Old 12-26-2019, 12:51 PM
Most of the 1970 style hood hinge I've seen look like they were black phosphate, but had lightened up a bit over time, making them look light black (or grayish) to me. Here are the hinges off go my 1970 04B Norwood Formula. They have the stamped numbers like Norwood's, and they have blue paint daubs.
I currently own two 1971 Firebirds, both are 02B Norwood cars, and both have the 1970 style hood hinges, so I don't know how deep into the 1971 run they used the early hinges. The hinges on my Formula appear to have been painted at one time, but the trans am hinges are in original condition. They appear black to me, and have the blue paint daubs on them.
ID:	527483   Click image for larger version
ID:	527484   Click image for larger version
ID:	527485   Click image for larger version
ID:	527486   Click image for larger version
  #122
Old 12-26-2019, 01:05 PM
SD455DJ SD455DJ is offline
Originally Posted by Norwood View Post
Dennis, all 70 hinges have this welded in brace
Thanks Craig! It looks like the passenger hood hinge is a replacement as it doesn't have the welded-in brace the driver side '525' hinge does and it doesn't have the stamped '524' in it....bummer.
Dennis
Name:	525 Hood Hinge.jpg
ID:	527492   Click image for larger version
Name:	Wrong Hood Hinge.jpg
ID:	527494   Click image for larger version
Name:	Hood Hinge - Driver.jpg
ID:	527495   Click image for larger version
Name:	Hood Hinge - Pass.jpg
  #123
Old 12-26-2019, 01:40 PM
Thanks for the pics of your hinges eaglesan13! Hmmm...so is our passenger side hinge original (?) as it does have the more finished/cleaner die stamped reinforcement like both sets of your hinges...just without the stamped '524'???
Ours has blue paint daubs too...almost look painted on the bottom portion that bolts to the fenders.
Dennis
  #124
Old 12-26-2019, 05:13 PM
Dennis,
I don't know if I've ever seen a hinge that had the reinforcement, but without the numbers stamped. Maybe I have, and just haven't noticed. I have seen the early hinges where the 524/525 numbers had been X'd out. I don't have any pictures of that, and have no idea why it would have been done.
Since your hinge has the reinforcement, and if there is no indication that the car had any body parts (like fender or hood) replaced, it wouldn't surprise me if it was an original hinge. I'd leave it alone if it were my car.
Cool car!
Chris
Dennis
  #125
Old 12-30-2019, 09:51 PM
Keith K, It sure looks like gray phos plating to us.
Dennis
Thanks for checking and posting the pics, Dennis!
  #126
Old 12-30-2019, 10:17 PM
Transamric's Avatar
Maybe I'm stating the obvious here, but the May 1st 1970 Pontiac MPC shows that the hood hinges were part numbers 9790524 & 9790525. Then by the March 1973 MPC they carried the "Chevrolet" part numbers of 3990431 & 3990432 as the Service replacements for all "F" body 1970-73.
  #127
Old 12-30-2019, 10:22 PM
Transamric's Avatar
FWIW, the September 1971 MPC (section 8.015) shows both pairs of part numbers with the #524 & 525 listed as 1970 only and #431 & 432 A 1971 - 72.
  #128
Old 12-30-2019, 10:42 PM
1965gp 1965gp is offline
Wow- so much to learn from this car! The details are amazing. Thank you for painting the air cleaner- that was hard to look at....
  #129
Old 01-01-2020, 09:42 AM
Dennis,
Cool car!
Chris
Chris,
Thanks! The fenders and hood are indeed the originals, so we also feel confident that the hood hinges are also the original to the car. They both have the messy blue paint daubs on them just like in your pictures you posted.
Dennis
  #130
Old 01-01-2020, 09:43 AM
Transamric,
Very interesting! Now I'll have to check what hinges are on my '71 Formula.
Dennis
  #131
Old 01-01-2020, 10:13 AM
Dan replaced the original broken and indented console with an NOS one I bought a long time ago from our local Pontiac dealership (boy, I miss those days!) along with an NOS bezel and repro gear indicator lens. We reused the original allen head bezel screws, console door & box, and seat belt holders.
Dennis
Name:	Original Console.jpg
ID:	527948   Click image for larger version
Name:	Old Console Out.jpg
ID:	527949   Click image for larger version
Name:	NOS Console In 1.jpg
ID:	527950   Click image for larger version
Name:	NOS Console In 2.jpg
ID:	527951   Click image for larger version
Name:	NOS Console In 3.jpg
  #132
Old 01-01-2020, 10:23 AM
Dan also replaced all the light bulbs while he was deep into the console swap and installed a new trunk mat as well.
Dennis
Name:	Under Dash Courtesy Lights.jpg
ID:	527953   Click image for larger version
Name:	New Trunk Mat.jpg
  #133
Old 01-01-2020, 10:57 AM
unruhjonny's Avatar
is that an arrowhead sticker possibly covering the dash insert bird holes?
1970 Formula 400
  #134
Old 01-01-2020, 11:45 AM
Jonny,
It is an emblem and could be attached with a backing nut. We don't know when the bird emblem was swapped out for the arrowhead. Do you have pictures of the proper bird emblem and the back side of the insert? Does the bird emblem attach with a single pin, or 2?
Thanks, Dennis
  #135
Old 01-01-2020, 12:32 PM
FASTASSBIRD FASTASSBIRD is offline
Man there is some truth to there being different colors in the wood paneling of the dash inserts
  #136
Old 01-01-2020, 04:33 PM
unruhjonny's Avatar
Jonny,
Thanks, Dennis
it's the same unit used on all 1970-1981 Firebirds*;
It has one larger plastic locking pin, which is retained by a metal "V" clip, and is complimented by a smaller plastic locating pin.
* = the exception being any gauge cars with AC, which did not have a bird on the dash.
I have chosen to link this specific one because it shows the "V" clip in place, and the alignment pin:
and then I found this (which I couldn't link):
Name:	better dash bird back.jpg
1970 Formula 400
Last edited by unruhjonny; 01-01-2020 at 04:34 PM. Reason: third image I linked was way too HUUUUGE
  #137
Old 01-01-2020, 06:23 PM
Assembly diagram for Bird on dash
  #138
Old 01-02-2020, 07:30 AM
Thanks Jonny! That is very helpful and good to know the hole we see to the upper left of the arrowhead is the pilot hole for the bird emblem.
Thanks Johnta1 for the assembly manual illustration. I don't have that in my parts manual which makes finding things a bit more challenging.
Dennis
  #139
Old 01-02-2020, 04:22 PM
Transamric's Avatar
Dennis
Could we get a picture of the placement of the trunk spare tire jacking instructions? I'm imaging that it's the original too.
  #140
Old 01-02-2020, 05:35 PM
Transamric, Here is a picture of the original jack/spare instructions on the trunk lid. Unfortunately, the posi instruction decal fell off, but you can see the stick-um residue where it was.
Dennis
Name:	Orig Spare Tire Instuctions Decal.jpg
