Old 05-30-2016, 10:42 PM
beemergary's Avatar
Originally Posted by Sanduners View Post
Looking for the white shift knob for a 1963 automatic floor shifter.
Looks like this:
I took a cue ball and turned it down.
  #102
Old 06-16-2016, 08:11 PM
chuckolot chuckolot is offline
Default Looking for
Looking for pass side fresh air vent for my 62
  #103
Old 06-16-2016, 10:29 PM
moneypit's Avatar
moneypit moneypit is offline
I may have a good one on my parts car, I won't be able to check until Sunday.
Colt.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
77 Grand Prix base model, 350 pontiac
97 F250 7.3 turbo diesel
85 CJ7 Laredo
65 Impala SS 396, 4 spd, A/C.
  #104
Old 06-16-2016, 10:41 PM
Thanks! The part where the cable connects to the door busted on mine
  #105
Old 06-17-2016, 09:08 AM
tiacguy's Avatar
tiacguy tiacguy is offline
I have two real nice like new vent cables form a 62 you have mail
  #106
Old 06-17-2016, 09:15 AM
tiacguy's Avatar
I forgot I have the pics in my computer here
  #107
Old 06-17-2016, 09:17 AM
Sorry looking for the passenger air door not the cables, thanks though
  #108
Old 06-17-2016, 01:57 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Can you just use JB weld epoxy and repair it?
  #109
Old 07-05-2016, 01:21 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
I have the door at the house. For some reason the picture will not upload. PM me you email address. John
  #110
Old 07-10-2016, 12:51 PM
moneypit's Avatar
Default Vent.
Sorry it took so long, but if you still need the vent let me know. The one I pulled is in good shape. I sent you a pm.
Thanks, Colt
85 CJ7 Laredo
  #111
Old 07-31-2016, 04:20 PM
beemergary's Avatar
Need inside trim pieces +2 bows to do a headliner on a BIG BACK WINDOW 63 Tempest. Will be at Norwalk
  #112
Old 08-14-2016, 06:39 AM
ta-69's Avatar
ta-69 ta-69 is offline
Looking for a pair of 63 lemans tail lights. Thanks Jim
  #113
Old 08-30-2016, 12:25 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Carpet Sill plate moldings wanted
Hi, looking for a pair of good used sill plate moldings for a '63. I believe 62 and 63 two-door cars, both coupe and convertible are the same.
Name:	63Lemans Sill Plates.jpg
Peter Serio
Owner, Precision Pontiac
  #114
Old 08-30-2016, 08:20 PM
Radman's Avatar
Radman Radman is offline
Ames has the door sills. You will need to re-drill the holes for the mounting screws.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
  #115
Old 08-30-2016, 09:21 PM
Thanks for the tip, I had those on another car and whenever I washed the car water seeps in from the bottom drain holes in both doors underneath the still plates and into the carpet!!
Peter Serio
  #116
Old 08-30-2016, 10:07 PM
tom s tom s is offline
The Ames plates are not correct,close but not right.Tom
  #117
Old 08-30-2016, 11:40 PM
Although I made the Ames parts work, I found that I had to de-burr the heck out of them, as my shoes would get caught. John
  #118
Old 08-31-2016, 10:56 PM
beemergary's Avatar
Would have to check but seems like 68 GTO sill plates work and nobody knows.
  #119
Old 09-01-2016, 12:13 PM
I would prefer a set of original 1962 or 1963 sill plates.
The bottom drain holes in the doors dump water out right on the outer edge; the full length of both sill plates. The sill plates for the early 60s cars have a downturned edge running the length of the plate. This is to prevent water from getting into the car. Underneath the plate all along the long outer edge you put some caulking, again to prevent water entry.
Mid and late '60s GM car still plates lack this down-turned edge.
The car is close to being finished (after many years) and I only have about 6 or 7 items that I need to track down to finish it up. I had several parts cars and years ago + I located a car in a junkyard only one state away. I should have looked at those but I did get a lot of the folding top metal parts, and the trim sticks around the body opening, from the car in that yard; all in great condition. All of those parts are restored and on my car now.
Peter Serio
  #120
Old 09-01-2016, 07:30 PM
moneypit's Avatar
I have a pair on my 62 2dr parts car. Good driver quality. I can pull them off and send you some pics by Saturday evening if your interested.
Thanks, Colt.
85 CJ7 Laredo
