RE: Shutter Wheel pic - is there a balance issue? Seems like a meaningful fraction of the disc is cut away. Thoughts?
RediRad circuit designs, branding and intellectual property are for sale. Serious inquiries only. |
Works like a charm. Blue line is 36-1 trigger wheel, green is the cam signal. ![]()
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
| The Following User Says Thank You to TheSilverBuick For This Useful Post: | ||
The best check is to place a hand on the outer housing when it's running to see if it has any excessive vibrations. If it turns out to be an issue I can relieve material (remove mass) on the opposite side of the slot from the bottom face so as to not interrupt the sensor.
1964 Catalina 2+2 4sp, 421 Tri-power 1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM, Holley EFI, DIS ignition. 1969 GTO 467, Edelbrock 325 CFM, Terminator EFI 1969 Firebird Convertible |
| The Following User Says Thank You to darbikrash For This Useful Post: | ||
Nice setup.
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Very clean solution.
Here is a system we are working on for a customer that will incorporate the Holley 60-2 crank trigger ring and their sensor with our mounting brackets.
The CTB assembly will work with our new 6 rib serpentine drive belt system with a spring loaded tensioner for the alternator, gen II power steering pump w/remote reservoir and the Sanden 508 style compressor. The trigger wheel will be mounted to the balancer behind the crankshaft pulley. We will post pictures as the parts get completed. |
Something like this.
Its ok to giggle and snicker, Dont laugh and point |
Making a little more progress with the 461. EFI is a Holley HP system. While not the cheapest solution, I like the Injector Dynamics LS style injectors. These are the shorty ID725 high impedance injectors mounted on a Torker II EFI intake, ported to match the heads by Dave at SD Performance.
Fuel rails are Edelbrocks. I fabbed up some stainless standoffs to raise the fuel rail slightly higher to accept the 48 MM (O-ring to O-ring) injector height. No changes needed to the intake. I also added a 1.5" Wilson spacer under the throttle body, this buys me some additional plenum volume, and raises the throttle body high enough to let the linkage clear the fuel rails. ![]() ![]()
Decided to pull my finger out and make up a new cam sensor for my coil per plug setup now. I didn't want to hack up the MSD distributor as I can easily convert it back to a normal dist for someone and it's still in great condition.
Anyhow, I took 1 small body points mallory distributor, gut it, threw all of the guts in the bin, machine the steps and raw casting out on a lathe, modified the shaft so that where the advance weight spring anchors off one of the pins, linish that so it's a 1/8" flat now to acts as the pickup for the MSD magnetic sensor. Add an 0.491" BOP gear, make a top plate and we are away! ![]()
Nice!
Nice work Krisr,
Good to see what everyone is doing for a Pontiac cam position sensor. Keep up the Good work. Just received this Mark III cam position sensor from the machinist. Molded after a Ford Cam Position Sensor. Link in post #95.
| The Following User Says Thank You to Ollie For This Useful Post: | ||
Geez that's nice and compact! Going to cut them on a CNC or one off?
One off, I do have AutoCAD drawings.
Check the link in post #95 on page 5.
Ollie,
Did you not get the one I sent you? Went out months ago. Dave
'68 Bird Vert, 455 , 6x-8, 1.5 HS, HEI, PPR TC-02-HF, TH400, 2500 Hughes, 2.56 8.2 (getting swapped for second gen with shorter gears) Fishing guide in the Washington state for Salmon, Steelhead and Sturgeon. Fish-On! |
No I did not receive one from you Dave.
Dog gone it! I sent back your sensor and other pieces. I'm sure it's too late to track now. I'll check out our tomorrow.
![]() Dave
I checked the Post Office today. Was told if a package is not picked up in 16 days it is returned.
A little more progress on the EFI 461. The Holley 60-2 wheel is now mounted on the balancer, and a crank trigger bracket has been fabbed up and installed on the timing cover. The bracket positions the sensor face .020 above the tooth surface, and the maximum run out of the tooth OD on the wheel is <.002/inches. This precision run out and close sensor gap insures a solid signal for the crank timing. The bracket has a radial slot which allows adjustment of the position of the sensor in an arc around the crank C/L to position it correctly relative to TDC. The sensor position is set at 10 teeth after the “gap”, which is 60 degrees BTDC. The ECU takes over from there to establish engine timing.
![]() Special thanks to Mark at Luhn Performance for all the hard work he did designing and fabricating the crank trigger bracket and the serpentine belt system. There are not many serpentine belt options out there for a Pontiac using an electric water pump, P/S and A/C-that includes an adjustable belt tensioner. I still need to finalize the pulley spacing with the Gates laser alignment tool, and then it’s off to the anodizer. The motor is set in the chassis and is almost ready to light off. ![]() Really happy with this system, and thanks again to Mark Luhn who has been great to work with.
Anyone got the part number on that ford sensor?
Also, who has cad drawings? And are they for that ford sensor?
Jon B
