Old 12-15-2008, 12:03 PM
Super Duty D's Avatar
Super Duty D Super Duty D is offline
Thanks Brewster,
That item is on my watch list.........Guess I'll have to bid against everyone on this thread now who needs one!!! LOL!!
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
72 442 W-30 auto, post coupe Bamboo. 1 of 19 total.
90 300zx TT 5spd.
  #1262
Old 12-15-2008, 01:16 PM
Norwood's Avatar
Norwood Norwood is offline
Brew, SHHHHHHHHHHHHHH
  #1263
Old 12-15-2008, 04:36 PM
toomanybirds toomanybirds is offline
Before you guys get too excited about the EGR valve on ebay, you should know it is only truly correct for a 74 SD-455 manual trans car.
It is listed in the 1983 GM parts book for 73 SD-455, but this is a superceded part number. The original and correct EGR valve for 73 SD was a different number, I don't have it in front of me, but Brewster could look on any of his 73 SD cars for the correct 73 number.
So if anyone with a 74 SD-455 manual trans car is looking for a NOS EGR valve, this is the one. But again, it is not correct for a 73 SD.
It would not even look correct as the vacuum hose fitting points forward on the 74, but it points up and backward on the 73.
  #1264
Old 12-15-2008, 11:13 PM
takid455 takid455 is offline
Send a message via AIM to takid455
FIRE IN THE HOLE!!!!!!!!!!!!!!!!!!!!!!
WOOOOOOOOOOOO. 23 YEARS IN THE WAITING.
After the routine checking, priming, setting, and rechecks prior to starting an engine, combustion of air and fuel occurred. I do not have the new exhaust installed yet, so this was straight headers. Man what an awesome sound. I didn’t run the engine too long as I don’t have the radiator installed. When I installed a new engine, I always run it for a little without the cooling system installed incase the engine needs to be removed. Just enough to get a little heat built up and to check to see that everything appears to be working correctly or at least not to cause a concern. I must say that this HC-03 cam sounds nasty. I attempted to adjust the timing to at least hold an idle while keeping the revs up to prevent can failure, and this thing does not care for low rpms. I have the timing ball parked right now. I’ll play with it more once the cooling system is installed so I can bring the engine up to full temp. Initial oil pressure registered just above 80 psi on the stock gauge. I guess the SD pump does pump at a higher pressure. Then again my 400 w/ a melling DS45 pump does 60 psi on initial start then drops to 40 when hot. I have to tidy some things up, but for the most part, the engine is pretty much done. Over time, I’ll gather the ‘correct’ parts to replace the old looking (egr, zinc plated switches, rear carb vacuum tee, ect) and ‘incorrect’ appearing parts (plug wires, vacuum hoses, stickers, ect). I had a question where some of the wires went, but figured that out. The one connecter with a black and a tan wire goes to the A/C system which did not come on this car. I guess they used the same harness. I ran though the gears to see if the rest of the driveline had any issues. None so far. So, I will say another SD is up and running and soon to be terrorizing the streets and giving me thrills.
I would like to see if anybody has any pictures of 74 SD cars’ engine bays w/ the air cleaner removed so I can get so good views of the wiring, vacuum and clip layouts.
  #1265
Old 12-16-2008, 01:40 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Engine looks pretty good!
Vacuum hoses should be color coded
Fuel line should have insulation on it.
See pictures I posted for you in your other topic.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #1266
Old 12-16-2008, 03:31 PM
spb350 spb350 is offline
Default SD Starter and carb dates
I was wondering, I just bought some SD parts one of which I was told is a SD starter, (see pic)is the SD starter different (part number) or is it just the fact it has the heat sheild? how do you tell the date? Also what is the earliest approx build date for the 73 SD carbs, mid NOV end of Dec. etc etc. Thanks
73 Trans Am Red/White #'s match 4spd...... sold
69 Firebird 400 conv #'s match AT Blue wht/wht
06 Vette conv Red/Red/Blk
  #1267
Old 12-16-2008, 03:39 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
OE '73 SD starter would be an 1108495. OE '74 SD starter would be an 1108500.
I've forgotten the date code sequence though.
Regards,
"455HO" Lloyd
  #1268
Old 12-16-2008, 05:39 PM
Brewster's Avatar
Brewster Brewster is offline
Toomanybirds, is correct and the numbers are different then mine which are: MH 7040175
256 2
Good eye on the positioning of the vacuum line because they are opposite from each other. Bob, looks like a killer x-mas gift for Momma to get for you! I'd call her but I dont have her cell number???????????
Got to work together brothers
Takid455, Looking good, and keep us updated on progress. You have all winter up there since the roads are bad for you too!
  #1269
Old 12-16-2008, 08:26 PM
Lloyd, thanks for the info. I checked mine and it is 1108500 it also has a 3 A and a 6 8. Would one of those be the daye code? Thanks
  #1270
Old 12-17-2008, 01:07 AM
Default 493159 SD Piston?
I did a search for piston number 493159 and nothing comes up is this a correct SD piston? 73 0r 74? Thanks
  #1271
Old 12-17-2008, 01:25 AM
those are aftermarket pistons along with the glyptol coating (red). stock pistons are radiused on the top edge. you have the correct 2 valve relief pistons though.
  #1272
Old 12-18-2008, 10:37 AM
Default Cleaning SD carb
This carb is one of the parts I recently picked up. According to the original purchaser(1975) he said it has 8-10K miles on it. What is the best way to clean this without removing the original finish? Is the pump arm supposed to be green? does that get washed off if I use regular carb cleaner Thanks
ID:	151832   Click image for larger version
  #1273
Old 12-18-2008, 11:30 AM
Brewster's Avatar
Green is correct for it and the choke pull off arm. Aftermarket and/or replacements for the pull off are silver. Carb cleaner should not change anything since they are powder coated and not painted.
  #1274
Old 12-18-2008, 11:40 AM
Brewster's Avatar
Turbowner, sure has his reserve up on this item.
Wooooooooooooooooooooow, wonder what it is??????????????
ebay item number for the 74 manual EGR valve: 300274271678
Sure glad I dont need one of those
  #1275
Old 12-18-2008, 01:18 PM
SD73's Avatar
SD73 SD73 is offline
So Brew, What is the part and stamp number one of your original '73 Auto cars show for that same part?
  #1276
Old 12-18-2008, 02:44 PM
Brewster's Avatar
[QUOTE=Brewster;3508840]Toomanybirds, is correct and the numbers are different then mine which are: MH 7040175
256 2
Your talking EGR Valve right????????????????
Super Duty Motor with Nunzi heads on ebay::::
Item #
220330088579
  #1277
Old 12-18-2008, 02:49 PM
SD73's Avatar
[QUOTE=Brewster;3510576]
256 2
That's what I'm talking about. Thanky!
  #1278
Old 12-19-2008, 04:45 PM
Default Original SD carb factory markings?
I was just about to clean up this newly aquired 7043273 carb and I noticed some markings on the carb. Some look like they were done with a black sharpy and some with a paint stick. Here are some pics I thought you SD guys might want to see these just incase they come off. I am probably going to sell this carb at some point down the road do you think its more valuable with its original patina or cleaned up and rebuilt. Also is the power brake booster fitting at the back of the carb a SD specific part number? Thanks
ID:	151963   Click image for larger version
ID:	151964   Click image for larger version
ID:	151965   Click image for larger version
  #1279
Old 12-19-2008, 04:47 PM
  #1280
Old 12-19-2008, 05:21 PM
x-bird2 x-bird2 is offline
keep the fitting with the carb, as they're kind of hard to bcome by and the potential buyer would likely want it. the markings i don't think are from the factory, but strangely enough, the butterflies on mine are numbered the same way.
