Old 12-19-2017, 10:38 AM
Tom Vaught's Avatar
Boost Engineer
Today I have provided a list of the most common Holley 2-BBLs used for 6-Pack set-ups
These same carbs could be used on a 389 Pontiac Engine (as MOPAR/Holley offered a set-up for the 383 engine
These same carbs could be used on a 440-455 Pontiac Engine (as MOPAR/Holley 440 set-up would work well (especially with Vacuum carbs).
List # Vehicle Year Engine Trans Type CFM
R4144 - 1970 - 440 - Auto - Center - 355
R4175 - 1970 - 440 - Both - Front - 500
R4365 - 1970 - 440 - Both - Rear - 500
R4374 - 1970 - 440 - Manual - Center - 355
R4375 - 1970 - 440 - Manual - Center - 355
R4376 - 1970 - 440 - Auto - Center - 355
R4382 - 1970 - 440 - Both - Front - 500
R4383 - 1970 - 440 - Both - Rear - 500
R4391 - 1969 - 440 - Manual - Center - 350
R4392 - 1969 - 440 - Auto - Center - 350
R4393 - 1969 - 440 - Both - Front - 500
R4394 - 1969 - 440 - Both - Rear - 500
R4669 - 1971 - 440 - Manual - Center - 355
R4670 - 1971 - 440 - Auto - Center - 355
R4671 - 1971 - 440 - Both - Front - 500
R4672 - 1971 - 440 - Both - Rear - 500
R4789 - 70&71 - 340 - Both - Front - 500
R4790 - 70&71 - 340 - Both - Rear - 500
R4791 - 70&71 - 340 - Manual - Center - 355
R4792 - 70&71 - 340 - Auto - Center - 355
R6403 - 1972 - 440 - Manual - Center - 355
R6404 - 1972 - 440 - Auto - Center - 355
R6405 - 1972 - 440 - Both - Front - 500
R6406 - 1972 - 440 - Both - Rear - 500
I will add more to this in a separate post.
Tom V.
  #102
Old 12-19-2017, 11:05 AM
Tom Vaught's Avatar
Boost Engineer
I have included two exploded view illustrations of the Holley 6-pack 2-BBL carbs
(and a Picture of a Holley 950 cfm 3-BBL carb).
The first thing that you will notice is that the old 950 3 BBL carb used a Secondary Vacuum Pod with 4 screws sealing the lid on the pod.
The Holley 6-pack carbs used a 6 Bolt secondary Vacuum Pods with 6 screws sealing the lid on the pod. They are not inter-changable.
The second thing is the 6-pack carbs get their vacuum signal to open the pods from a source in the center carb (like the 3-bbl)
but then use two vacuum hoses to supply that signal to the end carb diaphragms. There is a external nipple on each carb close
to vacuum pod mounting screws. Signal goes from the center carb thru the hose to the pod.
More on 6 pack carbs tomorrow.
Click on images
Tom V.
ID:	470427   Click image for larger version
Name:	HOLLEY Six-Pack-End-Carbs.jpg
ID:	470428   Click image for larger version
Name:	3 BBL Carb.jpg
  #103
Old 12-19-2017, 04:21 PM
Tom Vaught's Avatar
Boost Engineer
If you look on the End Carbs Illustration you will see that the 6-pack carbs had idle mixture screws on the Secondary long before the first 4-Corner Idle 4-BBLs were introduced.
The reason for the mixture screws is because we do not have a common base where we could machine in "Purge Slots" like a 4 BBL on the Vacuum Secondary carbs.
The rare Mechanical Secondary Carbs had a Metering Block and Idle Circuits just like the Primary side of any 2 BBL.
Chrysler wanted to be able to have the same Air/Fuel Mixture to each cylinder at idle with their 6-Pack Manifolds so they did dymo testing (as I mentioned before with the manifolds and tweeked the mixture screws on the end carbs until all of the runners were getting the same Air/Fuel Mixture with THAT manifold.
Then they had Holley set that Air/Fuel Ratio on that List # carb on the flow stands in production. Then they PLUGGED the screws so they could not be adjusted without destroying the plugs/base around the plugs.
Many racers did drill out the plugs and mess with the adjustments for racing, most times making the cylinder to cylinder balance a mess at idle but they were RACE CARBS AND ENGINES! Right. You have to screw with a Holley carb or you are not a racer.
(Have posted before how happy some owners are after I put the calibration back to stock Holley settings. So that is why the plugs and mixture screws are there.
Tom V.
  #104
Old 12-19-2017, 06:01 PM
Tom Vaught's Avatar
Boost Engineer
I mentioned the Vacuum Diaphragms used on the 6-Pack (and 435 HP Corvette) engines as having 6 screws to hole the cover on the Housing that bolts to the carb main body.
The 6-Pack Diaphragms are still out there in service but the old 3 BBL carbs 4 screw diaphragms have not been available in many years.
BUT you can mod a 6-pack diaphragm to be used in a 3-barrel by cutting the diaphragm (using a hole punch to match the 3 BBL mounting holes.
That is the easy part.
You also have different length stem peaned on the diaphragm and its washers. But if you remove the old 3-BBL stem, cut the 3 BBL stem down so that you have a new length to pean over the washers, it then will go right into the 6-Pack diaphragm and be close enough it length to work fine.
You put the 6-Pack stem hardware in a carb parts tray.
So to summarize,
1) Trim the ears off the 6-Pack diaphragm but keep the sealing surface so it can be glued to the 3-BBL housing.
2) Remove the original 6 pack diaphragm's stem and put it away in parts.
3) Modify the original stem from the 3 BBL to go on the new trimmed 6 Pack diaphragm.
Assemble the parts in the 4-Bolt 3-BBL housing and you are good to go with your now working again 3 BBL carb.
Tom V.
  #105
Old 12-19-2017, 11:14 PM
Tom Vaught's Avatar
Boost Engineer
Two other quick comments for tonight.
1) The 3-BBL Vacuum Diaphragm Stem is about .700" LONGER vs the 6-pack Vacuum Diaphragm Stem.
You can't add material to the 6-Pack stem to gain .700" additional length (splice in a section) because the hole thru the vacuum housing that bolts to the carb is not that large and the stem travels in an arc as it opens the throttle blades.
2) So the correct method is:
Grind off the old peaned over stem metal.
Create a new stem (using a lathe or careful filing.
install the new stem thru the 1st washer, thru the 6-Pack diaphragm, thru the 2nd washer, and then with everything in place pean over the new stem over and you are done.
Sounds confusing but a simple inspection of a vacuum diaphragm, makes it very clear.
Tom V.
  #106
Old 12-20-2017, 06:44 AM
Tom Vaught's Avatar
Boost Engineer
I was tired last night.
In simple terms remove the metal rod from the old 3 barrel diaphragm, mod it so it can be repeaned on the 6-Pack diaphragm.
Install it and the two metal discs on the new 6-Pack diaphragm and repean it.
Tom V.
More later.
  #107
Old 12-20-2017, 08:24 AM
Formulas's Avatar
Formulas Formulas is offline
Tom i have a 1050 3bbl. I was under the impression that if my diaphram ceased ops. I could use the more mainstream vacum housing is that not so?? Of course opening rate would have to be recalibrated as the larger diaphram will have more force at lower vacum siginal
  #108
Old 12-20-2017, 08:46 AM
Tom Vaught's Avatar
Boost Engineer
A bit more on 6-Pack carbs and 3 BBL Carbs.
The first Holley "Tri-Power" systems for the Big Block Chevy Engines was offered in 1967. I have a Hot Rod Magazine Cover picture somewhere (1967 time frame) with a prototype set of carbs mounted on the BB Chevy Engine. This was taken before the final casting design was put into production for the Corvette Engines.
In 1969, Holley offered the 6-Pack carb set-up on the MOPAR vehicles. Basically the same set up as the Corvette.
So now we come to the first technical point for the day. I have attached a picture showing the two metering plates offered on the secondary carbs. The Rectangular Plate being the early plate (from 1967 to 1969) and the "second design" plate (with the angled lower edge plate, see picture). They are not interchangeable. So if you have early carbs some of the Hot Rod (aftermarket) plates with removable jet capability may not work and you will be wondering why. See aftermarket plate pic.
It has the shape of the 67 style plate but is really designed for the 4 BBL vacuum Secondary carbs. More on 6-pack and Corvette 2 BBL carbs later today.
Name:	6-Pack Metering Plates.jpg
ID:	470566   Click image for larger version
  #109
Old 12-20-2017, 01:24 PM
Tom Vaught's Avatar
Boost Engineer
Many People, including myself, like a carbed engine that senses what the engine actually wants for airflow and gives it just that much.
I have a couple of 850 Vacuum Secondary carbs that are a exceptional on a road vehicle.
Same deal applies with the 6-Pack Vacuum Carbs except that they can support more airflow thru a larger engine.
Simple Math: Center Carb airflow = 355 cfm @ 3" Hg test pressure. To get to 4 BBL test pressure flow multiply the 2 BBL cfm by .707 or
355 x .707 = 250 cfm (4 BBL Rating).
Same deal for the end carbs:
500 CFM x .707 = 353 cfm for each carb and two carbs so 707 total cfm for the 2 end carbs.
So 707 cfm plus 250 cfm = 957 cfm (same as our 3-BBL Holley carb) but a lot "Cooler" looking package. Both set-ups should run about the same times on the track (if dialed in properly) as they are both Vacuum set-ups and they have 100 more REAL CFM vs the Corvette 850 CFM Vacuum Carb. Holley did stuff for a Reason.
Tom V.
  #110
Old 12-20-2017, 05:34 PM
Tom Vaught's Avatar
Boost Engineer
In my next post I will describe the parts required and the mods necessary to install Vacuum Secondary 6-Pack carbs on your 1966 Pontiac Tri-Power Manifold.
1) You need to order 3 of the adaptors in the link below so that you can mount your vacuum carbs to the Pontiac Intake. They are $40.00
each. You can buy cheap chinese adaptors from Speedway for $15.00 each but the quality difference is apparent.
http://www.dashman.net/product.html?id=245
(Dashman also shows you a pic of the adaptors on the pontiac intake).
2) So now you have the Holley Carbs, the Intake, the Intake adaptors, and are now ready to move on to the Fuel line fabrication and vacuum hose routing on the passenger side of the engine. I have provided a Picture of a MOPAR engine so you know what the fuel lines look like and the vacuum hose routing looks like.
Finally you need to install the safety linkage to manually close the secondary throttle on the vacuum carbs when you let off on the gas.
The fuel lines needed to be longer and of course the safety linkage also needs to be longer so some fabrication is required.
The links have to be cut and additional length added to them for the wider spaced carb position.
Looks at the pics and you will see what I mean. (I just cut the two links and added a piece in the middle of each one to make it longer).
Tom V.
Name:	Vacuum Lines and Fuel Lines-1.jpg
ID:	470607   Click image for larger version
Name:	Throttle Closing Safety Linkage-1.JPG
  #111
Old 12-20-2017, 09:33 PM
Tom Vaught's Avatar
Boost Engineer
One thing I just noticed on the Vacuum Hose Picture I provided. The vacuum hose from the metering block to the distributor can easily be seen. The hose connection to the center carb main body is hidden. Will try to scrounge up a clear picture on that connection.
OK Found a decent picture.
The nipple on the metering block is the upper nipple (it is pointing slightly upward and to the right).
The nipple for the signal to the secondary carbs can be seen on the main body and it is pointing slightly downward and also to the right.
Tom V.
Name:	Both connections.jpg
  #112
Old 12-21-2017, 02:29 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
Default Scrump-delie-ishes!
Is that yours Tom?
That looks absolutely delectable. an Christmas is jus roun the corner!
Then again that little fat bast, ur a, presious lil feller, never leaves me nutten that cool.
Maybe I could coerce, um, I mean converse with him since I've been mostly well behaved this year.
Been attending class all along with great anticipations of saving money... little did I know...
I'm going to try and stay the course for now though as I have my 400 rebuilt and a 3310C still in the box.
I'm assuming with the newer "High Location" Idle Feed Restrictions I may want to revisit that post at some point.
Appreciate the tempt...uh, technical data.
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
  #113
Old 12-21-2017, 07:42 AM
Tom Vaught's Avatar
Boost Engineer
That picture is of a Factory 6-Pack Intake and the Holley carbs installed. Used to show the linkage for the Positive Throttle Closing links.
There is a Thread out there called "For historical purposes" (in the Tri-Power Forum that shows my intake system The BG Intake is not nearly as tall (more stock Tri-Power Height).
Tom V.
  #114
Old 12-21-2017, 09:04 AM
Tom Vaught's Avatar
Boost Engineer
A story on 3-BBLs.
Many, many years ago I was helping Marty Palbykin on his NATURALLY ASPIRATED 1971 GTO. 470+ CID engine
850 CFM Holley Carb, Tilt Front End for easy maint on the vehicle and light weight on the front end.
So Marty decides that he wants to try more CFM on the engine. So we talk about installing a Holley 3-BBL on his car
(a REAL 100 cfm increase in airflow to the engine).
Marty is good with that deal but he says he wants the 3 BBL to be a Double Pumper Carb.
Not a Old School modded (660 center squirter Mechanical Linkage) single shooter removed
and 4 tube shooter installed.) Nope not going to make it. Has to be a Double Pumper 3 BBL carb.
So a Very Good Machinist Friend, Bill Klausing and I decided to build a 3 BBL Douple Pumper Carb
from a 850 Double Pumper Carb that already had the front and rear pump shooter bosses cast into the mainbody of the carb.
Installing a 3 BBL Throttle Blade was easy enough, just a bit more work in the center of the base
and using the same Double Pumper Throttle Shafts.
But now the metal needed to be removed around the rear Power Valve area and that void plugged
with a plug and a two part metal epoxy bonding process. So we did that deal and it looked great.
No need for a rear power valve on a Race Carb.
So we give the carb back to Marty for testing.
Primary works great as it should. Secondary operation was poor (being kind).
So I get the carb back and have it flowed on the Holley Flow Stand and the air/fuel is ok on the
rear but there is a giant lean area between the two rear boosters. So another Carb guy says:
"That is why the boosters are moved inward on a 3 BBL carb, to remove that lean spot in the center of the rear fuel distribution to the manifold.
Got to do that or the rear distribution is bad."
Well we previously found that deal out Bubba. I laugh at the carbs I see in the internet with the
two 3 BBL blades vs the normal 4 throttle blades and bragging about massive cfm increases with
their carbs. Been there done that .
So we need to have the boosters in the 3 BBL spots for the right mixture in the manifold.
1050 carbs use copper tubes to feed the fuel into the secondaries. Might have been easier
to try those (thinking about it today) and more cfm capability but we did modded conventional
boosters (moved to the 3 BBL locations. More metal Epoxy and then more flow testing.
But the mod worked. We retested the carb on the Holley Air Stand and the distribution was great on the rear
of the 3 BBL prototype "Double Pumper". So Marty ran the carb until he decided to go with Boost and then
the carb went to someone else I think.
Marty did say that he thinks with the converter he had that now we really did not need that pump shot on
the secondary side. Thanks Marty (;>( LOL!
So my points are:
1) Holley put the boosters where they are on the 3 BBL (secondary side) where they are FOR A REASON.
2) Holley did not put a shooter on the secondary side of the 3 BBL when they stayed with a Vacuum Secondary
carb (for a reason).
3) The Hot Rod Guys made the 4 shooter kits for the 3 BBL carbs (converted to mechanical secondary operation)
for a reason.
4) Center Squirter carbs and Double Pumper carbs were created because of the work and knowledge learned from
the 3 BBL carb mods and other mods before that time.
Mechanical secondary carbs need pump shots vacuum Secondary carbs can get away without a pump shot on the secondaries.
Big secondary carbs or Four (2 BBL Dominators) need big pump shots when installed on big plenum manifolds.
So now you know a bit more about the 3 BBL story.
Tom V.
  #115
Old 12-21-2017, 03:19 PM
Tom Vaught's Avatar
Boost Engineer
Today I am going to talk a little bit about magazine articles, and a couple of comments about the people who write the articles.
Anyone can write an article or a post but you really want to pay attention to the actual information inside the articles.
I found two decent articles (as an example) about a Holley Tri-Power System (offered for the SB Chebby engines).
Each writer took a different approach on how he wrote the article.
One article used a dyno test and the second article provided information. So you would might assume that the Dyno Article was
a better article. I will provide the links to the articles and let you read them vs go over every picture etc.
Magazine Dyno Tri-Power Article:
http://www.hotrod.com/articles/testi...-power-system/
Web Tri-Power Article:
https://www.racingjunk.com/news/2015...-power-part-1/
(There are 4 parts and 4 links easy to use).
So the assignment for the day:
1) Two Articles by different writers on the same basic subject.
2) Both writers took pictures of the parts.
In the 1st article the carbs were the basic shiny silver Holley stuff from Summit/Holley.
In the second article the carbs had the Dichromate finish.
In both cases, some basic carb math was done to come up with a cfm for the 3 carbs.
So read thru both articles and judge who you think you should pay attention to when discussing carb information. Enjoy.
I will add my comments later
Tom V.
  #116
Old 12-21-2017, 06:16 PM
Tom Vaught's Avatar
Boost Engineer
I will let you people think about this one until tomorrow and then go thru the articles.
Tom V.
  #117
Old 12-22-2017, 02:18 AM
4zpeed's Avatar
Tom V
I've seen your BG intake and carbs, very nice indeed, but I thought you may be toying with a new project in your retirement.
BTW that Ford 6V open plenum intake looks like it would perform very well.
I'd love to build a Holley Tri Power setup but with the EFI's and other systems out there I doubt a economical post 66 intake will ever materialize.
Thanks for the eye candy,
Frank
  #118
Old 12-22-2017, 03:37 AM
4zpeed's Avatar
The Racing Junk article is by far the most informative and in depth, also gives a simple formula to convert a 1.5" Hg depression test to a 3".
Great explanation on compatibility with common Holley parts, detailed breakdown of components with dimensions, descriptions, photos, "uber cool" way of presenting material but of course obviously and most important accuracy of information!
Now I see how easily the accuracy as well as integrity of information can and does get compromised, then readily accepted by the novice Rodder such as myself.
Had it not been for my attendance at Tom V's Holley School Of Thumb I would have never given it a second thought an took it for gospel. Thank you Tom!
The article from Racing Junk exposes the improper comparison by Hot Rod's columnist between the 750 CFM Holley vs. the so called 1,025 (in actuality 725) CFM Tri Power set up.
As you have stated in this thread...
Racing Junk
A two-barrel carb is tested (for flow) at 3" Hg depression. On the other hand, four-barrel carburetors are flow rated at 1.5" Hg depression. These are the industry standards for carburetor airflow testing.
◾1025 divided by 1.414 equals 724.9 or, 725 CFM.
On the other hand you have this...
Hot Rod
If our math is right, that totals an overkill of 1,025 cfm,
◾325 + 350 + 350 = 1,025 CFM
To compound the misinformation further and misfortune to others...
Hot Rod
Don’t stress over achieving a 100 percent opening of all six barrels—with over 1,000 cfm on tap,
To reiterate, physics do not change, on the other hand, you can play with numbers...
As always Much Thanks
Frank
  #119
Old 12-22-2017, 08:32 AM
Tom Vaught's Avatar
Boost Engineer
Send the young man to the HEAD OF THE CLASS!
The HOT ROD GUY has been out there for many years, always assumed (bad technique) that he was a Car Guy and did a lot of his own work.
Maybe in the early days, perhaps. He is a very good writer and has probably written thousands of articles over the years. Maybe he actually does know how to do the calculations like the Racing Junk Writer but was having a "rushed day" and the magazine still had to go to press.
Hard to say, but the 1,025 cfm number is a Bragging Number (advertising for the Magazine) and a lot of people will be confused by a intake package
with a lot of reported cfm that made really low HP numbers on the dyno for that CFM number. Don't have to be a MATH GENIUS but should have some
knowledge of how the tests and parts should be rated in real life.
That is why I say, 20.4" Test pressure is a good number for carb ratings, (based on years of experience by very smart people who knew how the math
worked before, during, and after WW-II. Barry Grant did no one a favor with the "test the carb at 28" of water" BS except to sell over-rated CFM carbs to people.
One last comment on this math deal.
Rule of thumb is you need a 2 "Jet Size" change to see any real difference in performance. Up or down.
So BG used to take the Holley Calibrations (He measured orifices on a carb, I assume) and then changed a given orifice number by 1.
So now the Novice will say "the Calibration is not the same - see the numbers are different." The reality was he copied the Holley calibrations
and put them into his carbs because they were solid calibrations and a 1 number change did nothing different to the performance of the vehicle.
So he was as good as the competition without doing any real Carb Engineering. Years later though he did pay people to try to copy the Ford Inline
Carb made by Autolite (not Holley) and the removable sleeve carbs which were a knock-off of the Weber engineering designs.
So this piece is not a Bash of BG so much as "try to learn a bit of the math on how the carb was tested. Same deal with Cylinder Head Flow."
Good Job Frank.
Tom V.
  #120
Old 12-22-2017, 10:00 AM
Tom Vaught's Avatar
Boost Engineer
Going to talk just a bit about early Holley Dominators, today.
Just a quick overview, a story, and maybe more in depth later.
"The World Famous Holley Dominator® also made its debut in 1968, developed specifically for NASCAR® racing." (From the Holley Site).
(Some magazine articles say 1969) and the public could not get a carb from Holley until 1970.
Ford and the other manufacturers were told "No MORE Dual Quad Carb Set-ups in Racing", so the Holley 3-BBL and the
Tri-Power Carb Set-ups were moved to the front of the line. NASCAR was also (I am told) was worried about vehicle speeds.
So Ford went the other way and commissioned Holley Carburetor in the Mid 60s to come up with a LARGE SINGLE CARB for NASCAR racing.
Ford continued to use multiple carbs in other forms of racing. So the first Dominators were created. There were two versions:
A Individual Runner Version of the carb was used on Trans Am engines and was R6214-AAA
(Doug Nash Dual Quad manifold (Pontiac) was designed to use two of those IR carbs). The Nash upper plenum was added later to run 660 cfm carbs.
The Part Number for the first NASCAR Dominators was List Number R4575-AAA and were 1150 cfm carbs. They used conventional down leg boosters,
had a Choke, had a PCV Connection, and Ported Vacuum. Later versions of the carb were lower in CFM and were 1050 cfm carbs.
I have attached a pic of one carb. (the other pics would not copy to this thread).
One other comment: I had a pair of the Individual Runner TRANS AM carbs 6214-AAA
They had one hole machined slightly wrong (but it could be easily fixed. The carbs were to be scrapped.
So in the old Holley days you could get a slip that said you would not sue Holley and Holley would give the employee
the carb to play with. You could use it for teaching, decoration, or even run the thing on your vehicle.
So I took the two IR carbs with the very tall boosters and made two "Racing Lamps" out of the carbs.
4 plexiglas tinted tubes (one inserted into each booster.) Then a base at the top for a dual socket 60 watt bulbs and finally the shade.
The carbs sat on air cleaner stud extensions made from brass and used in commercial trucks.
Cool set-up. Open the primary blades and one bulb came on. Open the secondary blades and the second bulb came on.
(Switches installed in NASCAR Nose Bowls in the accelerator pump housings.)
Years later a guy was restoring a NASCAR FORD and heard that I had a couple of the IR NASCAR carbs so he called me,
I removed the lamp stuff, set them up so they would run correctly, and sent them to him for his museum car.
Tom V.
Name:	Le Mans Bowl Dominator1.jpg
