Old 12-11-2022, 04:03 PM
ID67goat's Avatar
ID67goat ID67goat is offline
Originally Posted by Gach View Post
Exhaust valve are lower then intake valves. That not a good thing, that would mean different push rod lengths on exhaust vs intake. When you say pressed in plugs are you saying like pressed in freeze plugs. Any pictures thanks.
Yes, plugs like oil galley or freeze plugs. There are 4 total in each head, 2 on the ends of the head and 2 under the valve cover area.
Just measuring a couple heights on one head with straight edge and feeler gauges yielded about .045” on one valve and .035” on the other.
ID:	603371   Click image for larger version
ID:	603372   Click image for larger version
ID:	603373   Click image for larger version
  #102
Old 12-11-2022, 04:14 PM
Gach's Avatar
Gach Gach is offline
Judging from your picture it seems to be quite a difference in height. Yeah those are freeze plugs. If it was me I’d remove them drill tape them for screw in plugs, here’s why as that head expands and contract’s your taking a chance of them blowing out. Had it happen to a friend on a set of Winszler heads. Plus there’s no telling how much of a press fit.
Old 12-11-2022, 04:22 PM
Gach's Avatar
The difference in valve height just might affect push rod length. Can’t tell until you do a push rod length check. The taller intake valve push rod length may hit completely different on the exhaust valve. Meaning it’s to long for exhaust valve. Therefore affecting valve guides down the road. In others words push rod length for intake may end up in middle of top of the valve but the shorter exhaust valve may end up on end of the valve.
Old 12-11-2022, 04:34 PM
Gach's Avatar
The other thing I would check is the valve springs, it’s obvious exhaust valve is shorter. So might end up with more seat pressure on exhaust. That doesn’t worry me as much as checking all valve springs for repeatability. Only to finds them off 30-40 and as much as 50#’s of each other. I guessing because of the different install heigh. I mean all of this can be corrected, but it’s anyone guess on the cost.
I say that about the valve springs because I had a well-known Pontiac engine builder do a set of Ellerbrock heads for me. What we found was they were completely the wrong valve springs for cam I was running. I would’ve definitely ended up with Valve float.
Old 12-11-2022, 04:43 PM
Gach's Avatar
One real good thing is they have helicoil in were rocker studs go.
Old 12-11-2022, 05:38 PM
Gach's Avatar
Could also mean how they machine to seats depth, would explain difference in valve hight. Meaning not consistent
Old 12-15-2022, 01:53 AM
blueghoast's Avatar
Anybody have any info on the Wezler Stage II heads and they are a 12*
Valve angle?
Wonder if anyone is using them on the street.
Thanks GT
  #108
Old 12-16-2022, 10:18 PM
Mo's Avatar
Mo Mo is offline
Just saw some pics of their cnc ported heads on FB.
https://www.facebook.com/10002128070...ibextid=YOZbMF
Systems under stress fail catastrophically
The Following User Says Thank You to Mo For This Useful Post:
  #109
Old 12-16-2022, 10:24 PM
Mo's Avatar
Mo Mo is offline
Default Some pics
Some pics from the website
ID:	603677   Click image for larger version
ID:	603678   Click image for larger version
ID:	603679   Click image for larger version
  #110
Old 12-17-2022, 12:06 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Valve angle?
Thanks GT
Wenzler Series 2 heads can make good power in the right hands. They have a 14° valve inclination angle.
Go fast, see Elvis!
  #111
Old 12-23-2022, 02:07 AM
blueghoast's Avatar
Very nice CNC work here in these pictures.
Looks like they would flow pretty well too.
GT
  #112
Old 12-23-2022, 01:36 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Still waiting on mine.
Skip Fix
  #113
Old 12-23-2022, 05:27 PM
Dragncar Dragncar is offline
GT
It does not look like a lot of materiel was removed. You can still see as cast areas.
  #114
Old 12-23-2022, 06:46 PM
Skip Fix's Avatar
CNC batch supposed to be back from machining Tuesday.
Skip Fix
  #115
Old 12-23-2022, 07:57 PM
Murf Murf is offline
I think they were quoting 289 cfm when they first came out.
Murf
  #116
Old 12-23-2022, 08:45 PM
Gach's Avatar
Fully CNC machined from Speedmaster that we set up the springs, retainers and locks for your application. $2750 per set with free shipping! We are going to flow these ourselves so we have accurate readings but they look to have done it right so I'm expecting 320 or better.
That’s pretty good deal. Think I read they use Howard valve springs.
Old 12-24-2022, 03:12 PM
PAUL K's Avatar
This is our standard pushrod location CNC Edelbrock head so you folks have something for comparison.
ID:	604013   Click image for larger version
ID:	604014   Click image for larger version
Go fast, see Elvis!
  #118
Old 12-24-2022, 03:36 PM
slowbird's Avatar
slowbird slowbird is offline
Looks great imo
The Following User Says Thank You to slowbird For This Useful Post:
  #119
Old 12-24-2022, 07:36 PM
Skip Fix's Avatar
Looks nice Paul.
Skip Fix
  #120
Old 01-03-2023, 10:43 AM
X72GPX's Avatar
X72GPX X72GPX is offline
Send a message via AIM to X72GPX
Has anyone received the CNC heads?
