Old 03-10-2021, 12:01 AM
tom s tom s is offline
421s,with progressive linkage your driving on a 2bbl.Tom
  #122
Old 03-10-2021, 12:02 AM
slowbird's Avatar
slowbird slowbird is offline
Ports have been reduced down to stock size ports with room to make bigger.When I get the intake back I will give you the numbers on the runners.Tom
Thanks Tom! Things are looking really good right now, keep up the great work!
  #123
Old 03-10-2021, 01:06 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
Jim Robertson performed his magic doing the late style changes that had to be done to make it fit a set of 69 heads.Tom
It appears he certainly did, thank him for us please, this is beautiful, absolute art, much thanks Tom!
Originally Posted by tooski View Post
On top of the evident bling factor, how would this race type manifold with dual carbs affect the performance of a 'healthy' 400? I would suspect the over carburetion would detract from the performance. What was the original application for them?
You can see the original location for a 2bbl in the center of the 4 bbls, more on that subject in recent Smoke Signals articles.
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
  #124
Old 03-11-2021, 04:52 PM
3D done,will test fit this weekend.
The Following User Says Thank You to tom s For This Useful Post:
  #125
Old 03-11-2021, 05:02 PM
misterp266's Avatar
Thumbs up
Looks great Tom!
Nice work.
" Darksiders Rule "
  #126
Old 03-11-2021, 06:55 PM
mgarblik mgarblik is offline
What a cool conversation piece! Hope it fits as expected. Great progress. Keep the momentum going. This baby is up to a crawl now!!
  #127
Old 03-11-2021, 09:10 PM
InCredible !
  #128
Old 03-12-2021, 08:21 AM
Tim john Tim john is offline
I feel like this whole process is like watching a baby bird egg hatch into an Eagle...and she will soon fly when ready.
Amazing process, progression, precision and ultimately desirable (factory style) performance is on the horizon. Well done Tom and team.
Tim john---
  #129
Old 03-12-2021, 11:07 AM
I was told by the guy that helped on this project who has done many of this type of project and he equated it to exactly like waiting for the birth of a child.Not quite.Tom
  #130
Old 03-12-2021, 11:13 AM
tempest1964's Avatar
I guess that gives a whole new meaning to the expression ‘Bathtub Delivery’
  #131
Old 03-12-2021, 11:18 AM
Mike Davis's Avatar
Looks good Tom. Hope it fits well.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
  #132
Old 03-12-2021, 04:33 PM
slowbird's Avatar
First off awesome job Tom getting this done!!
Sorry to ask, without scrolling back through all the post, does this 3d intake fit early or late heads? The water crossover looks odd to me for the later heads??
  #133
Old 03-12-2021, 04:53 PM
The plastic is early but looks the same from the top,will post pics of it and the converted one side by side tonight.Tom
  #134
Old 03-12-2021, 07:06 PM
misterp266's Avatar
Question.
Will this intake fit under the hood of a ‘63 Catalina or does it “require” the SD scoop to work?
Regardless, I’m in for a late model version. I will PM you Tom.
" Darksiders Rule "
  #135
Old 03-12-2021, 07:31 PM
Some pics
ID:	562551   Click image for larger version
ID:	562552   Click image for larger version
  #136
Old 03-12-2021, 07:34 PM
More
ID:	562554   Click image for larger version
ID:	562555   Click image for larger version
ID:	562556   Click image for larger version
  #137
Old 03-12-2021, 07:35 PM
More yet
ID:	562558   Click image for larger version
ID:	562559   Click image for larger version
  #138
Old 03-12-2021, 07:52 PM
A little issue with the port alignment on the plastic intake,I think because the scanned port was a 2.100 tall port and we reduced more to stock 1962 head.Looks to me it would have to be opened up a touch to match a 62-63 421 SD port.Not sure if I want to mess with it or just go with it.The ports on the converted intake Jim did are perfect match for a stock 48 port with lots of meat to go taller and wider.Will try to get wall thickness.As you can see looking down from the top the water X overs are a match.You will notice the bolt holes on the first 2 on each side are now diff.I put 4 bolts in each intake screwing in with my fingers without a wrench so the holes on the flanges are pretty much dead nut to the heads on my engines.Baby steps.The project will start with the early style so im at the mercy of those that wanted them.When im convinced the pattern maker is comfortable and ready to take my deposit I will ask for a deposit from those that committed.That will separate the contenders from the pretenders.Im going away sking for a few days and will be back on it when I get home.Have the 383 RA V engine going on the pump the 24th so thats taking some of my time also.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
  #139
Old 03-13-2021, 08:29 AM
4zpeed's Avatar
Well of course they are.
'JimRobertson'
As always, thanks for the update Tom,
Frank
  #140
Old 03-13-2021, 01:01 PM
PontiacJim1959 PontiacJim1959 is offline
With the large space between #4 & #6, and #3 & #5 intake ports on the V-plenum, will you get fuel puddling/collecting in that area?
