1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
I will do just that. I suspect you are correct. I cleaned up the grounding wire attachment point on the floor near the gas tank, but who knows if the floor itself is good ground.
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE |
This should help you visualize fuel circuit.
From the 67 shop manual, but the layout is the same. |
Thanks. I get it. I'm just having trouble getting decent, consistent readings. I do seem to be getting consistent OHM readings at the tank of about 34-36 with a nearly full tank. That seems correct for the 1964 sending unit.
I'm getting about 12v into the gauge. Where it gets fuzzy is the line out of the gauge to the tank. I can't get a good contact on it (while laying on my back, reaching up to the back of the gauge) to ground it out in an attempt to get that gauge to read E. But next attempt I think I'll get a wire on that post, then plug the harness back in on top of it, then ground that wire to get the gauge to read E. (The harness on the gauge is a L shaped plug, so both B+ and the output to the sending unit get plugged in as a pair.) I bought a new multimeter and was getting very inconsistent volt readings out, but that's because I couldn't get a good probe connection I think. As you can read above, I was getting about 2.8v out before, but it was dropping to around .8v by the tank. If that is in fact the case, my problem should be along that wire. So if I can run a jumper off the gauge, I will be able to do two things: check gauge by grounding it, and then run that wire directly to the sending unit which should then read accurately. That's my game plan. I plan on executing it tomorrow evening.
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE Last edited by AdamIsAdam; 04-02-2014 at 08:49 AM. Reason: Fat fingers = tpyos ;) |
Don't worry about getting a wire on the back of the gauge just yet, find that Tan wire going to the ribbon cable under the carpet and ground it there. I am assuming there is a ribbon cable on a 64, never worked on one there. If necessary, just disconnect it there and then ground the contact where the Tan wire is. Remember Tan, not Brown. Brown is for Park lights. And, other end of ribbon cable should accessible from inside of trunk, comes up from under back seat, connector there.
Ground it anywhere on that lead going back and the gauge should read empty if it is good. If it doesn't then you have to back up towards the gauge itself, maybe even having to disassemble the dash to get the gauge out. It could be tested when on the bench by duplicating Batt, ground and resistance to ground on the Tan lead connection to prove it's functionality. If it does operate with that ground on that Tan lead, then you must prove continuity to the rear of the vehicle by either ohming it out front to rear or simply temporarily running a new wire from there to the sending unit for a test of operation. You could always go by Radio Shack and pick up a couple of resistors to hook up in place of the sender to ground for testing. Say, 35 ohms for full, 20 for half full, ground for empty. I would think you probably have good body grounding if the rear lights work properly, as evident in your other thread. Charles Last edited by Old Goat 67; 04-02-2014 at 09:27 AM. |
Right, I tried that and got strang results. See my post #112 above.
I got the same 2.8v at the flat wire-to-harness junction behind the rear seat. BUT, when I grounded that wire the gauge was still reading FULL! Which makes NO sense! That's why I am trying to ground at the gauge itself. It's also when I stopped and decided to buy a better multimeter and try again, but got sidetracked by the tail lights. Too many things at one time.
That voltage reading is a good way to troubleshoot, but my question is whether that is open circuit or not?
If circuit is open at sender, you should read 12V then. If connected to sender it indicates that sender is flowing current through it. |
Hmm. Not sure I'm totally following you here. My understanding is that while the gauge receives 12v in, the lead out of the dash to the sending unit is generally lower than 12v. Regardless, I tested with that lead wire unplugged from the sending unit at the tank and with the key ON. Does that answer your question?
Charles, I have never checked or tried, but will he get the full 12v after the gauge with that resistors in it? I can see the volts droping, I don't know by how much. Just trying to learn some stuff along the way also, and you seem very knowledgeable with a lot of this stuff.
UPDATE:
Good news, bad news. The good: I know what the problem is. The bad: it's my fuel gauge. I did the following: plugged the harness into the gauge by turning it 180* (thank you Clay). This allowed me to get power to the gauge, while exposing the terminal for testing. Clay took an unmounted fuel gauge today and took voltage and ohm readings for me. He got about the same volts coming out as was going in. For ohms, there was about 130ohm on one side (terminal to ground), and about 85ohm on the other for a difference of 45 ohm. Then he took a reading across the gauge and got 45ohm. On my gauge, I wasn't able to get any constant, decent volts coming out to the sending unitl. Then I grounded that line and the gauge stayed on FULL. Finally, I moved on to the ohms. I got 130ohm on B+ side to ground, and 0ohm on the other side. When I measured across the gauge, I got 0. So, sounds to me like my gauge is shot. All in favor of that diagnosis, say aye____... So, my only question now is, who's got a `64 fuel gauge they're not using?
You bring up a good point Pepi.
There should be some lesser voltage, because the resistor in the gauge should allow some flow thru the two coils left in the circuit while the sender is disconnected. I would have to go out and disconnect to see how low it might go. I've done that reading before but cannot remember what is read exactly, I was just looking for an open circuit voltage presence at that point back at the sender. I'd go do it now, but I just don't have the time today. Adam, the grounding test at the ribbon connector under the carpet would still be a good test for proving or disproving the gauge and dash wiring to be good. Charles Last edited by Old Goat 67; 04-02-2014 at 10:16 AM. |
When I grounded at the ribbon behind the rear seat, nothing happened. That's what's really odd. And I had a very good ground there.
Then you have to go up further to the next connection and try it. If there is one between where you did it and the gauge, other wise yes, ground out on the back side of the gauge. You said the back side of the gauge was an L shaped plug, can you unplug it and stick a wire in from the back and then plug it back in and ground the wire? I don't know how much room you have up there to work. Otherwise not plug the plug on completely and try to touch the metal tang with a pick or flat screwdriver with a wire attached to it and ground out, probably will need someone else to watch the gauge when you it that way since you'll be on your back trying to work behind the dash.
Adam,
There should be a connector to the ribbon right under the carpet by the kick panel. Try Pepi's test there. Could be an open ribbon cable...... If still no good, that only leaves the Tan wire to the gauge and then the gauge itself. Charles |
Adam, I printed out the wiring diagram you posted and don't see another connector on it, not saying for sure there is not another one, but to me it sounds like a bad wire from gauge to your connector you are checking where it drops to .8v.
You could try probing the wire between the gauge and where you disconnected the flat ribbon at different areas. Just take a pin to pierce the wire insulation and then touch your multi-meter to the pin and ground and check voltage. If you get your 2.8v try grounding it there and see what the gauge does. That troubleshooting will do several things. If you get 2.8v then you know the wire is broken further back closer to the tank, and if the gauge moves, that is the problem a broken wire. If you don't get your 2.8v repeat the same procedure closer to the gauge. Keep doing it until you get the voltage. I don't know how much voltage gets lost through the gauge, but this helps find the voltage lose in the wire due to a bad wire. Just repeat the process going to the tank to narrow down where the break could be. The reason I say use a pin is so you don't put big holes in the wire insulation. You could always put a little rubber cement or something where you probed the wire so you don't have an opening for corrosion to start on the wire. Charles, I was typing as you posted, I thought there should be another connection somewhere, but didn't know for sure. Adam if it works at the kick panel, ohm out the flat ribbon wire and I sure you find a break or very high resistance.
Just to back up a few steps, when I was working behind the seat, I unplugged the ribbon from the rest of the wires. I was able to get the same 2.8v at the ribbon. So that made me feel good since it will be easy to run a wire from there to the sending unit.
HOWEVER, when I grounded that wire, the gauge still read FULL. That's what got Clay and I to think i need to check the gauge itself. Maybe I have two problems, a bad wire and a bad gauge. So I'm trying to work on the gauge for now. I need to get that to read E before I change any wires on the car downstream of the dash. I'm going to try and flip the "L" connector over so that I get power to the gauge, but can access the sending until tab with my meter (Clay's idea). Clay also suggested I take some OHM readings on the gauge alone, no wires plugged in to it. I should be able to do that. I'll report back. Hey, while I'm scraping my hands behind the dash, is that where I grab the bulb to replace it? During all my messing around, i blew the dash bulbs. I have to check all the fuses first to make sure they're getting good connections. So many little problems, so little time. But, I'M SO HAPPY TO BE PLAYING with my new toy!
Pepi,
Drawing is weird there. There are two rectangular connector blocks up there on top left. One has only 4 wires, other one has 7??? Tan lead only goes through one? Could that mean that it represents the ribbon cable itself with connectors on either end? The one with four would be near the tail panel for the light wiring? Charles Link posted again for clarity.
. So your though of it representing the ribbon cable would be something I would put money on.Adam, I forgot you were getting 2.8V at that one point and still couldn't get gauge to read correctly. Turning the connector around on the gauge is a good idea.
Whether that rectangle represents the entire length of the ribbon or not? It makes sense to me since there's no other end of it shown.
Sounds like the gauge to me. Good to hear you might have it figured out. Once you get a gauge and verify let us know for sure.
