EFI Tech All things EFI and making classics modern!
Old 11-25-2025, 08:29 AM
HWYSTR455's Avatar
I'd be interested about the fit and clearance, especially the height around the water neck area and TB mount flange.
A few pics would be great when you get a chance.
The Edelbrock one I have doesn't have any CFM specs, but it was designed for a standard LS 92mm TB. I'm pulling vacuum over around 4k RPM, and suspect the TB/elbow is the restriction.
Mine is a tight fit with the elbow I have now, not sure those bolts along the top of that elbow would clear the hood bracing on my A body. I had to shave off the top half of the TB mount flange to get it to work.
