Old 05-06-2016, 07:58 PM
10second70GP's Avatar
10second70GP 10second70GP is offline
Very nice !
  #1182
Old 05-13-2016, 08:49 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
What are you 2K+ HP guys running for remote mount oil filtration systems?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1183
Old 05-14-2016, 12:03 AM
cgeise's Avatar
cgeise cgeise is offline
I used a Hamburg billet
  #1184
Old 05-14-2016, 09:51 AM
JSPONT's Avatar
JSPONT JSPONT is offline
There is not many 2000+h.p. guys out there, you might be on your own!!
  #1185
Old 05-14-2016, 10:12 AM
Elarson's Avatar
Elarson Elarson is offline
It's critical to get a low pressure drop filter setup. You're going to need lots of oil to your bearings and a restrictive filter forces more oil to go over the pump bypass.
I'd be inclined to use a dual spin-on filter setup with -10 minimum hoses. Make sure the filters have bypass valves in them. Use a Fram HP filter or similar that is designed for low restriction. You don't want a street filter that is designed to filter out the small micron particles.
System 1 filters are fairly restrictive.
The Boss Bird doesn't have a filter in the engine circuit at all.
Eric
  #1186
Old 05-15-2016, 02:59 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Elarson View Post
... System 1 filters are fairly restrictive...
I didn't know that. Any data available on how restrictive (pressure differential vs. flow volume)? I always used System-1 for the convenience of inspection. I think mine has a particle-size rating of 50 microns, so I assumed it would be considerably less restrictive than normal cartridge-style filters of 10 microns or less. Yeah, it has less area than a cartridge filter, but it's a decent amount of area, with its pleated-cylindrical stainless mesh design.
  #1187
Old 05-15-2016, 08:42 AM
lastson's Avatar
lastson lastson is offline
Not sure why it's taken me so long to follow your build over here, but I'm in for the ride and info now.. best of luck with everything
Sent from my SM-N910V using Tapatalk
  #1188
Old 05-15-2016, 10:01 AM
Elarson's Avatar
No data like that available....I wish...
I've been texting off and on with a guy who's having oiling trouble. He was using a System 1 filter and installed pressure transducers upstream and downstream. He decided that there was an unacceptably high pressure drop but didn't share the numbers. He runs 50 weight oil and a Melling pump. I assume that he was using the finer mesh element...but again I'm short on real data.
I've also heard from some local guys who run a pulling truck. They were trying to use one of those flat Oberg filters. It had a huge pressure drop and they threw it in the trash. As you know, the flat filters have a super small flow area...something like 1/5 the area of a pleated cylinder.
The Boss Bird has a System 1 filter on the return line to the tank. We liked the stainless filter because we don't have to worry about nitro breaking down the element. We use the coarse mesh element (with 70 weight oil). The primary oil feed into the engine is unfiltered. Maximum flow is the do-or-die of a nitro engine. And any junk in the oil is created by the engine so why not filter it before it goes into the tank instead of filtering it after the tank (before the engine feed).
Eric
  #1189
Old 05-15-2016, 10:38 AM
Tom Vaught's Avatar
Boost Engineer
The Boss Bird has a System 1 filter on the return line to the tank. We liked the stainless filter because we don't have to worry about nitro breaking down the element. We use the coarse mesh element (with 70 weight oil). The primary oil feed into the engine is unfiltered. Maximum flow is the do-or-die of a nitro engine. And any junk in the oil is created by the engine so why not filter it before it goes into the tank instead of filtering it after the tank (before the engine feed). Eric
That is the reason why on our Prototype Turbo Engine testing, Eric, we have the normal oil filter feeding the engine but we also have a secondary "screened" turbo filter before the Turbo Inlet Line. The screened filter has several hundred times the flow area of the inlet to the Turbo CHRA (Compressor Housing Rotating Assembly) so we do not have a pressure loss across the "Rock Catcher" filter.
When the engine is being run hard, no matter how clean the engine was when it was assembled for dyno testing you will still have material coming off the internals in the engine. Some of that material is large enough to restrict the flow passage in the CHRA and cause a very expensive turbocharger failure. So we try to save the turbo as much as we possibly can with the aux filter feed assy. So far we have never had a Turbo failure with that system installed. Crap does come off engines. Your return filter deal is a good method of catching the stuff that returns back to the tank for sure.
Tom V.
  #1190
Old 05-15-2016, 04:49 PM
jm455ho's Avatar
jm455ho jm455ho is offline
Anyone using K and P Engineering oil filter? They claim superior flow and filtration.
www.hobracing.com
  #1191
Old 05-15-2016, 05:49 PM
cgeise's Avatar
there is a small company In Spokane Wa. that has a billet piece that allows you to look at the screen thru some sight windows to see if your engine is shedding metal -- not cheap but looks good --
  #1192
Old 05-16-2016, 02:36 AM
Thanks Eric. I'll have to give some thought to filtering scavenged oil instead of the pressure side.
  #1193
Old 05-16-2016, 07:47 AM
LPI's Avatar
LPI LPI is offline
Default Ed's new RA V intake - rear facing TB
Ed has been very patient as his intake manifold has become a separate project within the scope of the larger picture...the rising up of the "Raven".
Have to give credit to Ed (and Mike at the chassis shop) for his patience, Don from DCI who makes a great casting, Your RA V heads and intake rock! Holley for providing the parts that we can use at a reasonable cost and Tom V for his insight, guidance and overall do it the "right way" attitude.
The cnc is making chips won't be long and another piece of the puzzle will be completed. This is a bolt on adapter to allow the Holley 102mm TB top to bolt to Don's intake base/plenum.
Holy cow Tom that's a dirt road...
www.luhnperformance.com
  #1194
Old 05-16-2016, 07:51 AM
LPI's Avatar
LPI LPI is offline
Default pic's might look better
Here are the actual pictures snapped out of the CAD file
Name:	Plenum top 1.jpg
ID:	428516   Click image for larger version
Name:	Plenum top 2.jpg
  #1195
Old 05-16-2016, 10:17 AM
dci dci is offline
Good thinking Mark. Making it a separate pieces instead of having to weld it makes it so much easier so anyone can purchase it and just bolt it on. Nice!!!!!
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #1196
Old 05-17-2016, 02:17 AM
Graham355's Avatar
Graham355 Graham355 is offline
I have been thinking about a similar design, but with a front mounted throttle body partially mounted on the lower casting and the rest (75%) mounted to a top plenum casting. I also thought about the possibility of extending the runners into the plenum with a bell mouth.
Just my ideas, I'm no expert but I can make stuff
  #1197
Old 05-18-2016, 05:48 PM
RAIV-Z's Avatar
Nice pics Mark, can't wait to get it all assembled and running
DCIRAVTTFMF!
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1198
Old 05-18-2016, 06:13 PM
69FIREBIRD76MM's Avatar
That top looks very similar to the Holley Ls1 intake manifold.
  #1199
Old 05-18-2016, 06:53 PM
Tom Vaught's Avatar
Boost Engineer
It should look the same, it is the same!
With the Luhn Performance Custom made "HALO" the LS Top bolts right on to that part and the "HALO" bolts onto the DCI RA-V Intake Manifold. Some creative design work there.
Tom V.
  #1200
Old 05-18-2016, 10:34 PM
lastson's Avatar
Is the company's name "Clearview" or something similar? They are a nice looking filter, but I don't know if they have any flow numbers on their site.
400 bucks is pretty pricey too
