Old 06-04-2014, 05:59 PM
george kujanski's Avatar
Ted.....my opinion is on a 8 bolt pump, the divider plate, the one with the large hole should "divide" the cavity into two spaces, half of the flow going to each bank. The other plate (the"internal housing", from the manual) is the one where the clearance from the int. housing to the vanes should be minimum.
George
The Following User Says Thank You to george kujanski For This Useful Post:
  #1262
Old 06-05-2014, 09:24 AM
George
Do you think it would be better to just raise the impeller to minimize the gap. How far is "too far"? I made a puller to raise the impeller and I think that may be the best way to go so that the plate matches the contour of the blades. Does the gap at the back of the impeller matter much? If this doesnt work out I would purchase another impeller from the Flying Dutchman. Thanks for all the help. ; )
  #1263
Old 06-05-2014, 10:00 AM
silverbullet07 silverbullet07 is offline
I just picked this one up. The impeller looks pretty good and is about even with the shaft.
  #1264
Old 06-05-2014, 10:17 AM
I guess thats a reman, from the looks of the pitted housing, but what brand? that does look like a good impeller. I think the one I have pis of is a old AC Delco reman I bought years ago. I may buy one just to get a good looking impeller and swap it into a good housing. ; )
  #1265
Old 06-05-2014, 10:24 AM
Not sure the brand. Here is the front.
  #1266
Old 06-05-2014, 10:33 AM
The way i see it, there are 2 variables in the design of the 8 bolt pump, the position of the impeller on the shaft and the impeller vane height. if the impeller vane height is OEM, then if the position on the shaft is correct to minimize the clearance of the vane to the internal housing, it will be at OEM specs.
In my opinion, the pressure at the impeller and behind it should be the same, regardless of the distance behind it (distance between the pump housing and the back of the impeller). More critical is the clearance from the vane edges to the internal housing, if that's too large, there will be recirculation around the impeller, reducing the suction from the radiator, and robbing flow form the cylinder banks.
Hence, position on the shaft to minimize clearance to the internal housing is the way to go, in my opinion.
George
  #1267
Old 06-05-2014, 11:23 AM
George
Thanks George. I have raised the impeller to about .025" clearance to the plate. I put the gasket on, then the 2 plates and made the measurement. The gasket really needs to be added into the measurement because that backs it out quite a bit (.035). So now I just need to clean up the front on the engine, paint it up and see what happens. ; )
  #1268
Old 06-05-2014, 12:04 PM
As I am mocking up the fit of the plates. On the right side where the plate matches up to the hole in the timing cover going into the block. The end of the "hole" is not nice and square. At the plate and the end of the hole there is somewhat of a gap there. I think I need to minimize that gap. I have not seen any post here adressing that. I took a section of small vaccuum hose, split it with a razor blade and attched it to the edge of the plate hole and made it so it seals that gap. I think if I didnt do that, there would be no point to all the progress we have made so far, minimizing the plate/impeller clearances. What say you? ; )
  #1269
Old 06-05-2014, 01:19 PM
Sounds like a nice idea.
On the later 11 bolt pump, Pontiac did away with the divider plate and instead used a closing plate that mated with two tubes in the timing cover to direct the flow. The mating surface of the tubes have a rubber seal to seal to the closing plate nicely. A better design, in my view.
george
  #1270
Old 06-05-2014, 03:02 PM
Yes, I believe the 11 bolt pump is a superior design, maybe thats why they changed it. I will know more next week after I get this Bird running. Thanks for all of your help, Ted. ; )
  #1271
Old 06-20-2014, 09:11 AM
67Twistytee's Avatar
67Twistytee 67Twistytee is offline
Guys
I'm having the now notorious heat creep on my '67 GTO. I drained the system and removed the pump and it's a stamped impeller. I ordered a Cardone from Rockauto and it showed up with the same stamped impeller. Napa says they can get me one from their warehouse (their in-house reman brand) and the stock photo looks like it's original cast impeller. Has anyone here used the Napa unit successfully? Did it come cast as original? Also looks like Autozone has a Valucraft reman that I can order. Same stock photo but I guess you never know what you're going to get.
Andy
North Carolina
1967 GTO SG over Parchment / mom original owner / sold in '78 / found 35 years later
  #1272
Old 06-20-2014, 09:18 AM
Also you can find several on ebay with the cast impeller if you need one.
  #1273
Old 06-20-2014, 11:50 AM
Old Goat 67's Avatar
Originally Posted by 67Twistytee View Post
Guys
Try to get one as close as this. NOS 67 water pump.
http://forums.maxperformanceinc.com/...d.php?t=752911
If not, ship it to this guy.
http://www.fdrbp.com/
This is what it looks like when you get it back. $90
  #1274
Old 06-20-2014, 12:22 PM
Thanks! Any secret to where you got the OEM unit? Does the Dutchman repair these with any core? I unfortunately no longer have the original core with cast impeller and the one on it was replaced in 2001.
Andy
North Carolina
  #1275
Old 06-20-2014, 12:54 PM
Hooch Hooch is offline
I got one from NAPA on Tuesday for $38.00 and it has the cast impeller same as the original one did. I had to bend the plate closer but it looks ok to me. You can also get one from summit that has more flow your call.
http://m.summitracing.com/parts/mil-16281
  #1276
Old 06-20-2014, 01:00 PM
Call the Dutchman, you'll be pleasantly surprised! He'll use your core most likely, but he is well versed on the Pontiac pumps, knows what the trick is to put a CORRECT impeller on it AND make sure the plates fit properly!
You'll be way better off waiting a week or so and you won't have to waste gas looking.
Oh, I have been searching for an NOS one in the box for about 12 years.
Charles
  #1277
Old 06-20-2014, 01:41 PM
Thanks Charles. I was hoping to get it done before a road trip I had planned next weekend. I'll see what the Napa one looks like in the am and if it's the same story I'll mail the one I have to the Dutchman.
On a related topic, I know these had a 190 T stat originally. The one in now is a 180 but needs replaced. Any benefit (or harm) going to a 160? I've read through many of the prior posts and didn't see a consensus. The summers are nasty and humid here and I wouldn't mind it opening earlier if it helps move water through the block.
Andy
North Carolina
  #1278
Old 06-20-2014, 01:52 PM
160° too cool, 180° best overall. 195° was factory for good heater output.
Charles
  #1279
Old 06-20-2014, 02:01 PM
Thanks again. It looks like they used sealer along with the paper gaskets last time. Is this necessary or am I good with just the gasket?
Andy
North Carolina
  #1280
Old 06-20-2014, 02:08 PM
Well, I always use a THIN coating of sealer to fill scratches.
