Old 12-12-2011, 10:31 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by Travis Q View Post
We are cam driven not belt driven. Made the switch last winter when we upgraded fuel pumps and installed the alternator.
TQ
Was not aware of that change Travis. was looking at other things like the extra bolts in the head. If it had been a snake i would have gotten bit, lol.
That being said, normally cam drive set-ups use a timing cover with the cam drive/ pump mounted on that part and a drive shaft from the cam driving the fuel pump.
If you had a BOP timing belt deal, and I do not remember if you had one or still do, did you make a stand off bracket to hold the pump and then still use the drive shaft to turn the pump?
Tom Vaught
  #122
Old 12-13-2011, 06:25 PM
Travis Q Travis Q is offline
Me, a 1974 model Bridgeport mill, a 1942 model South bend lathe, a little bit of scrap material, and a couple hours later.....
TQ
  #123
Old 12-13-2011, 07:17 PM
taff2's Avatar
taff2 taff2 is offline
I wish my little bits of scrap material ended up looking like that!
  #124
Old 12-13-2011, 08:06 PM
marks73ta's Avatar
marks73ta marks73ta is offline
Yea, mine end up looking like crappier pieces of crap. That looks nice. Simple but affective. Having a mill and lathe would help. But could be done with lesser tools and time. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
  #125
Old 12-13-2011, 08:28 PM
Tom Vaught's Avatar
Boost Engineer
TQ
I have seen your fabrication skills in the past on that F1R Procharger Bird FEAD System.
(FEAD = Front End Accessory Drive. And obviously some serious CAD Skills too.
I assume you fixed the "distributor movement issue" previous to the Fuel Pump Mounting exercise.
Very Nice work there Travis.
Tom Vaught
  #126
Old 12-13-2011, 10:01 PM
rodneybutler's Avatar
rodneybutler rodneybutler is offline
Another fuel pump pic with quick release V band. TQ got skills!
  #127
Old 12-14-2011, 04:05 PM
cgeise's Avatar
cgeise cgeise is offline
and the sensor on the cam is for cam sync for the EFI ??
  #128
Old 12-16-2011, 08:15 PM
Yes. Had to put it somewhere.
  #129
Old 12-17-2011, 05:36 PM
cgeise's Avatar
So I am guessing that the BOP belt drive dist. has no pick up in it ????
  #130
Old 12-17-2011, 06:33 PM
Correct again.
  #131
Old 01-09-2012, 07:44 PM
67'7F6'Bird's Avatar
I hear the Plasma Cutter warming up. Have you confirmed when the 1969 Firebird is going to the chassis shop?
  #132
Old 01-09-2012, 10:59 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Yes.
  #133
Old 01-12-2012, 10:58 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Did the 535 strap on a dyno yet? Looking forward to the results...natural or boosted.
  #134
Old 01-13-2012, 12:58 AM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
We just decided this week on turbo orientation...I think. So now we fabricate tubes. I am going to have Joe at The Indy Cartel tack weld it and send pictures to Ed. When we get the engine from Tony, then Casey is going to plumb and wire the EFI system for Ed.
Tony isnt crazy about reefing up this dude on the dyno. He only wants to pull it to maybe 1400HP. I think we can get him to pull it higher. The dyno is max about 1800HP. The other thing is to see what HP it makes on pump gas.
We will see what Ed wants to do. He is entertaining the idea of having it dynoed at Steve Morris' place. Tony is good with Morris' expertise on Turbo and EFI engines.
Tom, Rodney what kind of longevity do you guys see with 2000Hp plus Pontiac engines? Nearly 300Hp per cylinder has got to be a lot of free energy to maintain.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
www.ChemicalManagementIndiana.com
317-260-3486
  #135
Old 01-13-2012, 02:06 PM
cgeise's Avatar
As it all depends on the parts and the tune -- In my case turbos have been very easy on parts - I just pulled a few caps to check bearings after last years - and couldnt be happer - like new.
  #136
Old 01-13-2012, 07:44 PM
RAIV-Z's Avatar
How many 2000+ HP runs last year?
  #137
Old 01-13-2012, 07:52 PM
RAIV-Z's Avatar
Default The 69 bird is going south for the winter
Well, not that far south.
ID:	270638   Click image for larger version
ID:	270639   Click image for larger version
ID:	270640   Click image for larger version
  #138
Old 01-13-2012, 08:20 PM
moparcolt's Avatar
moparcolt moparcolt is offline
That motor sure would look good in my 67 firebird! It's for sale!
Tubbed, 4link, 12pt cage!
I think it would still need some updating to handle 2200HP though
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
  #139
Old 01-13-2012, 08:35 PM
RAIV-Z's Avatar
Nice looking car, what does it have for a cert and is the cage moly? My 69 already has an expired 7.5 cert.
Are you selling it running or rolling?
  #140
Old 01-13-2012, 08:40 PM
moparcolt's Avatar
selling it either way, but it is not certified, it would need updating. it is an older cage and is probably mild steel.
It is not really a race car. it was going to be before I bought it but I put it back on the street. It has alot of good parts and was well done but 2200 HP is A LOT!!!
I think most of the cage would need redone. you would have to see it.
http://s248.photobucket.com/albums/g...colt/firebird/
ID:	270644   Click image for larger version
ID:	270645   Click image for larger version
Chris Collier
