Old 05-02-2008, 12:09 AM
Ron H's Avatar
Ron H Ron H is offline
There is no gain from any stand point. Except maybe, any advertising is good advertising even if it's bad?
68 Firebird
Are you running with the wind or breaking it?
Old 05-02-2008, 12:42 AM
Pontirag Pontirag is offline
So polar pontiac, when you say you will buy a engine block from Kaufmans does that mean that you would be willing to buy one of the defective blocks held by other and made by Kaufmans. Same block same quality. You by one made by them or just by one from them. Either put your foot or your money where your mouth is.
Old 05-02-2008, 01:25 AM
440GP69's Avatar
440GP69 440GP69 is offline
isn't aluminum hardness checked different than iron?
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 05-02-2008, 09:19 AM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
I would buy a MR1 block from them one that fits my needs.My foot I would plant in your ass.
Old 05-02-2008, 10:13 AM
BILL BOWMAN1's Avatar
You really didn't answer the question. Would you buy one of the old defective blocks?
Old 05-02-2008, 10:54 AM
I tried too but was refused.yes I would.
Old 05-02-2008, 11:09 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Maybe the fact they wouldn't sell them should make a point guys!!
Skip Fix
Old 05-02-2008, 11:48 AM
punisher#1's Avatar
punisher#1 punisher#1 is offline
i nominate this guy for the first annual KRE "LEMMING OF THE YEAR" award.
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension.
5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos
Old 05-02-2008, 10:35 AM
Skip Fix's Avatar
Chris I wonder why aluminum rockers have a larger body that steel ones?? Maybe check the Brinell on them
Not an aluminum block expert but I believe most have thicker webbings and walls than their steel counterparts. Sleeve holes machined after casting and thicker walls the casting shift not as big a deal as pistons not riding on the actual wall(unless you count the old silicon impregnated Vega motors or original 430 Can Am blocks-remember those,or you guys too young?). If it were just that easy as casting the same cores in aluminum I'd bet the Pontiac one Butler has would have been out alot earlier. I know the aluminum 409 block a guy is working on is alot bulkier, he has the first batch cast last month.
Polar- "I got 8' of chrome moly you can buy too, or was that 6'". Seriously I hope the new ones don't have issues for anyone, but I doubt there would have been a recall if even they thought there wasn't that possibility, but I'd bet you could get an old one for a deal!
Skip Fix
Old 05-04-2008, 10:26 PM
I apologize to any board members. The heat of the debate and the trashing of the Kaufmans got the best of me. I am finished with this thread, and I am truly sorry. Thank you.
Old 05-02-2008, 07:57 AM
Brian Baker's Avatar
Testing aluminum is different than testing iron/steel:
http://www.instron.us/wa/application...gle.com/search
Because the test parameters are different for each metal, for instance, a Brinell reading of say, 100 on a cast iron piece, is not the same as a Brinell of 100 on a cast aluminum piece.
Old 05-03-2008, 06:21 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
http://www.instron.us/wa/application...gle.com/search...
Thanks for pointing that out, and for the link.
Old 05-02-2008, 03:04 PM
Tom Vaught's Avatar
Boost Engineer
"Polar, Don't get so mad. Tom vaught tried to get everyone to drop it 2 pages ago and its still going and getting nasty. I guess like Tom said, lets drop it and let the lawyers figure it out."
I see we are still calling each other names while KRE and DI sit back and watch people humor themselves with idle threats over the computers.
Aluminum vs Steel.
Quoting one number reminds me of the old days when I was just out of high school, really stupid, and figured my Pontiac boys with their 428 engines were better than the 427 Chebby and 427 Ford guys with their engines due to that one MAGIC CUBIC INCH. One little number does not tell the whole story, by any means.
Tom V.
Old 05-02-2008, 03:23 PM
Chris Roach's Avatar
Chris Roach Chris Roach is offline
Originally Posted by Tom Vaught
Aluminum vs Steel.
Tom V.
I certainly hope you aren't insinuating that I am stupid by referring to the brinell hardness of an aluminum DRCE block.
1969 GTO Judge Ram Air III
1968 Catalina "Darkside" Vert!
Old 05-02-2008, 05:48 PM
Tom Vaught's Avatar
Boost Engineer
"I certainly hope you aren't insinuating that I am stupid by referring to the brinell hardness of an aluminum DRCE block."
My quote:
"I was just out of high school, really stupid"
Where did I say ANYTHING about you?
I made a GENERAL comment that people with a little information can be dangerous using myself as the example (in high school).
Tom V.
Old 05-02-2008, 06:17 PM
Ron's Avatar
Ron Ron is offline
Butter never wins.....it gets eaten.
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 05-02-2008, 06:33 PM
Tom Vaught's Avatar
Boost Engineer
Agree Ron, you don't have to be a Rocket Scientist to have enough common sense to know that Butter and Aluminum are softer than "Most" cast iron and steel. Apparently there are exceptions.
Tom V.
Old 05-02-2008, 11:24 PM
Well, since I'm the only one who brought up aluminum, its apparent you are referring to me.
Sorry my questions don't stack up to your technical expertise.
My father, who was a very successful business owner told me once. "The only stupid question is the question that was never asked"
Have a nice day!
Old 05-03-2008, 12:25 AM
455Dave's Avatar
455Dave 455Dave is offline
Tom V.
Tom, I really hate metallurgy because it's so complex I won't teach it any more because I lose my students in about the first 15 minutes. Instead of posting up a bunch of empirical data I thought this time I would just post a short section from the the Atlas Foundry site:
"A conversion chart between Rockwell and Brinell hardness values can be used accurately for steel but deviations from this relation for steel occur with gray irons. This deviation increases with high carbon equivalent irons. The amount of flake graphite present influences the two tests differently. This is evident from a comparison of microhardness test results on the matrix of gray irons compared to standard Rockwell C values on the same irons. The microhardness impressions do not include the graphite flakes that are present under the Rockwell C hardness indenter."
"For this reason the hardness of gray iron should NOT (my emphasis) be compared directly to the hardness of other metals for an indication of properties such as machinability or wear resistance. However, some effective hardness conversions can be made between selective types of hardnesses."
An M16 or AR15 is made of 6061-T6 aluminum, over 10,000 rounds in my 10.5" shorty and it functions fine but it Brinell tests at 80.
Lot's of interesting stuff here:
http://www.atlasfdry.com/grayiron-hardness.htm
The bottom line never changes, Crappy QA = crappy product
Old 05-03-2008, 09:27 AM
Skip Fix's Avatar
There you go Chris good site. Now let's see what kind of cast iron did those blocks test out as and what were they advertised as?? "Soft","Ordinary" or "Higher Strength" Seems like the 30,000-35,000 number was thrown around.
http://www.atlasfdry.com/grayiron-classes.htm
But Dave my AR's recievers just have a bolt carrier sliding in them not pullling on them like cranks in mains do or keeping heads from lifting like decks are supposed to do. It does look though that you can use the Brinell to extrapolate which tensile strength iron is there.
Skip Fix
