Old 10-08-2022, 10:40 PM
Goatboyjohnny Goatboyjohnny is offline
Been too long since I posted an update.. been a long year.. Here's today's progress.. finished the final but of welding, prepped the underside and firewall, and sprayed 3 coats of black epoxy.
ID:	600145   Click image for larger version
ID:	600146   Click image for larger version
ID:	600147   Click image for larger version
ID:	600148   Click image for larger version
  #102
Old 10-09-2022, 10:35 AM
1_Wild_Cat's Avatar
Nice work…I’m not sure how I missed this thread before but I really enjoyed going through it today. Keep at it - we all know it’s a marathon not a sprint.
  #103
Old 10-09-2022, 11:20 AM
Thank you WildCat
  #104
Old 10-14-2022, 04:44 PM
Here's the last couple days progress.. Body color on cowl and firewall.. kind of excited to see the first bit of Burgundy sprayed.. sprayed the color Wednesday night and cleared it during my lunch yesterday. I'll be blacking out the underside and firewall tomorrow hopefully 😊
ID:	600434   Click image for larger version
ID:	600435   Click image for larger version
ID:	600436   Click image for larger version
  #105
Old 10-16-2022, 07:04 PM
Weekend progress.. Moved the car out of the booth to epoxy and paint the gas tank. Seam sealed the inside of the trunk and passenger compartment in between coats. After the tank dried enough to move, The car went back in for a final blackout of the firewall and underside.
ID:	600557   Click image for larger version
ID:	600558   Click image for larger version
ID:	600559   Click image for larger version
ID:	600562   Click image for larger version
  #106
Old 10-16-2022, 07:43 PM
1_Wild_Cat's Avatar
What product did you use to paint the firewall black? Looks great BTW.
  #107
Old 10-16-2022, 08:01 PM
The firewall and underside is all Flat Black Rust-oleum. I believe I added 2 ounces of enamel hardener and 2 ounces of Japan Jet Drier to a half gallon, and reduced it with acetone to make it sprayable. I can't recall the exact reduction rate, I went with what the back of the can said. Stuff actually sprays pretty damn good. And thanks, I'm happy with it too 🙂
  #108
Old 10-16-2022, 10:29 PM
Sounds like you're talking about the Rust-Oleum in the quart or pint can. I used the same thing for my firewall except I used gloss. I live in a very dusty environment and the dead flat just holds dirt too well. The gloss flattens out to about 60% in a few months time.. Pretty durable as mine has been there for probably about 12 years.
Old 10-16-2022, 10:36 PM
Yes sir Greg, I believe it is the industrial line, bought a gallon used about half. I used the same thing only in satin black on my frame.. Core support and inner wheel wells are base/cleared with a flattening agent.
The Following User Says Thank You to Goatboyjohnny For This Useful Post:
  #110
Old 10-17-2022, 05:43 PM
1_Wild_Cat's Avatar
Cool. Thank you Goatboy and Greg. Hopefully I’ll be getting to that point soon-ish.
  #111
Old 11-03-2022, 08:31 PM
Last couple weekends progress.. detailed and mounted the gas tank, dusted off the frame, installed the Z-bar and clutch rod, added color code designation markings to firewall, and lowered the body onto the frame for what I hope is the last time 🤞
ID:	601674   Click image for larger version
ID:	601675   Click image for larger version
ID:	601676   Click image for larger version
ID:	601677   Click image for larger version
  #112
Old 11-03-2022, 08:40 PM
Sorry for the sideways/upside down pics..
ID:	601680   Click image for larger version
ID:	601681   Click image for larger version
ID:	601682   Click image for larger version
ID:	601683   Click image for larger version
  #113
Old 11-08-2022, 08:59 PM
GT182's Avatar
GT182 GT182 is offline
You've come a long way since I last took a look. Looks great.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #114
Old 11-10-2022, 01:48 PM
Thanks my man!!!
