email me back after i told them that and of course now it is just past a yr gone!.. I just bought a pioneer sfi one for $169.. give the difference from yours to this one and i will be happy Jim!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 11-24-2008, 07:29 PM
baron_ baron_ is offline
Send a message via AIM to baron_
...and here's mine
Was about to use it on a twin turbo 461 forged crank/rod/piston stroker 400
I bought it about 1.5 years ago....great....
Clay Marsh
1967 GTO convertible Twin Turbo 5spd project
http://forums.performanceyears.com/f...d.php?t=618281
http://www.youtube.com/watch?v=eJ9KworCMRE
Old 11-24-2008, 08:01 PM
Default SFI is a SAFETY Item!
http://www.pro-race.com/about.htm My error on US made. Regardless it is a quality piece.
Before purchasing a balancer I did a search on various boards for comments and complaints. Pro-Race did not come up with complaints. Pro Products did have complaints and disappointment come up with their products (alarmingly so).
That some are out there still with a possible defect and not recalled from the warehouses and distributors and owners speaks VOLUMES. Does someone have to get KILLED first???
Quote Jim Davis "This problem existed well over a year ago and has since been resolved by going to a different process along with some other changes. I suspect that the damper failures that have occurred have all been on these older dampers."
You have only resolved PART of the problem Jim Davis!
How many potential bombs are still out there Jim?
Wheres the recall notices?
Someone gets hurt or killed and you (by the above statement) will have your hands full in court. Most lawyers would have a field day with that admission. I know a recall isnt cheap but you really should do just that. It might help business in the long run or at least limit your liability exposure. Personally I'd have a hard time sleeping knowing I had a product out there that potentially wasnt safe. Especially when its SUPPOSED TO BE A SAFETY ITEM!!!
BTW Many enthusiasts exceed warranty periods before they even use a product due to project delays. If they use it and it fails they just typically replace with another brand and throw the old one away in disgust, figuring it will be a hassle getting it warranteed and more importantly do they want to risk another failure.
Old 11-25-2008, 01:37 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
This is not good. I have one in that time frame in use and 2 two more to be put into service. Why not exchange them out? This is not good for business. Mine or yours. I'd rather buy new ones out of my pocket than have to explain failure to people that pay me money to build their motors. A lot of us already went through this with the cam/lifter failures.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 11-25-2008, 06:55 AM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Mine is from that same time period. It will get junked when I build my new shortblock, and I will not get another. I cannot afford to lose a motor, or worse.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 11-25-2008, 08:59 AM
PONTIAC DUDE's Avatar
Thumbs up
Still running the PP balancer on my personal driver after having that replaced the BHJ that spun after 5 years. It is right on the money TDC wise.
Also have one on my wifes car. No issues.
I have sold quite a few of them over the past 5 years and so far no one has called or complained about one.
Jim Glad you took the time to come on the board and post.
69GTO, KRE had block & customer service issues and people still buy from them.
Bruce same deal on replacement or taking care of the bad blocks and warranty.
Grandville 455. Do the rules only apply to certain companies?
I see the deal & posts in the BB section with Streaka and "would buy if you still wanna make those Billet covers".
Explain the rules that your using to judge companies or manufactures, because i don't see any standards that people are going by?????????????
Race Hard & Have fun. If it ain't broke it's hard to fix or find out if it's an issue?
Old 11-25-2008, 10:13 AM
79TA455STROKED's Avatar
79TA455STROKED 79TA455STROKED is offline
WOW,
I just got my new combo together and have one of these sfi balancers.
A problem im having is my timing seems to be retarding about 4 deg when i give it some throttle.
Its a msd dist,6al box with the dist locked.
I set it at 38 deg and it retards to about 33-34 deg when i hit it.
The balancer was rite on the money tdc when i degreed my cam but i wonder if it has since started to move causing timing retard problem im having?
Guess is should check it out as a possibility.
I bought it in 5/06 but didnt get motor fired untill 4/07 and the balancer has been great up untill now.
I guess i fall under the old stock category.
Will you guys replace this thing with a new stock one even if it is still good before it goes bad and takes out my motor???
Who do i contact?
9.81 at 139.89mph
3400lbs
Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS!
370cfm butler eheads
port matched victor
1095 king demon
4.30gear,th400
MICKEY THOMPSON DRAG RADIAL tire
Old 11-25-2008, 10:50 AM
Post
Originally Posted by 79TA455STROKED View Post
WOW,
Who do i contact?
The balancer won't retard under rpm but a dist or ignition box can.
Old 11-25-2008, 10:16 AM
JKrull66's Avatar
Race Hard & Have fun. If it ain't broke it's hard to fix or find out if it's an issue?[/quote]
The one off my 535 came with the shortblock from your shop... but it is over 2 years old now. I figured it is a paper weight. No use crying over spilt milk. The ring came off and took out the timing cover at PSN this year, mabee 20 runs total on it. Even if it was replaced I would not trust it. If it will help you in some way it is yours.
Just glad to see others being warned to check thier units, and that it was not likley something else is wrong.
Just my 2 cents.
John Krull
66 GTO HT Cruiser
POLARIS 900 RZR
Old 11-25-2008, 10:59 AM
Question
The one off my 535 came with the shortblock from your shop... but it is over 2 years old now. I figured it is a paper weight. No use crying over spilt milk. The ring came off and took out the timing cover at PSN this year, maybe 20 runs total on it. Even if it was replaced I would not trust it. If it will help you in some way it is yours.
Just glad to see others being warned to check their units, and that it was not likely something else is wrong.
Just my 2 cents.
John Krull[/QUOTE]
Can't log info if customers don't ever let me know. Duely noted, John.
BTW: I have over 85 passes so far on my PP SFI balancer. LOL.
grandville455:
Not to say an issue wasn't out there, but apparently they have taken care of it. He came on here and didn't try and BULLSH*T anyone. Just stated facts and if you or anyone has a problem feel free to contact them. Raisng hell on a public forum about a product a person has an issue with and never contacting the manufacture does what?
When I see people slam a manufacture, but still deal with other companies that have had issues they weren't resolved. I don't understand the ground taken? Where is the line?????
No hate intended.
Building the quantity of engines of different makes and all the issues I have seen or had to work with in the last 5/8 years is amazing. But if i quite using everyones products i had issues with to an extent, I would have to close up my shop. I have taken care of soooooo many issues that were manufacture issues and ate it. Most of use builders have.
Old 11-25-2008, 10:47 AM
I agree!.. Don't really care who has had good luck and who hasn't these are a problem and will continue to be a problem as far as I am concerned!! I wont buy another one ever! what if it came off when i was timing my car and hit me or someone else i loved and fuc**** killed them and PP new there was a problem and didnt recall them is that ok too!! JMO
Darby
Old 11-25-2008, 11:26 AM
They changed the bonding process to address a failure they found, thats great going forward. However with that said it does not properly address the product thats out there that has suspect bonding. SFI balancer is a safety item that should survive far beyond the rpm limits of a Pontiac. If someone broke a crank and drove over the mess they "could" get killed. If someone was winging the throttle testing something underhood and it fails it "could" send a piece of shrapnel(whether from the balancer itself or a piece it takes out)flying again possibly resulting in injury or death.
Interesting that very early assemblies are out there doing fine then some start failing. The manufacturer "should" be able to identify the suspect batch and SHOULD make things right. Warranty or no warranty. It is a safety issue. It shouldnt be a business ethics/moral question.
From my own 30+ year experience in customer service related field I know losing one customer from a satisfaction issue can and usually results in the loss of 10 or more new customers and possibly loss of existing customers that have no issues but "heard things" and are reluctant to chose you for their next purchase.
Lose your reputation and you will eventually lose your business. You can protect your reputation by doing the right thing or you can abuse the legal system to silence those that have just cause to say things that hurt your reputation. Truth and consideration prevails in the long run.
Old 11-25-2008, 11:38 AM
quicksilver97ta's Avatar
Question
How can you tell if you have one with the new bonding process vs. the old bonding process?
Old 11-26-2008, 09:41 AM
70 Lemans's Avatar
70 Lemans 70 Lemans is offline
Email from Jim,
On the back face of the damper is a date stamp. I can't' remember exactly how it is presented but if it is all numbers, then it is the older version before we changed the bonding procedure and you will need to send it back and I will send you a new one. If the date code is numbers and letters (or maybe just one letter) then it is the later version with the improved bonding.
Regards - Jim Davis
69 400 Block, .030 over, KRE eagle stroker kt, KRE,CNC ported e-heads 310 cfm, port match RPM , comp roller 236/[email protected] 586/600 lift 110 LS. 1.5 HS roller rockers, 350 Transmission, Red Neck tight 3500 stall converter, Ford 9” with 3.75’s, Strange center section, Moser 31spline axels, 29”Mt slicks, HRPARTSNSTUff anti roll system, Doug’s Headers 3.5” collectors, 22”Dynomax mufflers w/ H-pipe, Cliffs Q-jet, Fuel cell with sumps, Mallory 140 fuel pump and filter. Denny’s 3.5” drive shaft.
