Old 07-06-2014, 08:39 PM
Red Goat's Avatar
Red Goat Red Goat is offline
Originally Posted by Brewster View Post
Hope you got some extra for Lucy's New Detailing Kit since it will be needed in the future.
Cheers, B
I hear ya. Scott sells it by the quart, so there should be enough left over to do another whole motor!
Steve knows these cars inside and out, but his is the first HO that I've restored. Any comments on correctness are appreciated and easily changed now!
Cheers,
Tim
  #102
Old 07-06-2014, 09:16 PM
Wow... the car looks fantastic!
  #103
Old 07-06-2014, 10:00 PM
Formulabruce's Avatar
Wow, so where know where the new Assy line is located!! Sweet!
" Long may we DRIVE !"
  #104
Old 07-07-2014, 07:21 AM
165th's Avatar
165th 165th is offline
Those are great progress pics Tim. Keep em coming.
  #105
Old 07-07-2014, 07:43 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Car looks fantastic. Steve does top notch work.
I still believe that the master cylinder should be painted black, not grey.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #106
Old 07-07-2014, 08:05 AM
The Boss's Avatar
The Boss The Boss is offline
Just absolutely amazing details!
Agreed, Steve does great work!
And go racin' in the street.
  #107
Old 07-07-2014, 09:21 AM
weranc55's Avatar
weranc55 weranc55 is offline
Car looks great.
  #108
Old 07-07-2014, 04:18 PM
Brewster's Avatar
Brewster Brewster is offline
Thats correct Bob, I have seen original 72 cars with black or whats left of it since they only had one light coat of material on them to begin with.
Wonder why Steve went that route?
  #109
Old 07-07-2014, 05:39 PM
Norwood's Avatar
Norwood Norwood is offline
Like those judges at the Trans Am Nationals have a clue......
  #110
Old 07-07-2014, 07:53 PM
Brewster's Avatar
Ha, what if Dick and Bob show up??? Now that would be something hey Bob I haven't judged in a while however I would if they needed help.
  #111
Old 07-07-2014, 08:04 PM
Norwood's Avatar
Bob should judge.....UNBIASED and kinda knows his way around these cars....
  #112
Old 07-08-2014, 07:50 AM
Thanks Craig......................now about that bird location on your dash bezel.......LOL
The problem at the Nationals is not judging, it's teching the cars for class placement. Those guys don't have a clue and play by the "good ole boys" rules.
Bob Woodard
Brighton, MI
  #113
Old 07-08-2014, 07:53 AM
165th's Avatar
Tech question here (splitting hairs I know): Is the master cylinder all black? In other words, is it painted after the machined surfaces are cut in, and after the stamped letters stamped in? So all of the unit is black, including the machined surfaces and the valleys of the stamped letters? Told you I'd split a hair or two
  #114
Old 07-08-2014, 08:28 AM
Judge273's Avatar
Judge273 Judge273 is offline
FWIW, this is my thoughts on what's best:
Mike/Illinois
  #115
Old 07-08-2014, 08:35 AM
165th's Avatar
Looking good Tim and cant wait to see it. The paint work on those heads is a little different, Is that to replicate paint burn off?
Originally Posted by Red Goat View Post
Thanks Brew. We redid the engine paint after getting the engine over to Steve's shop. The color just wasn't quite right. Ended up using Scott Tieman's paint for it. I think Greg had requested that the heads be painted that way to replicate burn-off, but I didn't choose to go that way when we repainted.
Tim is right. This is a pet peeve of mine. Instead of carrying a wire brush and touch up kit around re-coating the black enamel burns, I prefer to just have the hot spots not painted at all. That's Hirsch high heat Cast Iron primer under the color coating.The blue fades from color to just ghosted or none over the hot spots of the heard. This one could have used some more paint in the spark plug areas and the leading edge of the head where the casting date is, but since we knew the engine was going to be repainted, there was no need.
These pictures are taken after 4 hours on a dyno and no touch up kit applied This keeps your hands free to admire the dyno results of 466HP/535ft lbs torque in one hand and a cold one in the other. Way to go Jim Robertson!
ID:	369443   Click image for larger version
ID:	369444   Click image for larger version
  #116
Old 07-08-2014, 10:44 AM
Cool
This looks good in that you can see the stamping but my bet would be that they were painted black after machining. I have no definitive proof, just gut feel based on years of manufacturing experience.
Bob Woodard
Brighton, MI
  #117
Old 07-08-2014, 03:21 PM
Red Goat's Avatar
Alrighty then... seems the crowd goes wild for the black MC. We'll get that taken care of!
Also, I'm needing some interior parts for this car if anyone has an interest in selling:
1. Need a pair of really clean lower door panels. Any color will do. 72-77 are the same.
2. I need a really nice formula steering wheel.
Let me know if anyone has something that they'd be willing to part with.
Cheers,
Tim
  #118
Old 07-08-2014, 10:50 PM
Brewster's Avatar
The master cylinders where machined after painting which was one light coat of paint. There are or where part numbers above the forward outlet in small font that had 5-6 numbers. I have pictures of an original along with other pics of units that have rust in those areas.
Those machined surface areas had surface rust while the rest of the unit still sported paint. That tells the story of the process and how to reproduce it.
I have pictures however Im in Omaha on business and have no access at the present time.
Good call Tim and will let you know about a wheel I had my name on long ago soon.
  #119
Old 07-18-2014, 12:22 PM
Red Goat's Avatar
Lucy is getting this beautiful NOS dash pad installed...
... along with all new M&H wiring harnesses throughout the car.
ID:	370460   Click image for larger version
ID:	370461   Click image for larger version
ID:	370462   Click image for larger version
ID:	370463   Click image for larger version
  #120
Old 07-18-2014, 12:28 PM
Thumbs up
It's going to be a fantastic car Tim! Steve does such nice work!
Bob Woodard
Brighton, MI
