Old 02-18-2022, 09:46 PM
GTOGEORGE's Avatar
Originally Posted by opeliac View Post
George, what is the deal on the 2000 series head studs that you are talking about?
I found me a way to get a set of special ARP2000 1/2” head studs that would work on my Hp heads.
GTO George
  #102
Old 02-18-2022, 10:40 PM
GTOGEORGE's Avatar
Picture of the ARP2000 head stud
GTO George
ID:	584470   Click image for larger version
  #103
Old 02-18-2022, 11:26 PM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
George, are these the fasteners that can be affected from the oils on your hands? Some ARP fasteners you need to wear gloves when handling them.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #104
Old 02-19-2022, 01:40 AM
Dragncar Dragncar is offline
You do not have to use gloves with ARP 2000 rods bolts on Molnar rods.
But the 700$ rod bolts for Crower billet rods require gloves. Not sure what the name/number those 700$ bolts are.
  #105
Old 02-19-2022, 09:53 AM
PAUL K's Avatar
PAUL K PAUL K is offline
The L-19 bolts are the ones your supposed to use gloves with. Some builders brush ARP lube on their fingers instead.
Go fast, see Elvis!
  #106
Old 02-19-2022, 09:55 AM
PAUL K's Avatar
GTO George
Just curious George why don't you use the high quality studs your pals at KRE sell?
Go fast, see Elvis!
  #107
Old 02-19-2022, 10:34 AM
GTOGEORGE's Avatar
I didn’t know they had any, as far as I know they use ( at best) a 8740 9/16” stud.
Let me tell ya this ARP2000 from outfront mototsports are way better then ARP8740 studs!
GTO George
  #108
Old 02-19-2022, 10:57 AM
slowbird's Avatar
slowbird slowbird is offline
GTO George
Why doesn't KRE offer them as an upgrade option?
  #109
Old 02-19-2022, 12:01 PM
mgarblik mgarblik is offline
I bought them from Bob and Frank...I had planned on having Butler do the machine work, but when I called today, the guy on the phone said they've never done any...So, I called Tony earlier, and I think i'm gonna run it up to BES next week...
I would think BES could cut the groove with their Rottler F65 machine or similar. If you like to do everything yourself, I have a BHJ O-ring cutting tool and a Pontiac plate I could possibly send you with a deposit and you can cut them yourself. This is a hand operated tool, but accurate if your careful. +-.001". You would need to buy the correct size carbide insert to match the ring. But that's not expensive, Like $30-35.00. Let me know if you want to try that.
http://www.bhjproducts.com/bhj_conte...ooling/org.php
  #110
Old 02-19-2022, 12:19 PM
opeliac opeliac is offline
I'm thinking the same thing for Butler...It seems like they would be a great upgrade option.
  #111
Old 02-19-2022, 12:22 PM
Dang, thanks for the offer...I've never used one of those, but I was reading about others that do...I may take you up on that offer...
I am also wondering why they dont put any sort of receiver groove in the head...Tom V explained the basics of the rings, and how they work, but it just seems like they'd be even better with a few thou receiver groove.
  #112
Old 02-19-2022, 12:51 PM
73 TRANSAM 73 TRANSAM is offline
I have one of those on my turbo setup IA2. The ring will cut its own groove to the head. Thats how it seals the bore. So when you remove the heads, u need to get it milled .005 to make it flat again.
  #113
Old 02-19-2022, 01:09 PM
So yours is dry decked too? How much boost have you made?
  #114
Old 02-19-2022, 01:15 PM
Dry deck and reverse cool. I only had it to 15 psi on the dyno.
  #115
Old 02-19-2022, 02:12 PM
How did you do the reverse cool?
  #116
Old 02-19-2022, 02:41 PM
I got a billet timing cover that I bought from a PY member and used a SBC nascar water pump and reverse cooled it. Not sure if it was actually better but I did it anyways.
  #117
Old 02-19-2022, 02:54 PM
cfmcnc cfmcnc is offline
Just a note.When you eliminate the head gasket thickness you have to make an adjustment in the piston to head clearance.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
  #118
Old 02-19-2022, 04:16 PM
PAUL K's Avatar
GTO George
Just when George almost had me convinced KRE is as great as he claims.
Go fast, see Elvis!
  #119
Old 02-20-2022, 02:35 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
... The ring will cut its own groove to the head...
Really? Wouldn't there be a number of combustion chamber shapes in which that could not work? In my ignorance, I assumed that a matching groove was cut in the head.
  #120
Old 02-20-2022, 09:27 AM
Marty's ring, will cut into the head on its own. That is how it seals as the rings are not flat on one side. It is raised on the outer wall of the rings and that is responsible for sealing.
