Old 05-11-2009, 10:57 PM
BILTIT's Avatar
BILTIT BILTIT is offline
I am glad i have not started cutting yet but i am pretty bummed. I have half the parts and the car tore apart but oh well. I will put in the QA-1's up front and try out the 4000 conti.
I guess i just need to get the A/F dialed in this year and use some nitrous.
Thanks for the encouragement.
I am frustrated that i cannot drive it, all the other cars are out and i know some are looking for me to try and take the title, lol.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
  #122
Old 05-12-2009, 12:46 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
Originally Posted by BILTIT View Post
Well, some turn of events. I may have to cancel the minitub for this season. It would not take much to put the driveline back in until a later date. I am seriously considering this option.
This sucks but other priorities need to come first.
Sometimes you do what you gotta do.
There will be time to finish at a later date, a car is nothing to stress yourself financially or emotionally about, its suppose to do the exact opposite.
  #123
Old 05-12-2009, 01:03 PM
BILTIT's Avatar
I agree, sometimes my brain does not like to listen to reason though, lol.
Derek B.
  #124
Old 05-20-2009, 08:14 AM
BILTIT's Avatar
So its official, its going back together without the tubs.
I got the tranny with conti 4000 put in and the rearend is in aswell.
Hoping to have it runing for friday.
On a side note, i can fit my et streets if i move the shocks inboard and go to caltracs at my current height. I might do that this summer to test them out.
Derek B.
  #125
Old 05-21-2009, 05:52 PM
BILTIT's Avatar
Car is almost together. Pass. header install, exhaust hookups and oil and shes a go for start.
I am excited to try out this convertor.
Derek B.
  #126
Old 08-07-2009, 03:38 PM
BILTIT's Avatar
Ordered the caltracs and adj. shocks today. Once they are in then i can run my ET streets without the tubs.
Cutting it close though, go racing in two weeks. Hoping everything will be here in time so i can install it.
Derek B.
  #127
Old 08-07-2009, 09:19 PM
ponjohn's Avatar
ponjohn ponjohn is online now
Cool, what changes that allows you to run the other tires?
John
  #128
Old 08-07-2009, 09:25 PM
BILTIT's Avatar
Mostly the shock location, by moving them in board i have much more room. Also the traction bar shock mounts are in the way, the cal tracs will fix that too.
Derek B.
  #129
Old 08-10-2009, 04:25 PM
drobinson drobinson is offline
Thanks for all the info guys. I will be going through this shortly on my 73' as well. I plan on using DSE tubs. Hope both our cars turn out great.
Happy Modding!
08 Chevrolet Trailblazzer SS Some work done.
73 Pontiac Ventura (Under Construction)
  #130
Old 08-11-2009, 12:45 AM
BILTIT's Avatar
Just got my trailer back together and picked up my new tow vehicle. Needs a clutch so that is on the agenda this week.
ID:	177495   Click image for larger version
ID:	177496   Click image for larger version
ID:	177497   Click image for larger version
Derek B.
  #131
Old 08-11-2009, 12:47 AM
BILTIT's Avatar
Haha, just noticed the license plate, nice. Too bad i cannot keep it.
Derek B.
  #132
Old 08-12-2009, 11:54 AM
ponjohn's Avatar
How'd the mud truck pull that?
  #133
Old 08-12-2009, 12:22 PM
BILTIT's Avatar
It pulls it fine other than my rear springs being worn out. I will be replacing them this winter i think.
The old 350 works pretty hard on hills, my mileage sucks wether i am pulling or not but it did the job for a few years. Time for something better. The '93 still only has a 350 but its EFI and should have as much if not more power than the replacement 350 in the '80 plus better drivability.
I am not sure about gearing in the '93 yet, have to check it out. It does have the OD 5 speed which will be nice when i am running to pick up an engine or something.
The '80 has 4.56 gears and 36'' tires, i usually pull with the stock 31'' tires for the extra effective gearing (and rpms, lol).
Now i am free to spice up the '80 with a poncho and more lift/tire.
Derek B.
  #134
Old 08-18-2009, 01:45 AM
BILTIT's Avatar
Got the QA-1's installed in the front tonight. Waiting to pickup some wheel seals for the new drilled/slotted rotors and then the ceramic pads. Hope this will help some weight transfer and braking. No caltracs or rear shocks yet, almost out of time to have them in by thursday night.
Derek B.
  #135
Old 08-18-2009, 07:00 PM
ponjohn's Avatar
Is it a track rental on Thursday?
What changes in total have you made since last outing?
  #136
Old 08-18-2009, 09:04 PM
BILTIT's Avatar
No, want to be loaded up thursday night so i can head out at noon friday from work.
Differences are 3800 convertor VS 3200, adj. QA-1's in front, drilled/slotted rotors and ceramic pads.
My caltracs and ranchos are in town, will get them from the depot tomorrow but not sure i will have time to fab up the shock mounts to install everything, might call in sick thursday lol..
Derek B.
  #137
Old 08-19-2009, 11:54 AM
BILTIT's Avatar
Took it for a drive lastnight, QA1's feel good. I had to crank the ride height up a fair bit due to the 350# springs and my tall tires i think. New brakes feel good and firm.
Caltracs and shocks will be in my hands today some time. Took today off work and maybe tomorrow to try and get everything together in time.
Derek B.
  #138
Old 08-19-2009, 02:19 PM
BILTIT's Avatar
Received my caltracs and shocks, nice stuff! Getting some shock tabs made this afternoon and picking up new u-bolts. Hoping to have this stuff in late tonight.
Talked to travis and got a good starting point for tuning and will see how it works out friday night.
Derek B.
  #139
Old 08-19-2009, 03:30 PM
ponjohn's Avatar
That's interesting, I installed them with zero preload. Made sure everything was at zero "lash", works great. Comes out straight, no issues. Made a HUGE improvement in consistency.
  #140
Old 08-19-2009, 04:51 PM
BILTIT's Avatar
Awesome, i do need some consistency. Spent most of the day running around getting parts, etc. The shock mounts will be made up tomorrow at the earliest maybe not in time for me but i hope. Bare minimum i will get the caltracs in and possibly fab some rudimentry shock mounts for the weekend or use the stock location and old tires.
About to start the disassembly of the trac bars, etc. and hope to have the cal tracs all bolted in later tonight.
Tried finding some clips for my window trim and no one in town has them, bummer.
Anyways, let the work begin!
Derek B.
