Old 03-20-2012, 01:09 PM
Just currious, if theres no issues capping that off, than why is it there? Is it just for reroute of the coolant from the heater core back to the motor?
If thats the case, than Im taking mine off this weekend. I hate unneeded clutter under the hood.
Hey Nick, you have a closer shot of that water pump?
  #102
Old 03-20-2012, 03:43 PM
lust4speed's Avatar
Yep. The block fitting is the high pressure side pushing the coolant through the heater core, and the fitting at the water pump is a low pressure area that allows the coolant to complete the return path. By capping the heater nipples off, all you are doing is making the passenger side of the engine cooling the same as the driver's side.
If you are never going to use the heater, then the most permanent fix is to remove the block nipple (not always easy) and put an expansion plug in the head, and then fill the heater nipple on the water pump with JB weld. Kind of freaks people out when they look down at the bare fitting not being capped off. I tried to use a threaded plug, but each time the old timing cover nipple has cracked and I end up just filling things in anyway.
Mick Batson
  #103
Old 03-20-2012, 07:53 PM
Nicks67GTO Nicks67GTO is offline
I did some interior work today. My old carpet was pretty nasty so I called up PY and had them ship me some new black carpet. I would say the fit is 8/10 Its sloppy by the shifter hump but you really can't see it.
I also took some shots of my GTO's original floors. Its hard to believe this car is 45 years old and has floors this clean. It had a touch of surface rust in a few spots but no rot at all. Quite amazing. Its also a testament to the awesomeness of California original cars!
Original floors...yep, unreal
  #104
Old 03-20-2012, 07:54 PM
New Carpet!
  #105
Old 03-20-2012, 07:56 PM
Seats back in!
  #106
Old 03-20-2012, 11:16 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Fantastic, Nick! Looks great. Very clean install...
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
  #107
Old 04-10-2012, 09:54 AM
edit...
  #108
Old 04-13-2012, 11:55 AM
I just stuck a big old ebay 1.25" WS6 swaybar and some poly bushings and links in to replace the stock 7/8" bar and beat up bushings and end links. I also made a thread about it here...
http://forums.maxperformanceinc.com/...d.php?t=695706
Install was very easy and straight forward. If you want pics/info of that click the link
  #109
Old 05-08-2012, 09:50 PM
Well i haven't updated for a while so here goes....First I got some new tires and decided to go with white letter out after a long debate... here's the thread
http://forums.maxperformanceinc.com/...d.php?t=696151
Here's a couple shots with the new tires out. BFG TA radials. 275/60/15 in back on a 15x8 wheel, 225/60/15 in front on a 15x6" wheel...
  #110
Old 05-08-2012, 09:56 PM
My next little project was to install some control arm braces from UMI. When I do the rest of my suspension ill probably go with their products. They seem to be a great product made in the USA and priced very well. I talked to Ramey from UMI on the phone today with a question on the install and he was very helpful. Customer support is very important to me, it earns business IMO.
I have heard these help with wheel hop and judging by the 40' burnout i did today i would say that they definately helped out. It was a strong 40'er and no wheel hop at all....
  #111
Old 05-08-2012, 10:57 PM
fyrffytr1's Avatar
Dang! that is a beautiful car. The wheels really set the car off and the lack of a pin stripe does not take away from it at all! I only hope mine looks half as good when it's done.
  #112
Old 05-09-2012, 05:30 AM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Beautiful car.......
Ramey is awesome at UMI. I have the UMI Front UCA & LCA's
I also bought those rear supports you have there......... but I couldnt install 1 side, one of the mufflers is just too close to fit it in.
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
  #113
Old 03-02-2013, 12:44 PM
Some Interior parts showed up on my doorstep the other day....Ill be getting these in around the end of March....
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies
- Build Thread
http://forums.maxperformanceinc.com/...615847&page=23
  #114
Old 03-02-2013, 12:48 PM
Some of the goodies inside.....New Legendary Rallye seat setup, rear seat, Door panels, headliner kit, sun visors, all kinds of trim stuff and more! Hopefully this car is a bit more fun to drive this year with an interior that isn't 45 years old and falling apart!
- Build Thread
  #115
Old 03-02-2013, 12:53 PM
Looking forward to seeing it installed.
Old 03-02-2013, 07:01 PM
ERIC AULL ERIC AULL is offline
VERY nice lookin car...and that upholstery kit is outstanding!!!!! Eric
  #117
Old 03-03-2013, 01:51 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Very nice Nick!! Where did you order your interior from? Are the door panels the assembled ones, or do you have to use your existing top piece's?
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #118
Old 03-03-2013, 04:40 AM
goatman65's Avatar
Beautiful car. Are the control arm braces adjustable? Just curious as to why.
I have Edelbrock braces on my 65.
  #119
Old 03-03-2013, 12:19 PM
I bought it all through Legendary Auto Interiors. They were having a big 20% off sale so I got a bunch of stuff.
I'm reusing my original stainless trims for now since they're in decent shape but the carpet came attached. On the back of the door panel they have guides for where to punch holes so it makes it almost fool proof as long as you know where things are supposed to go.
- Build Thread
  #120
Old 03-03-2013, 12:21 PM
UMI said the consensus is that not all of the frames are spot on identical. they might be really close but they're not identical and there is room for tolerance from the factory so this makes it easier to install.
- Build Thread
