#121
![]() Quote:
J.C. I "think" he was on a 315 DR on the 4.03 runs, he had back to back 4.03's at Light out. |
#122
![]() Quote:
GTO George |
#123
![]() Quote:
Do you happen to know what size turbos Justin is running? I believe that twin turbochargers are limited to 88mm each. Stan
#124
The latest Turbos sent to him were Harry's (Precision Turbo) Best T-88 Pro Mod stuff. Ceramic Ball Bearing, Custom Compressor and Turbine wheels, etc, etc.
Only the Butler's run the old school T-91 turbos as far as Pontiac guys go and Travis has said several times that the newer technology Precision T-88 stuff would be faster vs their units. Tom V. You are correct George, it was not a tear, it was a drop of urine from you pissing in the wind again.
#125
LOL! Ewwww that was a good one computer jockey!
GTO George |
#126
![]() Quote:
![]() I know there's a lot more to getting an e.t. but, do you have a way to figure out about how much HP it would take to put a 2650lb. pro mod at 5.90 in the quarter? thanks. |
#127
Good thing your not a betting man.. You would be broke with that kind of blind loyalty..
#128
It's only numbers in a checkbook.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
#129
![]() Quote:
http://www.prolineracing.net/engines...2-481x-4000-hp Stan
#130
Checkbook racing has been around as long as there has been checkbooks and racing. There are dozens of builders all over the US that can provide that kind of hardware and instantly give you a 4000 HP Pro-Mod engine. IF that's the way you want to go racing. No different than the plug and play route we could have gone with the Boss Bird. It all comes down to personal satisfaction.
#131
If he really wants to go pro-mod racing, he's in for a steep learning curve like John Gaydosh has gone through in pro-stock. I wouldn't be surprised if he went all in on it like Gaydosh nor would I be surprised if he's one and done. See my signature, I love Pontiacs as much as you all do but limitations are limitations. Some can be overcome, others, not so much. The sad truth is the Kauffman dragster, the baddest Pontiac I know of, probably couldn't qualify if they "waivered" it in. I'm pulling for Justin, I really hope he can make the show and "gulp" win a round...but it's not likely.
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
#132
![]() Quote:
#133
Bruce, I understand that he with the biggest head gasket ultimately wins because there is just more room to work with to do what is needed to stuff the most air in the hole. But there is no one who can tell that he could not make FAR more power by building a engine as close to the max ci possible and using a head that does not belong on a 500HP pump gas 455.
There are Pontiac heads that flow 500cfm. That is 150 cfm more than his E street heads. And no George, 42lbs of boost in not 42lbs of boost. What, do you think we are all stupid and will just except a statement like that. 42lbs boost on a iron D port is a far cry from 42lbs boost on a 500cfm billet RAV head. Whole lot easier to build boost trying to stuff it through a tiny hole vs a sewer pipe. And what you end up with on the other side of that tiny hole (combustion chamber) is not even in the same ballpark as the sewer pipe. I now firmly believe that if you listened to some of the people around here you would be in the 7s. Mike is making close to your power NA. Its not about "boost" George. Its about cylinder pressure. Boost is just one way of getting more cylinder pressure. Stuff as much air and fuel into a cylinder, squeeze it as much as possible and light it off. Make as much heat you can. Heat=energy. And I think Wilcox was on to something when he did what he did. Found a limit with a factory style iron block. How many other guys are trying a max effort 14-71 blown, alcohol-some nitro with real race heads ? 3-4 ?? We have Boss Bird, 3fast, maybe Melot? We will all know a whole lot more about the max power with a Pontiac based engine when Wilcox and 3fast are done with their engine. |
#134
No argument there. The way to climb the learning curve is one race at a time. Even on a flag waving Pontiac board, I hope nobody has any crazy illusions he is going rounds in Pro-Mod against the best and experienced racers in the class at Indy no less. I'm sure he is going in with his eyes open. He has a car that sort of fits the class, Indy is a super cool place to race no matter what. Why not give it a shot? If he is way out of the field, he will know it by actually trying to make it. Not sitting around wondering, wishing and computing all the reasons he could never do it. If he runs a lifetime best, he has accomplished something.
#135
![]() Quote:
The ONLY thing that has stop me from running a 7 is more boost, 11 lbs (you do realize I'm only running 11 lbs of boost......RIGHT "Genius") ain't going to get it done. I know I don't know anything (LOL).....ALL my car does is go down the track all the time (can't race if its broke) and run consistent while running 8 teens at 168 on ONLY 11lbs of boost. I'm happy!! GTO George Last edited by GTOGEORGE; 08-15-2016 at 09:04 PM. |
#136
2cents, Justin would be far ahead on the learning curve if he contacted Eric and crew.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
#137
![]() Quote:
"GTO George __________________ 8.15 at 168 mph only 8 lbs. of BOOST! 5.08 - 1/8 mile only 9.5 lbs. of BOOST! "
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
#138
![]() Quote:
Really who actually reads them......I guess besides you? LOL! GTO George |
#139
We all know that 11 lbs of boost isn't 11lbd of boost so it might be 8 or 9! LOL! Different weather conditions.....camshafts.
GTO George |
#140
ONE THING I LIKE ABOUT GEORGE IS THAT EVERY DAY HE SINGS A DIFFERENT TUNE.
Tom V.
