Old 01-14-2019, 02:17 PM
HWYSTR455's Avatar
A popular mod on the 2nd gen front sub is to weld the seams up, that strengthens them a lot.
Also, welding small triangle braces between the lower control arm mounts and the frame, but need to be careful, too big and it will get in the way of headers.
A member here sells some other items that help beef the sub up, one item I'm interested in is basically some thick washers that weld on the frame where the lower control arm bolts pass through. They tend to wobb out from load.
He makes a plate that braces the upper a-arm mount plate too.
  #102
Old 01-14-2019, 02:23 PM
HWYSTR455's Avatar
Here you go, it's member 'NOT A TA' :
https://lab-14.myshopify.com/collections/all
These chassis braces that mount under the front sway bar help too:
http://umiperformance.com/catalog/in...oducts_id=1026
  #103
Old 02-01-2019, 02:30 PM
72projectbird's Avatar
Picked up the subframe, control arms, knuckles, and dust shields from the blaster. They came out really nice.
Initially I was thinking powder coating them, but now I might just paint them myself. We're going to have a few warm days coming up, so I'll experiment with a few pieces and see how the come out.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #104
Old 02-01-2019, 03:27 PM
RAIVJUMB's Avatar
RAIVJUMB RAIVJUMB is offline
looks like it is coming along very nicely glad to see that and looking forward to seeing it around. Mark
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
74 SD T/A Admiralty Blue Auto
others that reside in the barn too
  #105
Old 02-01-2019, 07:31 PM
Thank you!
Hopefully it'll be running under its own power this spring. I was thinking about assembling it and driving it this summer, and tearing it back down for paint next winter. I still don't know if that's the exact plan, but it would be fun to drive it.
1987 Grand National
  #106
Old 02-01-2019, 07:38 PM
RAIVJUMB's Avatar
That is what I am doing with my sd
Sent from my E6782 using Tapatalk
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
  #107
Old 02-06-2019, 06:15 PM
I decided to paint the suspension parts rather than powder coating. The quotes I was getting were ridiculous, and with the metal as clean as it is, I can lay down paint and have it look just as good.
I started with the control arms. A few light coats of primer, followed by some semi gloss chassis black. They came out really nice. The pictures don't show it the finish too good.
1987 Grand National
  #108
Old 02-08-2019, 10:29 AM
JUDGE3 JUDGE3 is offline
Very nice and enjoy seeing it do it yourself.
powder coating it all would be a fortune. and why. the paint will look just as good for sure.
keep posting pics, I'm building a humble clone but love seeing what an original like yours looks like as it is dis-assembled and how you go about restoring it.
and what a find, sheeesh without going back and reading I think you paid 6 grand? pennies for a car like that.
  #109
Old 02-08-2019, 02:02 PM
Thank you!
Nothing wrong with a clone! My 71 is a clone built from second, third, and even fourth hand parts. It's the most fun car I've owned!
1987 Grand National
  #110
Old 02-08-2019, 05:17 PM
I got the frame painted up. It looks really nice, and I'm happy going with the paint route instead of powder coating. I also got the knuckles painted up and installed the dust shields on them.
1987 Grand National
  #111
Old 02-08-2019, 06:19 PM
weranc55's Avatar
weranc55 weranc55 is offline
Looks great
  #112
Old 02-14-2019, 09:18 PM
Originally Posted by weranc55 View Post
Looks great
Thank you! It's coming along. I really need to start tackling the rust repair that's left on the car. Hopefully within the next month or so I'll start on it.
I got all the bushings and ball joints in today, and hung them on the subframe. I'm still waiting on the springs and shocks. I still need to refinish the steering box, and get new tie rods.
1987 Grand National
  #113
Old 02-15-2019, 04:20 PM
Dropped by the machine shop today to check up on things. The engine is coming along nicely. We were able to save the original crank which is cool. The cylinder heads are next in line for the hot tank, so assembly should start soon.
1987 Grand National
  #114
Old 02-15-2019, 06:00 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Great progress!
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
  #115
Old 02-16-2019, 03:16 PM
455hota's Avatar
455hota 455hota is offline
Good progress!!
Please be careful with the front spring install into the subframe with it out of the car!! It did mine that way and it was an absolute bear even with two different style spring compressors!! Stay safe!!
...Steve T.
Pontiacs:
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Non Pontiacs:
1966 Lincoln Continental
1967 Ford Thunderbird
1979 Lincoln Continental (Towncar Option)
  #116
Old 02-16-2019, 04:07 PM
Originally Posted by 455hota View Post
Good progress!!
I plan on mounting the frame back on the car, and resting an engine in the rails before I attempt to mount the springs.
Springs are probably me least favorite part of reassembly.
1987 Grand National
  #117
Old 02-16-2019, 04:15 PM
necdb3's Avatar
necdb3 necdb3 is offline
Good progress!!
I did mine with the sub frame out. I pushed the spring into the lower arm like you normally would, then set it on my floor jack. If you chain the frame to the base of the floor jack, it doesn't allow the frame to lift.
  #118
Old 02-18-2019, 11:41 AM
shaker455's Avatar
shaker455 shaker455 is offline
Who did you guy's choose for a machine shop?
Carburetor building & modification services
Servicing the Pontiac community over 25 years
  #119
Old 02-21-2019, 09:28 PM
I fixed a hole in the firewall, right below the heater box. I took a pic of it completed, but I forgot to upload it. I ended up using the old door skins for minor sheet metal repairs. That's why it's white in one of the pics. lol
I also decided to replace the sides of the cowl. Initially I thought about just patching the lower halfs, but after tearing into it, it'll just be easier to replace the entire piece. Both sides are getting replaced.
If you look closely at the pic with the piece removed, you can look thru the kick panel opening and see the garage floor due to the lack of a floor pan.
I hope to get the entire firewall done by next weekend. Once that's completed, everything from the doors forward is now rust free!
1987 Grand National
  #120
Old 02-21-2019, 09:41 PM
unruhjonny's Avatar
That last picture is really cool to me, because it shows me how these cars were put together;
For instance, until I looked at that picture, I didn't realize that behind those cowl sides is the filler panels that have (on a non-A/C car) the vent!?
It makes sense, it just never occurred to me.
1970 Formula 400
