Old 01-18-2021, 08:11 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Originally Posted by AIR RAM View Post
Finally received my Turbo manifolds and I am more than impressed with the quality of the welds and overall look... The ceramic coatings look amazing as well!!!
The only unfortunate part of receiving these is the fact that It will be well over a year before they get used.... Just like any build, it all comes together in the end.
SPEED SAFE, NICK
What brand?
  #102
Old 07-23-2022, 12:33 AM
R 70 Judge's Avatar
I ordered a set of these today for my TA. Price went up a little to $849.95 but I still feel they are a great deal.
Getting excited! Now I need to pick turbos and wastegates
James
1970 Trans Am
  #103
Old 07-23-2022, 04:25 PM
charlie66's Avatar
let us know how it fits...
My Half AN Injun.....
The Following User Says Thank You to charlie66 For This Useful Post:
  #104
Old 07-25-2022, 03:05 PM
Scott65's Avatar
Scott65 Scott65 is offline
Anyone try these on a 64-67 abody? Very enticing...
'65 Tempest 467 3650# [email protected]
  #105
Old 08-06-2022, 04:44 PM
R 70 Judge's Avatar
Very nice!
ID:	595885   Click image for larger version
ID:	595886   Click image for larger version
ID:	595887   Click image for larger version
ID:	595888   Click image for larger version
James
1970 Trans Am
The Following User Says Thank You to R 70 Judge For This Useful Post:
  #106
Old 08-06-2022, 05:37 PM
25stevem's Avatar
25stevem 25stevem is offline
Flow wise to me they don’t look any better then factory log style types, in fact looking at them again the read most tube is more restricted.
I do stuff for reasons.
  #107
Old 08-06-2022, 07:02 PM
Tom Vaught's Avatar
Boost Engineer
1) They have a larger flow area vs factory type manifolds.
2) The exhaust PULSES are like marbles moving down a tube therefore the flow with a turbo thru those runners will just be restricted as soon as it enters the turbine portion of the Turbos anyway.
3) I have done a lot of actual dyno testing over the 40 years in my job and have to say I disagree with you on your post.
Cannot disagree that the flow area might be different vs individual runners but we are talking feeding turbos, not NA header Tech.
Tom V.
  #108
Old 08-06-2022, 07:48 PM
R 70 Judge's Avatar
They do make the logs in a higher flowing 3” version. They had a set on the shelf they offered to me when I ordered. I chose to stick with the 2 1/2” logs because I’ve seen them fit on a 2nd gen and I didn’t want to chance a hassle with clearance issues.
James
1970 Trans Am
  #109
Old 08-09-2022, 12:12 PM
charlie66's Avatar
3' would be over kill. If you ask me you made the right choice. I had the 2.5" log on mine and changed it to a 2 1/4' with no change in power .. I changed to the smaller size because i have a A body style car and there is hardly any room to fit anything bigger in there . I was actually crushing the log into the frame after awhile . lol
  #110
Old 08-09-2022, 05:02 PM
Tom Vaught's Avatar
Boost Engineer
Thanks Charlie66 for the info, for others. You are the guy who runs 40 psi of boost occasionally, Right?
And 30 psi quite often on your Pontiac 4 cylinder street racer? With EFI.
Tom V.
  #111
Old 08-09-2022, 06:39 PM
charlie66's Avatar
Tom V.
I haven't run 40-44 in awhile , But i do run 35 quit often.
At those higher psi levels o-rings are a must .
But i just wanted to let everyone know that 2.5" logs are more then enough ..
  #112
Old 08-27-2022, 12:00 AM
R 70 Judge's Avatar
I’d like to add power steering to my 70 TA. Has anyone run these turbo manifolds with the CVF Racing serpentine power steering/alternator combo?
Eyeballing it in pictures it seems like it may fit but I’d really like to know for sure before ordering everything.
https://www.cvfracing.com/black-pont...ic-water-pump/
James
1970 Trans Am
  #113
Old 08-27-2022, 08:20 AM
charlie66's Avatar
That looks like a nice kit. By the looks of it though you will probably have to reroute the drivers V-band to make it work .. Maybe come down and around the pump if there is room?
  #114
Old 10-28-2022, 02:38 PM
R 70 Judge's Avatar
Does anyone else have input on this? Possibly even with a stock power steering set up?
Power steering would be great but I have a feeling it may not be possible with these log manifolds without going to a mini/remote reservoir type PS deal.
James
1970 Trans Am
  #115
Old 10-28-2022, 04:47 PM
charlie66's Avatar
You can do this to the header and go under
  #116
Old 10-30-2022, 06:52 PM
Mo's Avatar
Mo Mo is offline
Looks like you would need a 90 degree bend down and the exhaust pipe may be against the back of the ps pump. Could try the link below, or have CVF make it happen.
https://www.speedwaymotors.com/Compl...gs,379729.html
Systems under stress fail catastrophically
The Following User Says Thank You to Mo For This Useful Post:
  #117
Old 10-30-2022, 08:30 PM
R 70 Judge's Avatar
I’m liking the pricing of that kit way more than the others I’ve been looking at. I can probably have an adapter bracket fabricated to use that power steering set-up with turbo manifolds.
Does anyone have a power steering box and pitman arm they want to sell?
James
1970 Trans Am
  #118
Old 01-07-2024, 12:24 AM
ID67goat's Avatar
ID67goat ID67goat is offline
R 70 Judge were you ever able to put these turbo manifolds to use?
I was curious to see if anyone has some feedback on how these fit in a stock chassis and if there is interference with accessories etc.
  #119
Old 01-09-2024, 01:55 AM
R 70 Judge's Avatar
I haven’t test fit them but we “eyeballed it” when my car was in the shop for upgrades. It appears they will interfere with the power steering pump if it’s in the stock location. In an effort to make my car more driver fiendly I added a remote power steering system and moved the pump up out of the way so it would clear a turbo pipe coming forward off the manifold. I also added a hydraboost brake upgrade and Aerospace discs in the front that match the rear. My plan is to eventually do a 88-94mm single turbo on the passenger side. My engine is in the stock location btw.
I have a few pictures of the remote pump setup. As you can see there’s ample room for routing piping with how it’s set up. It may be a while before I do the turbo conversion. I’d like to add a Tremec Magnum 6 speed first and that’s a pricey upgrade. My TA was originally a M21 4 speed so I’d like to get a stick back in it.
ID:	626275   Click image for larger version
ID:	626276   Click image for larger version
ID:	626277   Click image for larger version
ID:	626278   Click image for larger version
James
1970 Trans Am
  #120
Old 02-14-2024, 05:05 PM
ErikW's Avatar
ErikW ErikW is offline
That looks killer. Nice work! FYI the Stainless Headers 2.5" logs are working great on the Boosted Bandit with 78mm T4 turbos. We just ran a personal best of 8.22 @ 167 mph at Sick Week in Florida. That's at 3550lbs race weight. The back pressure readings are still below the boost pressure (about 19psi at 23 lbs of boost) almost one to one. Very satisfied with them. No need for the larger 3" logs unless you are going to run a massive turbo on it. The 88mm would probably be a nice choice.
1964 GTO
9.76 @ 137mph
2009 G8 GT
The Following 2 Users Say Thank You to ErikW For This Useful Post:
