| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
#121
Well now at 2:20 p.m., 50 minutes after my post above, 835 users online, 50 of which are members.
#122
Sure beats 12,000.
https://www.flickr.com/photos/197745168@N07/ "The biggest areas that have been a disaster moving from truth to subjectivity are academia (esp science), media, and law." |
#123
I thought it was me. When comparing what you guys experienced its same here. I've noticed bad or not good advice on you tube , net,etc with our Pontiacs. This forum is the best for help,experience with building our Pontiacs.
#124
Way way better, only 189 guests now and similar when I popped on 3 hours ago, good job on making them aware and the quick fix after.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
#125
Looks like they took out the trash.
#126
A big thank you to staff for the improvement
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
#127
Why am I being asked if I'm human every time I sign in?
Practicing social distancing for 65+ years |
| The Following 2 Users Say Thank You to BOB VIDAN For This Useful Post: | ||
#128
Well because that’s debatable in your case, cheers 🍻
| The Following User Says Thank You to 60sstuff For This Useful Post: | ||
#129
I think it is a way to prevent ‘bots from doing a mass attack and overloading the max performance internet server. So we can all access the forum
| The Following 3 Users Say Thank You to tempest1964 For This Useful Post: | ||
#130
I see the light! Amazing how fast the 'net' changes. I just got recertified to volunteer especially around youth. What they are 'bombarded ' with!! Parents be watchful!
#131
The captcha seems to be helping a lot. This is a great improvement!
Thanks again to tempest1964 for initiating this change! There does, however, seem to be some caca slipping past this verification software. Hope it doesn't learn how to bypass the captcha well enough to flood the site again: |
| The Following User Says Thank You to Shiny For This Useful Post: | ||
#132
when you see something like this, hit the report button
#133
The site is running great now. Almost as good as a well oiled Pontiac machine!
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
#134
With roller cam, or HFT ?
I'm World's Best Hyperbolist !! |
| The Following 2 Users Say Thank You to dataway For This Useful Post: | ||
#135
Well, you can let your imagination make it whatever you want. Me, I'm thinking of the old site as an HFT and we just got upgraded to a roller.
| The Following User Says Thank You to jhein For This Useful Post: | ||
#136
I am not a robot.
#137
| The Following 3 Users Say Thank You to jhein For This Useful Post: | ||
#138
HFT that seems to be wiping a few lobes every now and then.
| The Following User Says Thank You to 72projectbird For This Useful Post: | ||
#139
With a bad float in the carb? … it get’s flooded every time you have to start it, making start up procedure ten times as long as it should be?
| The Following User Says Thank You to unruhjonny For This Useful Post: | ||
#140
Have you had a haircut and shave lately Bob ?
| The Following 2 Users Say Thank You to Baron Von Zeppelin For This Useful Post: | ||
