Old 08-08-2019, 10:50 PM
OVERULD's Avatar
OVERULD OVERULD is offline
When I bought my first 74 Formula 455 back in 1975, it didn’t have a spoiler (see sig photo). I wanted to add one back then. Now that I own that car’s twin from the same dealership, I am very conflicted. I love the look of the spoiler on a Formula, because like others have said, it balances out the twin front scoops on the hood. Hard decision. Still on the fence.
The fact that the two cars are both non-spoiler makes me want to leave this one that way...or do I say here’s your chance for a re-do?
By the way, sorry for the rabbit trail in your thread. I Love your car and the way the spoiler looks on it. I say change the column shift too. Go 4-Speed.
BJ
  #122
Old 08-09-2019, 06:51 AM
Pepi's Avatar
Pepi Pepi is offline
Mine didn't come with a spoiler and I have been leaving it that way for originality. I do like the look of spoilers but as others have stated, then it looks like a Trans Am. I have had friends say the back looks plain but the front end makes up for it.
To each their own though, the cars are yours so if you want to add a spoiler add it, if you don't like them then don't.
Car looks great and good job on the spoiler!!
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #123
Old 08-09-2019, 10:48 AM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
This is one of those times you can have it both ways.
Get another deck lid! You have to paint the spoiler anyways so just add a lid.
They can’t be that hard to find. They made them from 70-81 and the Camaro one is the same.
  #124
Old 08-09-2019, 12:25 PM
unruhjonny's Avatar
umm, you seem to be forgetting the holes required in the quarter panel
1970 Formula 400
  #125
Old 08-09-2019, 04:07 PM
Pepi's Avatar
I think I have a deck lid sitting around some where.
  #126
Old 08-10-2019, 07:06 AM
HO Kenny's Avatar
There is usually a flaw in my genius. I should have remembered that. 🧐
  #127
Old 08-14-2019, 01:58 PM
Flush-Fit molded with fiberglass resin.
Double-Sided attachment tape for prelim engagement/positioning.
= no holes
just an option
Today's bonding epoxies would probably allow drill-less attachment too, without the "flush-molded" look.
Butt-Naked isn't always a Good-Naked (saw that on Seinfield one time )
  #128
Old 09-04-2019, 07:47 PM
77 Canamman's Avatar
I was able to locate excellent used horns, thus getting them to function properly. I was able to access the bolts through the market lamp cutout.
Sent from my XT1650 using Tapatalk
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #129
Old 09-07-2019, 08:52 AM
I went with the Year One Honeycombs with M/T tires. The cost of everything was almost the same as if I went with the Coker Firestone Wide Oval radials, and kept the Rally II's. I was able to get the car state safety inspected, and then put 50 miles on it. It ran and drove great.
  #130
Old 09-25-2019, 01:11 PM
I had some Admiralty blue single stage enamel left over, so I painted the area's I am working on. I also happened across a 1973 454 Stingray during this morning's cruise. I'm headed to Carlisle next week hoping to bring home a nice drivers fender.
  #131
Old 09-26-2019, 10:25 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
looks great, you got a lot of car for the $$ on that one!
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #132
Old 09-27-2019, 11:58 AM
Thanks, Rick. I have the car running excellent. I have a couple of hundred miles on it, and everything is working like it should.
I did some research, and found something interesting for those of us with the neutral interior color. Corvettes in 1974-75 used the same light neutral (cream)color that Pontiac used in 1973. I verified the color match using PPG paint code sheets. Corvette Central sells the dye in either quart cans or aerosol. As for the midnight neutral(greenish brown) color, I have not located a source for that yet.
  #133
Old 09-27-2019, 01:08 PM
Just adding another possible 2 cents worth.
You could get cloth interior in a 74 F-Body with deluxe interior, also.
Hard to remember if it was exact color as 73 - but probably so.
I inspected a 74 SD TA Dark Blue with cloth interior in the late 80's.
Mint condition well kept car.
It was the first one (and still the only 74) i had seen with that cloth interior, in person.
Only seen about 4 - 1973 models with that interior.
2 were Brewster Green SD Automatics.
1 Brew 455 TA Auto
and your Formula.
Glad the Vette people have some stuff available for you.
  #134
Old 10-14-2019, 07:28 PM
I installed Fairchild Industries outer door belt strips. They seem to be the closest to GM available. The felts are properly riveted to the strips, and they fit great. They were under $50 a pair.
https://www.ebay.com/itm/Fairchild-I...72.m2749.l2649
  #135
Old 10-16-2019, 07:54 AM
Question
My factory Delco AM/FM radio will be here soon. Of course, the bonehead that owned my car cut the factory radio harness, but fortunately spared the dash and left the rear support bracket in place... Does anyone have these connectors with a few inches of wire that they would like to part with?
file photo of requested item
  #136
Old 10-19-2019, 08:30 PM
I received the radio, advertised as pulled from a 1975. I was surprised that it was the coveted AM/FM red dot stereo instead of the mono. The decal on the radio chassis was MIA. After locating the special connector, and a couple of hours of lubricating and cleaning the radio, and adjusting the flip dial, it fired up and played flawlessly. I have more work to do before installation, such as recoloring the needle, and detailing the pushbuttons.
  #137
Old 10-20-2019, 09:12 PM
After the needle recoloring and pushbutton resto..
  #138
Old 10-21-2019, 05:01 PM
OVERULD's Avatar
Nice work on the radio. I have that same red dot stereo in my 74 Formula and with two new, correct speakers, it sounds great!
BJ
The Following User Says Thank You to OVERULD For This Useful Post:
  #139
Old 10-22-2019, 06:47 PM
Thank you. The original rear speaker was included with the car, and works well since it was in a box since 1977. The front speaker will need to be tested. More to come..
  #140
Old 10-23-2019, 12:08 PM
abefromen's Avatar
abefromen abefromen is offline
Do you still need this? I have an old harness and they may be on it.
The Following User Says Thank You to abefromen For This Useful Post:
