nice find jdw and good project however you approach it. Good luck and don't forget to share your progress!
Gotta Luv some old Muscle.. 64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror 3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna Silvermist w/BlackVinyl Top http://s161.photobucket.com/albums/t201/dracowizard/65/ |
I just picked up an unmolested, but needs a lot of help, 64 Lemans 2 door ht for my 25 year old daughter. She has wanted her own collector car for a while. I'll post some pictures as soon as she takes them.
Man - new springs and that 1-inch spring spacer / lift kit make a big difference! Instead of wallowing down the road like a pig she now has some spring in her step! Oh and those new 3.55 gears are a big improvement over the old highway cruiser setup...
This hobby is fun when you make progress! Now if I can just get that 389 built and under the hood.... Before & After pics....
Mark Las Cruces NM ___________________________ Current Project: '67 Catalina Convertible 400 4-spd |
I love the '64's....if and when I'm ever stupid enough to buy another car, that'll be my next purchase...
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house... |
Never should have sold this. 65 tempest custom Wagon. 455, 350, 67 355 safe-T-trac. All original deluxe interior with 66 rally gauges. GTO hood and lemans grills. 15x7 RII wheels with 215-65-15 front and 255-70-15 rears.
Paint started out as Crystal Turquoise but I had to add 1/3 92 teal GM to get it to better match the interior. Went back east somewhere in 2003. Sorry about the bad scan.
72 GTO 400-M20 Lucy Blue 86 2+2 Black 09 G8 GT red 08 Torrent GXP (wife's) 09 G8 ST (UTE) black A pissed off fat house chimp on dope would be a lot more deadly. |
Far from finished, I caught the racing bug. Started off as a 468 with a 66 TriPower. Currently has a Torker II and a 180hp jetted Cheater plate. Best of 11.32 with a 3.23, 8.2 rear.
http://www.youtube.com/watch?v=XGf_pe66mOE http://www.youtube.com/watch?v=obtS3...eature=related |
Here is mine...just now getting on the road after 4 years of work. Today it has a YC 455 (462) with hydraulic roller, T700R4 with 2500 stall lockup converter, quick ratio steering box and 4 spoke Grant wood wheel, Griffin custom radiator, new GM wiring throughout, 3.25:1 Safe-T-Trac, Classic Air A/C system, killer stereo (for a convertible) with hidden iPod Nano (plays 2000 early rock songs), RAM AIR Restoration ceramic manifolds with 2/5" exhaust thru Dr. Gas X pipe and Xelerators, Global West suspension with disks up front and factory braces with boxed trailing arms in the rear with finned drums. Body is unrestored with lots of original parts. Wheels are AR Torque Thrust IIs, 16". Not being a GTO I felt free to modernize and upgrade the car rather than restore it. It drives great and goes like stink! It has been a fun... but very long, project.
Scotty |
Work in progress
For those that don't know, both the '64 & '65 GTOs were a LeMans with the GTO option. So, I think they should be included in here. They can't technically be excluded, because the are a LeMans!
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. [email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Here is my 1964 LeMans HO I just purchased. This is my first Pontiac. It is all stock. I am planning to update a few things but keep it mostly original. Thanks Eric
that's tight
Very tight indeed...
I see alot of split bench seats in these cars, im looking to recover mine, does anyone make em?
20 years ago I took a 2 door post lemans that was owned by Catholic church of Seattle and i cloned it when you could get GTO parts cheap! Factory black car with red buckets and radio delete. I did hood, core support, stab. bar front rear, quick ratio box, kybs, emblems, 4 speed, tilt, 64 wood wheel, 64 round bar, 64 tach, alum. dash insert, map light, remote mirror, 3.23 posi, pwr steering with quick ratio box, power brakes,splitters.I took a 455 and put dished pistons then ran everything on the top end to 64 gto, you name it, every hose line and bracket etc. Only stuff not correct are some bolt heads, timing cover, dip stick, 67 ho exhaust. SD performance ported the heads 245 cfm 65 tripower cam, quiet exhaust. Later I added 17 inch Cragars style wheels with bfg drag radials only because traction was not there period. I went thru great pains to to make look stock wi
Just surfing through,when I came to your car. Great Job! Rich
![]() If everything seems under control,your just not going fast enough. Mario Andretti ________________________________________ May God have mercy upon my enemies, because I Won't. General George Patton |
Here's mine
