Old 05-11-2011, 04:58 PM
george kujanski's Avatar
I have a 11 bolt that I originally needed to "adjust" the clearance, otherwise mine would puke coolant after shut down. No more, tho.
George
  #102
Old 05-11-2011, 05:04 PM
Sirrotica's Avatar
Originally Posted by rad400 View Post
I talk to Jim butler and he says there is no problem with water pump if over heating it is timing or running lean. cooling system is just coolant and air.
I believe there is a 50+ page post that has pretty convincing data to contradict Mr. Butlers theory, plus I have my own data that says adjusting the timing and carb mixtures won't stop the problem I was having with my own 428 in my own stockcar. If that was true why would Detroit have engineers whose job it is just to optimize cooling systems, sorry I don't subscribe to his theory.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #103
Old 05-11-2011, 07:41 PM
George
I've got one that does the same thing after extended idle. '71 400 with 11 bolt water pump.
Old 05-13-2011, 04:04 PM
arbys's Avatar
arbys arbys is offline
A big thank you to Dan67, GT182 and Old Goat 67 for helping me get my 66 back on the road. These three went way out of their way to help a fellow PY'er. The divider plates came from Dan on Wed. morning and the SS plate came from Gary at noon today. I put it together with the SS recontoured plate and I've got plenty of flow. Works great. I'll wait til Cadone gets the correct impellers and the return the SS to Gary and use the original plate. Thanks again.
  #105
Old 05-13-2011, 10:02 PM
GT182's Avatar
GT182 GT182 is offline
Great to hear she's running. And glad to be able help out too....
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #106
Old 06-19-2011, 07:17 AM
arbys's Avatar
Any word from Cordone yet on the corrected impellers?
  #107
Old 06-19-2011, 09:15 AM
GT182's Avatar
Charles and I will be calling Cardone and Ames Monday morning. Other than that no word yet.
Gary
  #108
Old 06-19-2011, 09:30 AM
67Dan 67Dan is offline
Default Call them!
Call them! 215-912-3521
  #109
Old 06-22-2011, 10:08 AM
troy_barker's Avatar
troy_barker troy_barker is offline
I am waiting on putting my motor together to get one of these, sure hope its soon, ready to get the old GTO fired up.
Bring back my 67 GTO: Shes ALIVE as of 2-19-13
previously owned
78 Firebird
67 Nova
64 Nova
  #110
Old 06-23-2011, 10:09 AM
GT182's Avatar
Charles and I talked to Cardone and Ames Eng. yesterday. BTW... to make thing a bit clearer, this is not the Ames that is selling us parts in the catalog. Things are still at a stand still until Ames and Cardone talk directly to each other. We/ve identified the problem... copies of the original rear divider plate is needed in stainless steel.
I know this is frustrating as all hell, and it is for us too. We've done just about all we can, short of having the correct 8 bolt rear divider plate made ourselves. Anyone got the money to help get that going? I sure don't.
As for the correct pump, call Cardone and ask for it. Tell them it's the pump without the shaved vanes. My understanding is that they have some of these in stock that were never shaved down. But, they are mixed in with the incorrect ones. Try this number that Dan gave above.... 215-912-3000 and ask for Tech Support, or ask to speak to Product Management in Pump Division. I have no 800 number for them.
Gary
  #111
Old 06-23-2011, 10:39 AM
Corporate wheels turn slowly...I suggest anyone who is not driving their caryet this season waitng for Cardone.....stop waiting.
Put it together as best as you can or the season will end with your car in the garage.
I'm just cynical.
George
  #112
Old 06-23-2011, 11:09 AM
GT182's Avatar
I'm just cynical.
George
No, i'd say you're telling nothing but the truth.
And as a notice to all here. An email has been sent to Cardone and Ames Engeering as a formal invitation for them to get together on this.... from Charles.
Gary
  #113
Old Goat 67's Avatar
Well, I just sent an email to both of the contacts in both companies pleading with them to get together to rectify the situation for us.
We should start a new thread with a poll attached, so we can have numbers to give them.
We'll see what we'll see!
Charles
  #114
Old 06-23-2011, 12:08 PM
Decided to try a poll folks;
See:
http://forums.maxperformanceinc.com/...d.php?t=669386
  #115
Old 06-25-2011, 08:42 AM
gene simmons gene simmons is offline
Is this the correct Cardone remanufactured water pump?
http://www.summitracing.com/parts/AAZ-58-299/?rtype=10 This looks to be the 68 pump.
Will i be able to get these pumps through the local Arnold motor supply,Napa and O'reillys, when available?
It doesn't look as though cardone has 69-up yet.
Summit still has the stamped steel impellers
http://www.summitracing.com/parts/AAZ-58-303/?rtype=10
  #116
Old 06-25-2011, 12:40 PM
The 58-299 is the correct pump for the 8 bolt setup from Cardone, BUT and I say BUT, most you will find have the shorter vanes which will not work good with the original plates!
IF you are LUCKY enough to get one with the vanes about 3/4" high and a curve to them, you'll probably be OK.
Having said that, I would NOT buy one mail order. I had O'Reilly's get four of them shipped to my local store and one had the correct impeller. I went with my plates in hand, so Guess which one I came home with?
End of overheating!
I do not know the part # for the 11 bolt one. Maybe someone else does.
Charles
  #117
Old 06-27-2011, 01:59 PM
mike389's Avatar
mike389 mike389 is offline
Default Cardone
i just removed this same pump due to seal leak. checked Cardone site and they make a new pump # 55-11137 !!! O'Reilly auto parts can order it under part# CP850, finished with remans with a one year limited warranty!
the vane height is 3/4" on the old pump
11 hole pumps, they have reman & new i checked year 1969
http://www.cardone.com/English/Club/...bcat/byapp.asp
mike
  #118
Old 06-27-2011, 02:09 PM
mike389's Avatar
Default Cardone
Make Model Year Product Category Product Line
Pontiac Catalina 1969 Pumps Water Pumps
Application Data Part Number
Water Pump - A1 CARDONE [Reman.]
w/3 31/32" Hub Ht.
58-302
w/4 15/32" Hub Ht. and Optional Performance Pump and w/Aluminum Housing
58-303P
w/4 15/32" Hub Ht. and Optional Performance Pump and w/Cast Iron Housing
RR AT THIS TIME
w/4 15/32" Hub Ht. and Standard Pump and w/Aluminum Housing
RR AT THIS TIME
w/4 15/32" Hub Ht. and Standard Pump and w/Cast Iron Housing
58-303
Water Pump - CARDONE Select [New]
w/3 31/32" Hub Ht.
55-11143
55-11145
  #119
Old 06-27-2011, 02:49 PM
Damn good research Mike!
Thanks,
Charles
  #120
Old 06-27-2011, 03:07 PM
grandville455's Avatar
grandville455 grandville455 is offline
What does RR at this time mean?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
