Old 01-22-2014, 11:53 PM
kaptinkafeen kaptinkafeen is offline
I have to say, that I totally appreciate all the photo's. I'm putting together my father's 72 TA, and the under hood wiring is a mess. His car is also a K65 unitized dist car, no a/c though.
I have been saving some of the pics (actually I've been saving lot's of photo's from not only this thread, but others too) so that I can reference them when while looking at the shop manual schematics I have.
I like the fact that you're actually giving your files a name instead of a generic number - nice!
Thanks from my end. Keep them coming. I'm needing all the help I can get.
-Andrew
-probability is fundamental, uncertainty is inevitable
[B]Looking for a '71 casting rochester 7042270 - have a '72 dated 7042270 that can trade?
The Following User Says Thank You to kaptinkafeen For This Useful Post:
  #122
Old 01-23-2014, 12:04 AM
transam1972 transam1972 is offline
Default PHOTOS
WOW!!!..Andrew, thankyou!..your post means that it has been worthwhile...if you have a specific item you need photographed just let me know and I will photo document it...I myself have always appreciated the posted photos and I look forward to requesting some pics myself...I am missing a rear alternator bracket and need someone to photo document the bracket and hardware....a year and a half not knowing how to post pix so that is why they are turning up...and thanks again!!!
  #123
Old 01-23-2014, 06:43 AM
Here's what's taking up my time lol....
A BIG thanks to all PY members for helping and contributing. Things would be a lot harder for me without the knowledge and contributionS of you guys
-Andrew
The Following 2 Users Say Thank You to kaptinkafeen For This Useful Post:
  #124
Old 01-23-2014, 05:56 PM
Default 1972 TRANS AMS
Name:	1972 CORRECT WIRE SHIELDING.jpg
ID:	350549 NICE!!! that is exactly what I want...Cameo white & blue stripe Honeycombs Black deluxe and loaded!!!....here are more detail photos
Name:	M & H ELECTRIC REPOP ENGINE HARNESS.jpg
Name:	HARNESS CLIP MOUNT   M-40.jpg
Name:	80 AMP BRACKET DETAIL.jpg
Name:	80 AMP MOUNT DETAIL.jpg
  #125
Old 01-23-2014, 06:02 PM
Default 1972 455 H.O.
Name:	80 AMP ALTERNATOR  HARNESS CONNECTION DETAIL.jpg
Name:	455 H.O. ONLY AC BRACKET.jpg
Name:	455 H.O. ONLY AIR CONDITION BRACKET DETAIL.jpg
Name:	1972 455 H.O. CHOKE INTAKE MOUNT AND AC BRACKET DETAIL.jpg
Name:	1972 455 H.O. front air cond. bracket with missing purge hose clip.jpg
  #126
Old 01-23-2014, 06:06 PM
Name:	1972 ONLY CHOKE MOUNT DETAIL.jpg
Name:	1972 ONLY 455 H.O. TEPERATURE SENSOR PASSENGER SIDE.jpg
Name:	1972 original 80 amp alternator    note missing rear support bracket.jpg
Name:	1972 TENSION PULLY AND HARDWARE.jpg
Name:	1972 ROCHESTER AUTO VACUM MODULATOR DETAIL.jpg
  #127
Old 01-23-2014, 06:11 PM
Default 455 High Output
Name:	ALTERNATOR MOUNTING DETAIL.jpg
Name:	1972 80 AMP TENSION PULLY.jpg
Name:	BATTERY CABLE INSTALLATION.jpg
Name:	CHARCOAL CANNISTER HOSE.jpg
  #128
Old 01-23-2014, 06:22 PM
Default 455 C.I.D.
Name:	WASHER MOTOR.jpg
Name:	UNIQUE CAP NUT    REPOP AVAILABLE.jpg
Name:	REPOP HEAD BOLT WITH NEG CABLE DETAIL.jpg
Name:	REPOP CARB CABLE COURTESY OF SD73 WHO TALKED ME OUT OF MY NOS REPLACEMENT.jpg
Name:	CHARCOAL CANNISTER LINE MOUNTING DETAIL.jpg
  #129
Old 01-23-2014, 06:29 PM
Name:	BRAKE BOOSTER.jpg
Name:	CHARCOAL TANK HOSE ROUTE.jpg
Name:	PASSENGER SIDE CHARCOAL CANNISTER PLUMBING.jpg
  #130
Old 01-23-2014, 06:37 PM
Default 455 H.O.
Name:	1972 DRIVER SIDE & CONSOLE DUCT FOR AIR CONDITIONING.jpg
Name:	1972 ORIGINAL PASSENGER DUCT   NOTE MOUNTING BRACKET   AVAILABLE AS REPOP.jpg
Name:	1972 UNDER DASH AIR CONDITION DUCTS.jpg
Name:	1972 PARKING LIGHT HARNESS.jpg
Name:	ORIGINAL AMBER BULB.jpg
  #131
Old 01-23-2014, 06:49 PM
Default TRANS AMERICAN
Name:	COOLING LINES   NOTE MOTOR MOUNT BOLT NOT SECURE.jpg
Name:	REPOP TRANSMISSION COOLING LINES TO REPOP DESSERT COOLER RADIATOR.jpg
Name:	FUEL PUMP    FUEL LINE HOSE RETAINING CLIP.jpg
The Following User Says Thank You to transam1972 For This Useful Post:
  #132
Old 01-23-2014, 07:05 PM
Default TRANS AM 455 H.O.
Name:	currant repop fuel pump  non AC delco.jpg
Name:	GM replacement fuel pump.jpg
Name:	REPOP FUEL LINE    PUMP TO CARB.jpg
Name:	FRONT AIR DAM MOUNTING HARDWARE.jpg
Name:	NOTE    AIR DAM HARDWARE THE SAME AS FAN SHROAD MOUNTING HARDWARE.jpg
  #133
Old 01-23-2014, 07:13 PM
Default FIREBIRD TRANS AM
Name:	FRONT BUMPER MOUNT DETAIL       NOTE  SNOW!!!!.jpg
Name:	FRONT BUMPER MOUNTING BOLT DETAIL.jpg
Name:	GM PURGE VALVE    2 STYLES AVAILABLE.jpg
Name:	GM CHROME MLDNG & SILL.jpg
  #134
Old 01-23-2014, 07:23 PM
Default Trans Am
Name:	repop radiator shim replacement detail.jpg
Name:	repop radiator support mounting hardware.jpg
Name:	SR CANNISTER.jpg
Name:	original & repop spoiler hardware.jpg
  #135
Old 01-23-2014, 07:56 PM
Default 1972 FIREBIRD TRANS AM
Name:	bushing install.jpg
Name:	bushing install 2.jpg
Name:	original ac condensor    wll be replaced.jpg
Name:	ORIGINAL 455 H.O.INTAKE MANIFOLD DETAIL.jpg
Name:	TENSION PULLY MOUNTING HARDWARE.jpg
  #136
Old 01-23-2014, 08:01 PM
Default TRANS AM
Name:	1st issue standard belt upper.jpg
Name:	1976 BATTERY CABLE SHIELD.jpg
Name:	GREASE IS THE WORD.jpg
Name:	upper belt      note metal trim mounting clip.jpg
  #137
Old 01-28-2014, 01:02 PM
Default HE WHO CRASHES AND WALKS AWAY, WILL LIVE TO CRASH ANOTHER DAY
Name:	The Crash.jpg
Name:	1999 MISUBISHI 3000 GT.jpg
Name:	MITSUBISHI 3000 GT 2.jpg
  #138
Old 01-28-2014, 01:05 PM
SD73's Avatar
SD73 SD73 is offline
That'll buff right out.
The Following User Says Thank You to SD73 For This Useful Post:
  #139
Old 01-29-2014, 06:53 PM
Default THE CRUNCH MOBILE
...oh and by the way,I was driving that car when an oversized DUMP TRUCK forced me into a series of concrete dividers,he slowed down so he could begin plowing me from my side till I broke loose and was able to plow into a guard rail....but I am alive and that's what counts..a senseless way to die in a car crash....he managed to flip his dumptruck and eject himself..after all it was his fault!!..I know maybe because I did own a Japanese iron..but I got a great deal in 03,only 71 k on it now...imagine if it was the TRANS AM...yet I have already destroyed a 76,again not my fault....if it were not for bad luck,Id have no luck at all...
  #140
Old 01-29-2014, 07:29 PM
SD73's Avatar
I'd say you have awesome luck if you tangled with a dump truck and lived to tell about it! And only McQ is allowed to total T/As so don't get any wild ideas there.
