Old 04-04-2011, 11:38 AM
Hotrodizz Hotrodizz is offline
Ive never seen or heard that. Trim rings for 73, but I wasnt aware they were a different color around the perimeter. I'll check my unmolested spare tire/wheel when I get home.
Old 04-04-2011, 08:38 PM
blue71ta's Avatar
blue71ta blue71ta is offline
your car is looking great; keep the pics coming!
Think it will be ready for the Indian Uprising show? Would love to see it in person.
Old 04-05-2011, 06:12 PM
Father&Son73T/A Father&Son73T/A is offline
Thumbs up
x2!
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
Old 05-19-2011, 01:44 PM
Got the bumper back and installed. I ended up using Badger Plating in the Milwaukee area. Turned it around in 3 weeks at a fair price. Looks flawless.
The Trim Parts carpet isnt fitting well, especially the rear piece. I ordered another rear only, and the fit is exactly the same. I cant live with it, so I ordered an ACC carpet. The dash pad I had dyed is showing an old repair, so the hunt begins for another. ALso still waiting on the engine builder.
While I am not finding much time to dedicate to the car right now, I feel like I cant progress much anyway. It makes no sense to put the seats in, before the dash, no sense to put doors on it while there is still interior work to do. I dont want to assemble the front sheetmetal until the car is running, etc, etc.
I plan on bleeding the brakes and putting the wheels on it, modifying aftermarket rear sway bar bushings and installing them. At that point, the suspension, brakes and steering are done. Sorry, done rambling..
Old 06-03-2011, 09:30 AM
Current state of affairs....Dash is in and complete, Column is in place awaiting the repainted collar bracket, then console, glove box, front seats then steering wheel. at that point, I believe the interior is done.
Ill probably install the glass and doors next since I do not have the engine back yet, and cannot progress on the front end sheet metal.
The 3rd pic shows 3 connectors which I believe are for options my car doesnt have. Does this sound correct?
ID:	246015   Click image for larger version
ID:	246016   Click image for larger version
Old 04-06-2011, 12:08 PM
I live in St Charles, so Ill be there.
Old 04-05-2011, 07:19 PM
Norwood's Avatar
Norwood Norwood is offline
So is it gray?
Old 04-05-2011, 07:36 PM
Held for Ransom's Avatar
Shadowing is making it look gray (grey), but it's silver, with overspray on inner rim.
Old 04-06-2011, 01:07 AM
I'll have to see if I can find the info on them.
My wheels were gray.
(but is a later build in 73)
Old 04-06-2011, 07:56 AM
x-bird2 x-bird2 is offline
my wheels were ....turbos ..... lol
Old 04-17-2011, 10:44 AM
My original spare is silver, same as the other 4.
Old 04-17-2011, 11:21 AM
Between being busy at work, and family stuff, I have to squeeze time in on the TA when I can, so I'm only able to give it an hour here and there, but here is a little more progress:
Most of rear end components are installed and cleaned
I bought the "expensive" carpet underlay kit, and I just couldnt stand it, so I bought some bulk jute padding with silver backing, and cut it to the contours of the floor. Ive used the more expensive Dynamat type of insulation on other cars, but I didnt want to adhere anything to the perfect floors of this car. I also laid the new carpet that had been boxed for 9 months, so it can start taking the right shape. I then installed the rear lower plastics, and upper rear seat.
The original headliner was falling off the board, so my local interior shop removed all the foam, installed new, then re-glued the original material back on. He couldnt promise it will last, but for $50, I figured it was worth a shot and so far, so good.
The firewall heater box, harnesses and vacuum lines are also in place.
The engine side AC case is installed, as is the wiper motor, transmissions, and brake booster. I removed the plastic that the body shop had wrapped the front subframe in, but I havent blown all the dust off of it yet.
I hope to get a few more hours on it today
Old 05-10-2011, 09:22 AM
Been very busy with work lately, so I havent been able to dedicate much time to the car and especially updates, but here we go.
Old 05-10-2011, 09:54 AM
Norwood's Avatar
Very Nice Tom, it coming along GREAT.
Old 05-10-2011, 11:08 AM
CaptCrunch CaptCrunch is offline
Nice work!
Old 05-10-2011, 08:28 PM
Great progress. Going to be nice!
Old 05-10-2011, 10:15 PM
cnc's Avatar
cnc cnc is offline
where can u buy BULK jute padding ??
Car looks Fabulous keep it comin
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 05-10-2011, 10:23 PM
Very, very nice.
Old 05-11-2011, 07:12 PM
1973T/A's Avatar
1973T/A 1973T/A is offline
Ive bought mine at fbodywarehouse before
Old 05-11-2011, 09:55 PM
I didnt buy it here, but this is what I used: http://www.summitracing.com/parts/THE-14120/
