dont make assumptions. based on the details provided, although still somewhat confusing, the cam/lifters should be fine. a small amount of coolant in the oil will make it cloudy after a short run, it doesnt mean the cam went flat or any other major damaged was caused from just a small amount of coolant in the oil for a short run time. the cam & everything simply needs to be inspected then go from there, don't buy parts that arent needed.
didnt you just go through selecting a new cam after the initial engine failure? why do you want to pick a different cam now for the same specs of the drive line?
I know it seems crazy but after I got the oil filter adapter to stop it just starting pouring water. I could see bubbles around the timing cover and of course the water outlet so I assumed that was the leak. I wish you guys could see it because it’s been one thing after another. It was putting a small amount of water in the oil at first and then about the 4th of 5th time I cranked it it dumped ALL the water into the engine. When I went to open the radiator cap it blew it off,. This engine doesn’t have hours on it, it has like 15 minutes. I drove it to the end of the street and back and that’s it. My machinist is gonna rebuild it no matter what is wrong with it. He told me that I could go back roller if I paid the difference between the 60919. I just wanted to solicit advice about what some of you would use. There was a difference of opinions on what cam to use earlier. This isn’t my first rodeo with a Pontiac engine but my previous two were over 20 years ago. I have never built a max effort street Pontiac.
My head is spinning here.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
| The Following User Says Thank You to ZeGermanHam For This Useful Post: | ||
Mine too. This has been a disaster. The first was my fault but this is just ridiculous
Dave - at this point I would plan to keep the 60919 whether it’s the one in there now after inspection or a new one if that one was damaged. Not only will a roller cost more, you’ll need the polymer distributor gear, different pushrods and of course roller lifters. And after all that you may get a ticking lifter. Why torture yourself with all that when you’ve already been down that road? Especially since this will be a street only car. Keep it simple and stick to the plan you had.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following User Says Thank You to grivera For This Useful Post: | ||
I would definitely stick with the 60919
| The Following User Says Thank You to Gach For This Useful Post: | ||
If helpers directly beside engine, looked for soaked helpers.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Yeah it may look like they pee their pants LOL
Good that it’s in pro hands now. The leaky adapter you fixed before the issue, right? This leaves the oil/coolant mystery
Your builder might be a stand up guy, but how many times are you going to have him rebuild it/fix it? The 'coincidences' are stacking up.
K, just saying what everyone else is thinking... .
I blew the first one up. Totally my fault. If for some reason I don’t get satisfactory resolution I guess I will search for someone else but I doubt it will be necessary.
Pinhole in one of the cylinders. He is going to sleeve the block and replace bearings. Cam and lifters are undamaged
No charge?
Usually, that's caught when checking a block before a build? .
No charge. The block came from a “dealer” who sells BOP blocks in Virginia. The block was said to be checked. It came wrapped in plastic with a tag that it had been checked. I had to pay extra for a virgin block.
Why didn't that show up during break-in? Didn't anyone check the oil?
Triple Black 1971 GTO |
I'd pay for someone to THOROUGHLY SONIC-CHECK all the cylinder walls in that block before you put it all back together.
My concern would be that when there is a thin enough wall in any one spot for a pinhole, there's probably more than one thin spot or thin cylinders. Good luck! |
| The Following 2 Users Say Thank You to Joe's Garage For This Useful Post: | ||
Pressure test!
Jeff |
| The Following 2 Users Say Thank You to geeteeohguy For This Useful Post: | ||
I did some googling and I assume it’s a heat cycle thing from all I read. I have the dyno video. Ran fine. Yes the oil was changed here. 100% normal. New oil and filter before startup
I asked the builder to pressure test it before assembly and he has no problem with that. He didn’t mag it because it came “tagged” from a person who is supposed to be on the up and up. I won’t name his business until I see what he’s gonna do but he was a reputable source supposedly. If presentation counts the way it looked delivered then I can see why the mistake was made. The thing I appreciate is that it was owned by my assembler and I will have nothing further in it.
