Old 06-06-2015, 09:22 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Originally Posted by Matt Meaney View Post
can anyone post a video of what these engines sound like at idle and maybe a drive away? so, you can hear how it's not revving to the moon before it moves. if you can, list all the particulars with it too. cam, idle rpm, static compression, timing, what exhaust, convertor, etc. the more info the better.
If you want to click on the Facebook link on the bottom of this post and go to the video section, there are short idling videos of a RAIV Trans Am, my 80 T/A that uses a 259 duration cam with 108 LSA mentioned previously and my 74 red Firebird with a 275/283 108 LSA mentioned previously you.
Also there are several videos of them at the track but unfortunately the noise from the race cars drown out the sound of our cars in most of the videos. If you search on YouTube under "pkmusclemotors" there are a couple of good Go-Pro videos of my brothers 70 Firebird using a 455 with RAIV heads and mid 270 duration cam ground on a 106 LSA. The video that he races a 64 GTO has some pretty good sound from inside the car.
I just watched the videos on YouTube and the one titled "1970 Firebird Formula runs mid 10 second quarter mile @ 128 mph in car view " is an excellent example of what can be accomplished when extra effort is applied to keep your car comfortable and you are not worried about adding a few extra pounds to keep your Pontiac a true "street car"!
Go fast, see Elvis!
  #102
Old 06-06-2015, 10:07 AM
PAUL K's Avatar
As said,my 366 V engine with the single plane intake and a lot of cam for a little CI and lazy ports showed WAY lean on the AFR gauge but had real heavy gas smell at idle.When I went to the dual plane it showed a little richer with no carb change and had less gas smell.Tom
Good post! Port design and size effects idle quality, throttle response, torque and horsepower. Keep the velocity high and the ports as small as possible to get the job done, this should be on the priority list before flow numbers.
Also carburetors equipped with an adjustable idle mixture screw at each barrel and screw in air bleeds will make it easier to dial in the air fuels at idle and help with the eye burning and gas smell .
Go fast, see Elvis!
  #103
Old 06-06-2015, 10:26 AM
PAUL K's Avatar
I think this link will work:
https://youtu.be/9Zk4n3KAawU
Go fast, see Elvis!
  #104
Old 06-06-2015, 12:15 PM
ta man ta man is offline
I don't have a video of mine,its similar to Cliffs,mine has a steady strong idle,when I say it drives like a stock 301 Trans Am..believe it ,with the Continental Convertor you can put the car in reverse or drive and it will move..no revving up of the engine to get it going.
  #105
Old 06-06-2015, 12:19 PM
firechickenman's Avatar
firechickenman firechickenman is offline
Great thread! A lot of god info here! Click the link in my sig for a video of mine. If you click on my name or pic below the video, I have several videos of it. In car and outside. Comp 290B6, 290/304 dur. 255/266 @ .050 106 LSA installed at 103 ICL.
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
  #106
Old 06-07-2015, 03:04 AM
brut4s's Avatar
brut4s brut4s is offline
Firechickenman, how is the car on the street?
  #107
Old 06-07-2015, 10:37 AM
Very streetable in my opinion. Idles a little rough at 900 in drive, 1050 in neutral/park. The Continental converter doesn't drive like a stocker but does very well on the street for a 4000 stall. It's pretty comfortable at 70mph on the highway too. We did about 1400 miles in 4 days last year on drag week without the car even breaking a sweat.
Greg Weigart
  #108
Old 06-08-2015, 05:44 PM
PAUL K's Avatar
You might want to look at post #73 . Maybe you can by-pass running deeper into the ten's and go straight to the low ten's.
Go fast, see Elvis!
  #109
Old 06-11-2015, 07:52 AM
funkybird's Avatar
funkybird funkybird is offline
Very interesting thread
Totally hear what your saying ref big cams in a 455
Question
For a mostly stock street only driven 455 automatic car, how big a cam can you go?
I fell into the trap of a small cam with a big CU unit at the last rebuild (sadly before I discovered this forum). Whilst driveability is great, it needs high octane fuel to stop pinking.
Based on the generic advice from the cam manufacturers, I was more concerned about keeping vacuum for the brakes & my stock convertor.
Im thinking a cam change is needed at the next rebuild, but ideally, without the expense or trouble of switching the converter, which (as a novice) is another area of black magic to me
Consider that my car had the 068 cam (288/302). I dont think Pontiac ever fitted 041 (308/320) to an automatic car, but please correct me if Im wrong on this
So how 'big' should I go?
  #110
Old 06-11-2015, 09:12 AM
AG's Avatar
AG AG is offline
I have the 041 cam in my 9.1 cr 455 with Rhodes lifters and an automatic that works very well with a 2000 rpm stall converter. Vacuum is 14" at idle and the carb is easily tuned, really a very mild combo with RA manifolds and 2.5" exhaust with Dynomax super turbos.
  #111
Old 06-11-2015, 09:15 AM
77 TRASHCAN's Avatar
Question
You need to post more information about your car/engine. Compression ratio would be most important thing for cam selection
Shut it off
Shut it off
  #112
Old 06-11-2015, 09:46 AM
Steve C. Steve C. is offline
"Compression ratio would be most important thing for cam selection"
Important consideration, but most important ?
Often a 'catalog' suggestion is general and can be vague.
"The charts are often nowhere near scientific or definitive in its scope. Larger or smaller cubic inches, different lobe separation angles and other variables will alter these figures, but at least it's a starting point in the explanation of using a certain range of cam with a certain range of static compression ratio."
Good read and indicates the importance if interested:
http://www.badasscars.com/index.cfm/...prod/prd68.htm
Old information here:
  #113
Old 06-11-2015, 10:09 AM
ponyakr's Avatar
ponyakr ponyakr is offline
I'm not one of the experts here, but just thought I'd chime in anyhow. If you got enuff CR the "041" cam with Rhoads lifters is a real good cam for a 455 Auto, with stock converter.
We ran this combo in several 455 bracket engines over a period of many years. With the Rhoads lifters, they idled smooth enuff for us to launch from an 800 rpm idle with a stock 13" converter. We were not going for max hp, or ET, so we shifted at 5000rpm. So, for idle to 5000 rpm operation, I couldn't have asked for anything better.
Would our cars have run quicker with bigger cams ? Certainly. Later on, a track we ran, switched to 1000ft, instead of 1/4 mile, and they set the minimum for Super Pro bracket at 9.99. We were running 10 teens. So I switched from 4.11 to 4.88 gears and switched to a CC cam with 244/253 @ .050 dur and just over .500 lift, and of course, Rhoads lifters. Still had a TH400 with stock 13" converter. Still left from an idle, cut good lights, ran 60ft times in the 1.60's, and ran a 9.85.
CC still has these lobes available, but only in single pattern cams. I'm sure they'd grind a custom dual pattern with these lobes. But I'm thinkin these lobes may need a bit more than 9.5 CR to work well. We were running the '68-'70 big valve heads--16, 62, 64. I have not done any cam testing like these other guys have, so I'm sure they would know if these lobes are usable or not. With today's technology, there are probably many better lobes available.
http://www.summitracing.com/parts/cc...w/make/pontiac
http://www.summitracing.com/parts/rh...w/make/pontiac
Cliff has done LOTS of testing with the 041. I think he used the Crower 60919. I used the Crane and Melling versions, because they were cheaper at that time. The Melling SPC-8 is still only about $100 on Ebay. Jim hand wrote one of the best articles I've read on using the 041 cam and Rhoads lifters.
http://community.fortunecity.ws/silv...build/cams.htm
Hey, all I'm sayin is that the RA4 cam with Rhoads lifters worked great for us, for what we were doing, and helped us win lots of races. I'd like to hear from the experts here, at exactly what CR the RA4 cam becomes "not so good". Like, will it work OK at 9.5 but not too good a 9:1 ? I assume there is a CR number, below which, it is a bad choice.
  #114
Old 06-11-2015, 11:05 AM
Dyno test changing compression only
Page 51 here:
https://books.google.com/books?id=5L...hWCC6wKHaMbAFo
Not discounting the importance of adequate compression, but many will suggest the often small difference in increased compression has little impact on street driving. Especially in all weather conditions, including stop-and-go traffic, fuel quality, and never knowing what the tune up is going to be for "John Doe".
"I have found in my experiences tied to track results that higher compression and then having to go to longer LSA to kill the compression/bleedoff has resulted in lower ET's at the track."
Pontiac Dude
"Me,I see no valid reason to push the CR envelope for mostly "street" oriented cars."
Screamingchief
http://forums.maxperformanceinc.com/...ght=leave+shop
  #115
Old 06-11-2015, 11:16 AM
scott70's Avatar
scott70 scott70 is online now
I run a 462 ,,, 9.3 to 1 ,,crower 60919 cam with 1.65 rockers with Rhoades max lifters and idles very well,,,actually wish it had a little more lope to it. Pulls hard from idle to 5300. Probably further but just havent pushed the rpms any higher than that.
  #116
Old 06-12-2015, 11:40 AM
How do you like your v-max lifters??? Do yours make much noise??? Last time I heard Jim Hands wagon @ Ark City, Kansas he had the v-max lifters in his engine. They were not very noisy at all. When he had the original Rhoads lifters in his engine they were VERY noticeable....
Shut it off
Shut it off
  #117
Old 06-12-2015, 12:21 PM
scott70's Avatar
With my vmax lifters,,when i first start it up cold,,theyre fairly quiet but as the oil gets hotter,,the noise is definitely noticeable. I had regular Rhoads in a different engine,same car years ago and it seems to me the vmax are louder than those were,,,,,,but that was years ago.Setting the preload on the vmax is different the reg rhoads. Great vac for the brakes and a fairly smooth idle. Comp. cams 1.65 roller tip rockers.
  #118
Old 06-12-2015, 12:27 PM
steverino steverino is offline
Lots of great info , I'm following closely and learning quite a bit.
I'm curious ponyakr and AG, what rockers do you use with your RA4 style cams and rhoads lifters ?
Also lots of good info in the Jeff Smith sbc article, although they did use alum heads, maybe it had an effect on the detonation (or lack there of) ?
My builder's experience was similar in dyno testing of circle track racing engines as well as (mostly bbc) customer's street engines, insofar as the compression ratio net gain (for a street car certainly with unknown quality variances in pump fuel) was no worth even approaching 10 to 1, I had to plead with them to plain the heads to raise me to 9.4 (could even be 9.25-9.3)
In any case, many folks shared their insights with me before I selected cam for my 455 with tripower and stock 6X (milled for 99cc chambers), and I appreciate it, one o fthe things that this forum is great for !
I deliberated between; 1) RA4, but wasn't certain if it would perform as expected with 1.5 rockers . 2) crower 90243, and finally the choice I made, 3) the xe274
The scary thing is that some reputable builders as well as cam manufacturers were highly recommending the 268, I am glad I read Jim Hand's book, and decided to go "one size up", due to the larger displacement, I don't think I would've been happy with the 268
I am probly lucky that after almost 3k miles, the lobes and lifters seem to be ok thus far .
Now I am more "in tune" with the "sewing machine sound" , the engine can be a bit "ticky even with great oil pressure at steady rpm's
It does like a bit extra timing 16 initial (36 total), and 91 octane, but as long as gas is reasonable, I'm ok with that
The performance is great in fairly heavy 66 gto conv with 4 sp and 3.23
I know the power band is shortened, done by 4900 rpm, but that again is ok for my use, actually favorable to me, I do love the torque, which the 455 excels at anyway
I have had a few issues with the combo, we had to change valve seals to positive style, again , help from here on the forum helped me to pinpoint the issue (the builder had miscalculated the valve lift/seal clearance)
but with a stock cooling system, we've been running great and never too hot
So I'm sure my bottom end is good
I'm pretty certain that my heads are going to be a limitation to the total power I can make, but that is fine, I really want to keep the stock look under the 66 tripower
My question is, If I do decide to make a cam change at some point down the road ( I have considered it, but it's on the back burner for sure), what hydraulic flat tappet would I go to ? My heads are no clearanced for the 1.65 rockers, so I'm thinking maybe the crower 90243 still ?
I do see that respected builder Len Williams advertises a good power number from the RA4 style cam (which I believe is what he uses), and with 1.5 rockers and rhoads lifters, so maybe that would be a better route ?
I know that a roller and aluminum heads are where "all the power" is at nowadays, but
As I said, just thinking about it for now
Thanks for the info and all the great input !
  #119
Old 06-12-2015, 12:41 PM
AG's Avatar
AG AG is offline
I use 1.5 ratio roller rockers with the regular Rhoads lifters and it is tickey when warmed but it doesn't bother me, some people can't stand it. To me, the 455/RAIV cam is a tough low budget combo to beat with or without Rhoads lifters, mine is in my "family" car and I love it and don't need anymore power than it has. The motor I am building for my '68 Bird will have the Old Faithful on a 114 LSA, Edl CNC chamber CNC ported heads on a 461 but won't be a daily driver like my '72 vert family wagon.
  #120
Old 06-12-2015, 02:33 PM
ponyakr's Avatar
I used the reg Rhoads and stock 1.5 rockers. I realize that Cliff and Jim Hand say the 1.65's will make more power. But in my situation, I was bracket racing. I was not trying to make max power, or lowest ET. What I needed was a smooth idle at 800rpm, in gear, and lots of bottom end, off the line torque, so I could run a stock 13" converter.
Another reason I didn't run 1.65 rockers was that I'da had to hog out the pushrod holes. And it would'a just put more strain on the valve springs. Hey, I even ran stock bottleneck studs and 3/8 polylocks. Running 1.65 rockers was just not worth doing, for my purposes. If you haven't bought a cam yet, and you want more than a RA4 with 1.5 rockers can give, you can just use the extra money the rockers would cost and have a cam ground like you want it.
You could hear the tick. Some people just can't stand it. Even some guys that love a lopey idle, and loud exhaust, seem to hate Rhoads lifters. I really can only see a lot of advantages to using Rhoads lifters. Hey, they will extend the power range of most any cam. (Yeah, I realize they are not good for small cams and the steep ramp cams.) You can get by with more of a top end cam, but still have a decent idle, good vac, and more low end than possible without the Rhoads. It's a win--win. So what's not to like. Plus they have real snap ring retainers, instead of the flimsy paperclip style which some lifters have. I've read that Rhoads begin life as Johnson Hy-Lift lifters, and are then modified by Rhoads.
Hey, I was aksed to leave a Pontiac forum for recommending the RA4 / Rhoads combo. They said that was old, out of date technology, that nobody had used in 30 years. Most of them thought the CC XE cams were best for almost every app, regardless of cube. And a respected Pontiac engine builder, was leading the charge. He even said he recommends rollers, unless the customer absolutely insists on a flat tappet. That's all I'll say about that.
