Old 12-16-2012, 05:38 PM
LeighP's Avatar
LeighP LeighP is offline
http://www.youtube.com/watch?v=DQtQCFWWBzs
About half way through this one....
http://www.youtube.com/watch?v=faRA4aND7sY
http://www.youtube.com/watch?v=tds9QtGYsik
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #102
Old 12-16-2012, 06:29 PM
mscicluna007's Avatar
mscicluna007 mscicluna007 is offline
Oh man that cam sounds awesome. Thanks for the Videos Leigh.
Its definately a distinct sound with the 041 Spec RAM AIR IV Cam.
I think this is a match to the SD Heads for sure now.
  #103
Old 12-16-2012, 10:49 PM
Held for Ransom's Avatar
I wish the people with '73s would respond to your questions.
As far as I know, that style of Kelsey Hayes combination valve was not used in '73.
  #104
Old 12-16-2012, 11:09 PM
njsteve's Avatar
njsteve njsteve is offline
Originally Posted by mscicluna007 View Post
So I purchashed some correct 73 parts from Leigh today and hoped I could clear up some of the problems I was faced with.
The Proprtioning Valve that I had Was a Bendix unit. I am still not sure if it was original so I won't Discard it yet but I have an origianl 73 Proprtioning Valve that appears to be correct for my car.
Here is a few Pictures of the unit I received today and the old unit as a comparison.
Similar but I am not sure if it was correct. Feel free to Let me know if anyone has seen bendix units on these cars before.
That original valve is what I have in my '72
  #105
Old 12-16-2012, 11:16 PM
Steve,
Yours was cast with the Bendix name, not with the Delco symbol ( ) ?
  #106
Old 12-16-2012, 11:23 PM
njsteve's Avatar
Ill look in the garage but i dont think it has any name on it. I have some photos in my 72 Formula thread.
  #107
Old 12-16-2012, 11:29 PM
Default Thanks
Thanks Held For Ransom,
The forum is like a diary to me so anything that goes on will jolt my memory in years to come when it all goes together again. I am hoping the people who know the cars inside out can let me know whats original and whats not. I have been comparing parts with the assembly manual also but if anyone knows better than chime in please.
NJSTEVE - is yours like the Bendix unit I have or like Leighs unit that I picked up.
Thanks for your help to guys much appreciated.
Michael
  #108
Old 12-16-2012, 11:51 PM
http://www.forums.maxperformanceinc....d.php?t=629738
http://www.forums.maxperformanceinc....d.php?t=644339
Two good threads.
  #109
Old 12-17-2012, 08:15 AM
njsteve's Avatar
Here is the valve from my late December-built 1972 Trans Am 455HO, 4-speed with power disc brakes and 15" wheels: (sorry, I dont have the reverse side photo)
Here is the valve from my late December-built, 1972 Formula 455HO, 4-speed with power disc brakes and the Trans Am supension option and 15" wheels:
As you can see they used different design valves even though it was the same application and built during the same week on the same assembly line (Norwood). So either one of the two you have would be OK for your application.
Hope this helps.
(And I'd be happy to take over the rest of your resto if you wanna trade) :-)
The Following User Says Thank You to njsteve For This Useful Post:
  #110
Old 12-17-2012, 02:11 PM
LeighP's Avatar
Looks like you have a choice, Michael. Any chance you can spot the original valve in any of the magazine article pics?
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #111
Old 12-17-2012, 02:41 PM
Tunas73TA's Avatar
Tunas73TA Tunas73TA is offline
Not sure this helps but here is the pic of the Prop valve in my 73 that I believe to be original.
After cleanup:
chuck...
1973 455 TA (07A)
  #112
Old 12-17-2012, 03:13 PM
njsteve's Avatar
The brass ones were later replacements, I believe. The brass units are also what they sell in the aftermarket. The original cast iron ones are hard to come by since they tend to corrode more than brass.
  #113
Old 12-17-2012, 05:24 PM
Chuck, I knew you had the brass unit, because I saw it in your thread, thanks.
Stamp/Date code WV 3 155 is June 4th, '73 (or '83, or '93 or '03).
Steve, I didn't know they used the KH (Kelsey Hayes) unit as early as or earlier than '72.
I figured the Bendix combo valve would have only been used with the Bendix master. It seems it may be marked similar to Chucks' unit ? V 233 ? (Aug 20th, if 1972).
  #114
Old 12-17-2012, 08:48 PM
Default BENDIX Combination Valve
Thanks HFR for your help. Those threads are great reads and I will get through them in the next week or so.
I have taken the time to take the BENDIX Combination Valve down to a local Brake Specialist who was well recomended and deals with Hot Rods/American And Vintage Cars.
He had a quick look and said its definately off an American Car so This part may just be original to this car and maybe some other Dec 2nd week 1972 build cars.
The only problem is the BENDIX Stamping sits facing the brakcet towards the Cowl so unless it is out of your car you may not see it.
This Unit does have the V 233 date stamping.
I have re posted the pictures for the purpose of helping trigger somebodies memory.
The brake specialist will rebuild my Master Cylinder, Combination Valve and Brake Booster and is able to plate the booster.
Can anyone give me specifics on the plating method and or colour I would need for the Brake Booster.
Michael
Name:	2012-12-06 11.24.21.jpg
ID:	306515   Click image for larger version
Name:	2012-12-06 11.24.54.jpg
ID:	306516   Click image for larger version
Name:	2012-12-06 11.25.02.jpg
ID:	306517   Click image for larger version
Name:	2012-12-06 11.25.42.jpg
  #115
Old 12-17-2012, 10:52 PM
wwilder9's Avatar
wwilder9 wwilder9 is offline
My Feb 73 car had that same Bendix prop valve, I have it off the car and it also needs rebuilt, I have looked every where for a rebuild kit, The rebuild kit above is not the right one for it, The valve looks just like yours, I'll get you some pictures soon as I charge my camera up.
68 Firebird Coupe 350/Auto/Air
70 RA III Formula/Auto/Air
71 T/A 455HO/Standard/Air
73 T/A 455/Auto/Air
  #116
Old 12-18-2012, 12:35 AM
My local guy said he has a place interstate who fabricates all the parts he just needs to disassemble and than he can order them in.
In the meantime I have emailed InLineTubes to see if they stock rebuild kits or can obtain them for these units.
  #117
Old 12-18-2012, 03:11 AM
falcon4's Avatar
falcon4 falcon4 is offline
For what it's worth, my '76 400 auto (originally) has a bendix proportioning valve as well.
'66 Valiant Regal 225
'72 Lemans Station Wagon T-41, 455
'76 Trans Am 455
'77 Ford F-100 4WD 351
'78 Ford F-100 2WD 302
'79 Firebird Black 301
'79 Z28 350
'79 Trans Am 403 numbers matching
'04 Ford Falcon XR8 5.4 ltr.
and no wife.........Yipppeeeeeee
  #118
Old 12-18-2012, 07:24 AM
Brewster's Avatar
Brewster Brewster is offline
The Bendix valve is correct and there was even a decal off the engine end that hung with two letters on it. I dont remember off hand which letters but will be in my garage later this week and try and post a picture.
  #119
Old 12-18-2012, 10:26 PM
Brian, that picture looks like it has the KH unit.
  #120
Old 12-19-2012, 04:21 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
My 72 455HO Formula has the cast iron valve as well.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
