Old 01-18-2014, 05:45 PM
transam1972 transam1972 is offline
Default spoiler welting
Originally Posted by SD73 View Post
Tell me more about the welting with the pull off tape. Who sells that one? Any part numbers?
F BODY WAREHOUSE..E BAY sells a variety of welting too
The Following User Says Thank You to transam1972 For This Useful Post:
  #102
Old 01-19-2014, 01:54 PM
Default FRONT AND REAR SWAY BAR HARDWARE
Y99 TRANS AM FRONT 1 1/4'' SWAY BAR 7/8'' REAR SWAY BAR
Name:	REPO &ORIG FRONT & REAR SWAY BAR BRACKET.jpg
ID:	349996   Click image for larger version
Name:	ONE AND ONE QUARTER INCH  FRONT SWAY BAR HARDWARE.jpg
ID:	349997   Click image for larger version
Name:	ORIG & REPOP BRKT.jpg
ID:	349998   Click image for larger version
Name:	ORIG FRONT BRACKET WITH ALLAN SCREWS Y99.jpg
ID:	349999   Click image for larger version
Name:	rear sway bar bracket & bushing.jpg
  #103
Old 01-19-2014, 02:28 PM
Default 7/8 REAR BUSHING INSTALLED
Name:	SEVEN EIGHTH REAR SWAY BAR BUSHING.jpg
Name:	rear bushing.jpg
  #104
Old 01-19-2014, 05:57 PM
Default 1970 to 1981 GM SR TRANS AM FENDER
Name:	N.O.S. FENDER.jpg
Name:	1970 TO 1981 GM SERVICE REPLACEMENT FENDER TRANS AM.jpg
Name:	1976 AIR VENT.jpg
Name:	air extracter.jpg
Name:	GM SR FENDER DETAIL.jpg
  #105
Old 01-19-2014, 06:04 PM
Default FENDER MOD
Name:	VALANCE BRACKET DETAIL 2.jpg
Name:	VALANCE BRACKET INSTALL DETAIL.jpg
Name:	ORIGINAL 1972 VALANCE MOUNTING BRACKET.jpg
Name:	SR SHAKER.jpg
Name:	SR SHAKER 2.jpg
  #106
Old 01-19-2014, 06:11 PM
Default ROCHESTER QUADRAJET
Name:	ROCHESTER QUADRAJET 4 BARREL.jpg
Name:	SERVICE REPLACEMENT 1975 455 H.O. AUTO.jpg
Name:	455 H.O. AUTO.jpg
Name:	BOBA FETT SLAVE 1.jpg
  #107
Old 01-19-2014, 06:27 PM
Default UNDERBODY
Name:	cable detail.jpg
Name:	underneath detail 2.jpg
  #108
Old 01-19-2014, 06:57 PM
Default UNDERBODY
Name:	underneath detail.jpg
  #109
Old 01-19-2014, 07:11 PM
Default RANDOM
Name:	72 tail pipes and tips.jpg
Name:	orig vs nos tip.jpg
Name:	LOWER FRONT FENDER.jpg
Name:	MY 455 H.O.COM T SHIRT.jpg
Name:	TRANS AM AD.jpg
  #110
Old 01-19-2014, 07:18 PM
Default OIL PAN REMOVED FOR 1 PIECE GASKET INSTALL
Name:	oil pan removed 2.jpg
Name:	oil pan removed 3.jpg
Name:	oil pan removed 4.jpg
Name:	oil pan removed 5.jpg
Name:	oil pan removed 6.jpg
  #111
Old 01-19-2014, 07:23 PM
Name:	oil pan removed 7.jpg
Name:	oil pan removed 8.jpg
Name:	oil pan removed 9.jpg
Name:	oil pan removed.jpg
Name:	oil pick up pump.jpg
  #112
Old 01-19-2014, 08:15 PM
Default BUSHING INSTALLATION
Name:	LOWER FENDER MOUNT.jpg
Name:	FRONT SUB FRAME.jpg
Name:	FRONT SUBFRAME 2.jpg
Name:	FRONT SUBFRAME 3 not tightened.jpg
Name:	FRONT SUBFRAME 4.jpg
  #113
Old 01-19-2014, 08:26 PM
Default CONTROL ARM
Name:	UPPER CONTOL ARM.jpg
Name:	UPPER CONTROL ARM 2.jpg
Name:	UPPER CONTROL ARM DETAIL.jpg
Name:	rear subframe.jpg
  #114
Old 01-19-2014, 11:03 PM
Formulabruce's Avatar
This one looks like its time for a repair?
" Long may we DRIVE !"
The Following User Says Thank You to Formulabruce For This Useful Post:
  #115
Old 01-19-2014, 11:40 PM
Default 1972 FIREBIRD SEATS STANDARD & DELUXE
Name:	72 original seat track covers.jpg
Name:	72 seat track hardware.jpg
Name:	1971 to 1974 seat tracks.jpg
Name:	seat frame front.jpg
Name:	seat frame rear.jpg
  #116
Old 01-20-2014, 12:15 AM
Default 455 HIGH OUTPUT
Name:	455 C.I.D..jpg
Name:	455 H.O. 1.jpg
Name:	455 HIGH OUTPUT.jpg
Name:	PONCHO POWER.jpg
  #117
Old 01-20-2014, 05:06 PM
70RAlll 70RAlll is offline
I am sorry to say this, but your Star Wars stuff is a bit creepy.. do you really need to include it in your TA pictures?? No one else is going to tell you, but I am sure others have the same opinion I do.. why don't you keep your pictures to TA's..
The Following User Says Thank You to 70RAlll For This Useful Post:
  #118
Old 01-20-2014, 05:19 PM
Default no disclaimer
I can post any photo I want,you dont have to click on it...you off all people find Trans Am photos creepy?...I have not been able to post photos for over a year...I downloaded a bunch of photos because I hope that one picture may be helpful to someone....just as someone elses photo is helpful to me....STAR WARS is hugely popular, just because you dont like it....what other intrests do you have besides Trans Ams??
  #119
Old 01-22-2014, 07:40 PM
Default M & H ELECTRIC 1972 455 H.O. AUTO A/C UNI. DIST. SHAKER ENGINE HARNESS
Name:	1972 unitzed distributer auto ac harness.jpg
Name:	1972 unitized distributor starter leads.jpg
Name:	1972 alternator plug.jpg
Name:	harness lead ends.jpg
Name:	GM saved connector.jpg
  #120
Old 01-22-2014, 08:16 PM
Default 1972 UNITIZED DISTRIBUTOR
Name:	unitized distributor and shaker power.jpg
Name:	UNI. DIST. LEAD.jpg
Name:	more leads!!.jpg
Name:	FUSE BLOCK.jpg
