Yeah, these west coast guys out here in Seattle think it's a really rusty car, but they don't know what cars are like back in the Midwest and Northeast. It's all relative.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
That’s some nice work
Looking real good so far Your metal work on the doors are impressive. Did you mig them or tig weld them? I have a tig welder but still have not mastered it yet as well as mig welding |
The doors were mig welded. I believe the tig welder may be used in a few areas of the body where heat management is more of a concern.
I hear you
I am doing the same as you I have a metal/body man and I have a painter I am just disassembling bagging and tagging as well as refinishing all the small parts then I will reassemble it all back |
Question for those of you who have replaced the rear deck panel before... Did you put some kind of pad between the deck panel and the parcel tray structure below? If so, what did you use? Some sort of closed-cell rubber mat?
Use dynamat or an equivalent sound deadner
If not the panel will sound very tinny and not solid at all |
Thanks for the suggestion on the Dynamat. I've got some in the shed from an earlier project.
In other news, I'm fabbing up some reinforcements for the chassis rather than buying them pre-made. Got the rear section tacked in tonight.
Finally got all the reinforcements welded in and cleaned up today. Came out pretty decent! Took a while to make everything from scratch, but it was worth it.
Nice work and craftsmanship
Keep it going! |
Time for a small update. Got the rear deck substructure and outer panel installed, and finished the sail panel repair. Pretty amazing to have all the rust gone in that area. Now moving onto lower fender patches and then the tail panel and trunk pan. Took a while to get where we are now, but it should start picking up as the rear deck area was probably the most intense part of the bodywork.
I've also decided to paint the frame myself, so I've been slowly scraping, wheeling, and stripping it down to bare metal. It's tedious, but I think it'll come out nice. ![]() ![]() ![]() ![]() ![]() ![]()
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 02-15-2020 at 09:49 PM. |
Awesome work, mine needs the same areas replaced and I have that scheduled for 2022, lol. Great progress and very nice attention to detail.
Randy |
If you're going to be replacing the rear deck substructure and parcel tray like I did, you'll probably want to save the photo above that shows it without the outer panel installed. Nobody makes a GTO rear deck substructure, so the only option is to modify one that is intended for a Chevelle. This entails extending it by about 5" or so to fit the GTO body dimensions. You can see where it was extended in the photo above where there is gray paint on it. EDIT: Here is another photo showing the rear deck substructure extension that was needed.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 02-16-2020 at 01:22 PM. |
| The Following User Says Thank You to ZeGermanHam For This Useful Post: | ||
Good grief, I think I'm finally in the home stretch with refurbishing the frame. I decided to clean and paint it myself to save some money over having it blasted and powder coated. Took an eternity to get it down to bare metal, including the nooks and crannies, but it came out nice. My angle grinder definitely got a workout with this task.
For all the old timers who say they don't make 'em like they used to, take a gander at the front crossmember welds. Must've been slapped together on a Friday afternoon before a holiday weekend, by Ray Charles... I'm going to clean them up and re-weld, just because I can do so easily at this stage. ![]() ![]() ![]()
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 02-23-2020 at 09:39 PM. |
Keep up the good work. All of those little details that no one sees pays off in the end. Mine says hi from Michigan..
![]() Sent from my SM-G970U using Tapatalk |
Thanks for the words of encouragement! Yours is a beauty, and a post coupe like mine as well. Very cool. I'm originally from Michigan, too (East Lansing), and my GTO was built in the Pontiac, MI plant. Possibly yours was, too?
holy Toledo you have that frame looking like chrome. how long did that take? what do you suppose you'll paint that with?
For paint I'm going to be using Eastwood's chassis black satin finish. I'll also be using their internal frame coating.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 02-24-2020 at 12:53 AM. |
I am glad I sent mine out for blast and powder - 40 hours of what you did by no means is fun. How are you going to run your fuel and brake lines? Most kits are either hardtop/post or conv't - yours is neither now frame-wise |
Dang, that's almost too pretty to paint!
Greg Reid Palmetto, Georgia |
Thanks! Some of the guys at the shop have been joking with me that I should just throw some clearcoat on it. I can't recall if that was before or after they made fun of me for how long it took to clean up.
