Old 02-18-2024, 07:00 AM
steve25 steve25 is offline
A tube of this goes a long way.
  #122
Old 02-18-2024, 10:07 AM
HWYSTR455's Avatar
I have a notion that Herb Adams with the hand that he had in this and his eye for wanting to use it in his 64 road racer is the only reason why that rear bulkhead dry sump pump was added to the Design.
The big question I have is how he got this costly change passed the eyes of his upper supervisor’s during preproduction.
I think I have seen signs of this oil system in photos of one of the experimental overhead cam motors, so it may have been around for a while, but to include it in even a limited production motor still had to be a big cost.
I guess like we have heard in stories over the years that even though upper management was against this motor Pontiac sales already had so many orders for F body’s with this motor, and since parts where already made they had to reluctantly go with since the cost would then be covered.
To me all the positive advertising and word of mouth that came from the making of this last true super car was worth any monetary loss the division would have to swallow, in fact to me this is what set the stage for the later huge sales numbers of the TA models post 1974.
Herb Adams is active on Facebook, bet someone could message him, he's very friendly and sure he would be happy to talk Pontiac stuff. (He did accept my friend request)
Not sure his son manages the account or not, but seriously doubt it. Believe his son does still do some VSE parts, not sure on that either, but recall at one point he did.
Back in the VSE days, I spent many hours over time talking to him. True enthusiast.
  #123
Old 02-18-2024, 10:41 AM
Thanks !
I will see how it goes in regards to contacting him.
  #124
Old 02-18-2024, 03:07 PM
gpguy gpguy is offline
Super Nice. Great Project and good luck with it.
GP.Style
70 GP SJ White/Blk/Blk
71 GP SJ 4 spd Blk 3X
  #125
Old 02-19-2024, 03:21 PM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
I use a little of my wife Jergen's hand lotion before I start working on the cars, and then use hand cleaner with pumice.
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
  #126
Old 02-19-2024, 07:04 PM
HWYSTR455's Avatar
Um. What are we talking about again? .. Heheh!
  #127
Old 02-20-2024, 10:51 PM
mgarblik mgarblik is offline
Back on track. A little more short block assembly today. In the pics you can see how I like to attach the oil pick-up. I have been TIG welding them with a silicon bronze rod for decades. No issues. Also stretched the rod bolts into place for the final time. .0075" is what ARP specs. for stretch on these 7/16" rod bolts. A few pics below.
ID:	629080   Click image for larger version
ID:	629081   Click image for larger version
Name:	oil pump 1.jpg
ID:	629082   Click image for larger version
Name:	oil pump 3.jpg
The Following 8 Users Say Thank You to mgarblik For This Useful Post:
  #128
Old 02-21-2024, 07:33 AM
Thanks for the up date!
  #129
Old 04-06-2024, 05:39 PM
It's been a while but another little update on the re- re build of this SD-455 engine. The short block is now complete and I disassembled one head today to take a look. Everything is pretty dry in there but only a tiny bit of rust here and there. The heads are not ported or gasket matched. It has had a valve job and bronze guide liners installed and honed to fit. The guides are perfect. The original valves were reused and guides may have been cut for PC seals. Since I have never worked on a set, I don't know how they came from the factory. My plan is to lap the valves to get a visual look at the valve job, test the springs, upgrade to viton valve seals, clean and put them back together. The keepers were reused and in marginal condition. They will be replaced. Overall happy they don't look all hacked up inside. In the pics you will notice these heads have NO casting codes on the exhaust ports. Also no stampings on them anywhere. I looked carefully. No date code or day night shift. Only the part number, that's all. The connecting rods were "A" series forgings and I was told heads without any numbers were early castings?
Name:	sd head 1.jpg
ID:	631667   Click image for larger version
Name:	sd head 2.jpg
ID:	631668   Click image for larger version
Name:	sd head 3.jpg
ID:	631669   Click image for larger version
Name:	sd head 4.jpg
ID:	631670   Click image for larger version
Name:	sd head 5.jpg
The Following 4 Users Say Thank You to mgarblik For This Useful Post:
  #130
Old 04-06-2024, 05:41 PM
Few more pics. Sorry some of these pictures are sideways. Don't know why it does this or how to turn them.
Name:	sd head 6.jpg
ID:	631672   Click image for larger version
Name:	sd head 7.jpg
ID:	631673   Click image for larger version
Name:	sd heads 8.jpg
ID:	631674   Click image for larger version
Name:	sd head 9.jpg
The Following 3 Users Say Thank You to mgarblik For This Useful Post:
  #131
Old 04-06-2024, 06:00 PM
Thanks for the update .
  #132
Old 04-06-2024, 06:52 PM
HWYSTR455's Avatar
Did SD heads come with 1 piece valves? Honestly don't know that.
  #133
Old 04-06-2024, 09:28 PM
The intakes look like a nice one piece valve. I will need to look at the exhaust valves closer tomorrow to tell. I am not sure.
  #134
Old 04-06-2024, 11:13 PM
PAUL K's Avatar
PAUL K PAUL K is offline
The early SD heads were casting 485215. Soon after production started they made a change to the casting and the new number was 485216 hence the "16" cast on the exhaust ports. The 16 heads also gained two rectangular blocks on the center exhaust ports below the 1 & 6.
Go fast, see Elvis!
  #135
Old 04-07-2024, 04:09 AM
Dragncar Dragncar is offline
Pontiacs have beautiful chambers when you compare them to Chevy chambers of that era. All the machined cuts, nice.
Every time I look at them I always think of the 90cc head prototype that was made.
Its amazing PMD got that low CR engine to run so well. 10-1 would have ruled the streets.
  #136
Old 04-07-2024, 07:05 AM
Besides that, and I hope I don’t offend any owners of these cars here, but Fords and non nail head Buicks ( V8s ) and AMCs have the worst valve jobs and or castings.
Not that they don’t seal but they have sunken sharp rideges and under cuts and castings that either have very bad core shift or bad castings period!
Zoom in on the picture of the rusty Ford 460 head I posted and look at the under cut below the main 45 degree seat of the intake valve, and then there’s the chamber lip above the intake valve so this Ford head already started off life with a sunken seat which is something you want to avoid at all cost with intake valves.
Next look at the Buick head and the huge lip running around under the main seat of the intake valve.
Even on aftermarket heads there can be terrible transitions from the top of the valve job to the chamber.
On the Edelbrock big port Rpm heads for BBM motors they have a bad lip above the intake valve.
Sorry that I don’t have a photo.
The brand that hands down makes you shake your head in flat out disbelief are AMC V8 heads.
The last set I did I spent 30 minutes on EACH valve just hand blending out the ridges left by the machining of the valve job
You never find the kinda crap on a Pontiac head thank God.
ID:	631698   Click image for larger version
  #137
Old 04-07-2024, 07:51 AM
sdbob sdbob is offline
Thanks for all the information. Amazing.
  #138
Old 04-07-2024, 10:14 AM
If I had to guess and that's what it is, I would say the last digit is a 5. Awfully hard to tell a 5 from a 6 in this circumstance. What do you guys think? Paul, do you happen to know what changes were made to the 16 casting? Any idea how many early castings were produced? All kind of interesting. I guess I can remove the paint and try to get a cleaner look at the part number.
Name:	sd cast number 1.jpg
ID:	631707   Click image for larger version
Name:	sd cast number 2.jpg
  #139
Old 04-07-2024, 11:30 AM
Some better ID pics.
Name:	sd head ID3.jpg
ID:	631714   Click image for larger version
Name:	sd head ID4.jpg
ID:	631715   Click image for larger version
Name:	sd head ID5 (2).jpg
ID:	631716   Click image for larger version
Name:	sd head ID6 (1).jpg
  #140
Old 04-07-2024, 12:24 PM
nas t eh nas t eh is offline
That is a 5
73 T/A 455, 4speed
