Old 08-01-2025, 05:29 PM
Bought a 70-72 gauge carrier at Norwalk and managed to get it her to Portugal without the ramp rats wrecking it. Suitcase was flattened a bit but I gather that 50+ year old plastic is pretty tough stuff!
  #1422
Old 08-02-2025, 12:30 PM
mgarblik mgarblik is offline
Finally got the 62 Catalina out for a drive. The weather here has been horrible for over 2 months. Either torrential rainfall or 110 heat index every day. So many events rained out or held in the heat and mud. Weather perfect today. Went to a Cars and Coffee. Well over 1000 cars, probably closer to 1500 when considering the constant cars coming in and leaving. Some notable Pontiacs and a few others. 1. 1970 TA, Nice car, original drivetrain, white/blue, power windows and AC. 2. 1967 GTO, original owner, original paint, original everything, right down to the 400 2BBL. engine with Hurst His and Hers shifter! 3. 1970 4-door Executive all original, now owned by the grandson of the original owner. He just completed a 1700 mile drive in it. My car got allot of attention from the 50 and older crowd. A few curious younger people looked puzzled by the bathtub intake and the 2 4BBL. carbs. Others: 2 1968 Olds 442's, beautiful. 1957 Nomad, red/white, beautiful. 3. 67 Camaro SS all original 4-speed, 4. 454 El Camino 4-speed. Tons of Corvettes, exotics of every brand. Leaving the event, entering the highway, performance cars are "expected to accelerate" on the interstate. Catalina turned some heads, pulling hard to 6000 RPM's in 1-3rd. gear. Fun morning.
The Following 4 Users Say Thank You to mgarblik For This Useful Post:
  #1423
Old 08-02-2025, 01:36 PM
67drake's Avatar
67drake 67drake is offline
Same here! Great season for the local farmers, as it seems to rain every other day. Getting projects done is kinda hard though as between the rain and heat, and Canadian wildfire smoke, I can only do so much before exhausting myself. Any non rain days I’m trying to keep up cutting grass!
My plan is to get into the shop this weekend and and least get the new lighted hood ornament on the ‘55 installed and lighting, in place of the original one.
‘55 Catalina
The Following 3 Users Say Thank You to 67drake For This Useful Post:
  #1424
Old 08-02-2025, 02:13 PM
BILL BOWMAN1's Avatar
Aggravated both of them! Put a SBC in between them. Its for my truck, I’m not jumping ship.
The Following 2 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
  #1425
Old 08-02-2025, 05:19 PM
Exactly, been doing next to nothing because of the heat or rain. Today was the first time in 6-7 weeks that the air is off and windows open!
  #1426
Old 08-02-2025, 06:08 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Fun day at the track today!! Been a while here since temps were under 85°.
ID:	655143   Click image for larger version
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
The Following 7 Users Say Thank You to OCMDGTO For This Useful Post:
  #1427
Old 08-04-2025, 01:00 AM
Verdoro 68's Avatar
Thought about getting up for Cars and Coffee, but decided the time would be better spent doing projects. I worked on the Ventura all day - stripped and painted the passenger inner fender inside and out, the hood hinges, passenger side frame, and part of the core support.
Cole and I are planning on road tripping the Ventura to the Duct Tape Drags in Arizona. It's about 1800 miles round trip. I'm confident in the chassis and cooling system since that's where a bulk of our focus has been, but have been debating what to do with the engine.
The engine has about 100K miles and compression is low on a couple cylinders However, the low cylinders have gone up 20psi since he started driving it regularly. A few weeks ago he changed the oil and I had him put 6 quarts of Driven 15-50. A day later it developed a lifter tick. He checked the dipstick and it was showing overfull, so he drained enough out to show the correct level on the dipstick.
The lifter tick mostly quieted down, which makes me think maybe the oil was getting aerated, but I still wasn't feeling super confident in the engine. We've been running off the idiots lights since we got the car, so I installed an old set of AutoMeters I had laying around. I was surprised to see plenty of oil pressure! It almost seems too good the be true for a 100k engine, but I'll take it. I'm not even sure we need the thick oil.
ID:	655167   Click image for larger version
ID:	655168   Click image for larger version
ID:	655169   Click image for larger version
ID:	655170   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 6 Users Say Thank You to Verdoro 68 For This Useful Post:
  #1428
Old 08-04-2025, 04:43 PM
fairwayhit fairwayhit is offline
Took it out for a little shake down run. Still has a small miss at idle, but otherwise running pretty good.
The Following 6 Users Say Thank You to fairwayhit For This Useful Post:
  #1429
Old 08-04-2025, 07:07 PM
jhein's Avatar
jhein jhein is offline
Put her up on the Quickjack. Took the rear wheels/tires down to the tire shop and had my BFGs put back on. Got rid of the MT drag radials which were worn out anyway. I only got about 2500 miles out of them which was not unexpected. While they did my tire swap, I went back home and changed the oil. Also collected a sample to send in to Blackstone. I know it's somewhat controversial, but I usually fill my new filter with oil before installing it. This time I didn't. I didn't time it but it took a little while for the pressure to come up. Probably only 5 seconds or maybe a little more but it felt like forever sitting there looking at my zero oil pressure. So I'll go back to filling the filter. I also have developed an oil leak at the rear end of the motor. I couldn't really tell where it's coming from but the four bolts on the rear of the pan were a little loose. So we'll see if tightening them up helps or not.
The Following 2 Users Say Thank You to jhein For This Useful Post:
  #1430
Old 08-05-2025, 06:28 PM
Shiny Shiny is offline
After a year of moving, house projects, and doing nothing on the car, it's time to pick up where I left off. I have a lot more space in this garage than I've ever had, so there's that.
Here's where I left it:
https://forums.maxperformanceinc.com...ighlight=front
Re-acquainting myself with a dolly and slapper, I raised a low spot and then decided it was too hot.
Or maybe I just want to ease back into this and didn't want to deal with the bigger challenges in the contours!
And BTW, spray-on dyekem is great for this... way easier than the giant sharpies I'd been using as a guide.
Name:	Screenshot 2025-08-05 160140.jpg
ID:	655260   Click image for larger version
The Following 4 Users Say Thank You to Shiny For This Useful Post:
  #1431
Old 08-06-2025, 07:36 PM
carcrazy carcrazy is offline
Preparing the 67 GTO for a new headliner. A job I have put off for quite awhile. Got the bows pulled out (took a lot more effort than I thought it would), cleaned them up and then cleaned up the left over adhesive along the edges. Still waiting for some new front hubs to finish off the brake job.
The Following User Says Thank You to carcrazy For This Useful Post:
  #1432
Old 08-09-2025, 01:52 AM
I could not get back to sleep at 5 this morning so I thought I would exercise the Lemans before sunrise. It was still somewhat dark and foggy. Common sense would say the hell with it and go back in - nah. I was greeted by one of the headlights beaming off into space light a searchlight during the Blitz. WTH?
I wonder if the inspection company was dinking around with it too?
That, and it took a bit to restart after I went to get a Phillips - these ECM's are really sensitive to voltage. I guess trickle charging is in my future...
  #1433
Old 08-09-2025, 10:14 AM
Cosmic Charlie Cosmic Charlie is offline
As you probably know you actually want a Battery Maintainer ... that shuts off at charged voltage, a trickle charger will eventually over charge your battery. I like the cheap ones that have a voltage digital read out window.
  #1434
Old 08-09-2025, 10:31 AM
Actually I did not know that. The one I have may have that feature - will have to read more about it.
  #1435
Old 08-09-2025, 12:56 PM
..these ECM's are really sensitive to voltage. ...
What does this mean?
Maybe an inexpensive DC-DC converter would take care of it?
  #1436
Old 08-09-2025, 01:20 PM
Starting voltage needs to be at least 12.8ish. Sitting for a bit with a trunk mounted battery is not a recipe for success here.
  #1437
Old 08-09-2025, 01:37 PM
If your battery is Very Low a maintainer will not charge it if the maintainer is only rated at 1/2 Amp or 1 or 2 Amps. I have the newer inexpensive maintainers that are rated 6 +- Amps that will actually charge a low battery +- eventually
I have 6 inexpensive maintainers, various companies and I just bought this one that works OK (2 amp)
https://www.amazon.com/dp/B0C7VFB64L...fed_asin_title
Brand Battery Tender are Well Known but cost like $ 60
Lastly Battery Maintainers are NOT for small motorcycle batteries like a 250 CC but are OK for a large motorcycle batteries like a Harley Davidson
Voltage State of the Battery’s Charge
12.6 or higher 100%
12.5 90%
12.42 80%
12.32 70%
12.2 60%
12.06 50%
11.9 40%
11.75 30%
11.58 20%
11.31 10%
10.5 or lower Dead
  #1438
Old 08-10-2025, 01:38 AM
Verdoro 68's Avatar
Got the Ventura back together. Most of the work we did is hidden, but the underside of the hood and freshened up hinges look good. I ended up repainting the inside of the fender Fernmist because it was so ratty looking.
Next on the list - inspecting the engine to see if it's up for the drive to Duct Tape Drags in October.
ID:	655404   Click image for larger version
ID:	655405   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #1439
Old 08-10-2025, 11:09 PM
Drag Star Le Mans's Avatar
Got a 4 banger outta this...
DragStarLeMans
The Following User Says Thank You to Drag Star Le Mans For This Useful Post:
  #1440
Old 08-11-2025, 08:49 AM
73_Lemans_350's Avatar
73_Lemans_350 73_Lemans_350 is offline
Yesterday my wife and I took the LeMans to a free local car show. I parked next to a Bonneville, and found a nice 77 Can Am! Weather was perfect.
ID:	655510   Click image for larger version
ID:	655511   Click image for larger version
ID:	655512   Click image for larger version
ID:	655513   Click image for larger version
Design Engineer | Dakota Digital
1973 Lemans - 350, Centerline Auto Drags and Cooper Cobras
The Following 4 Users Say Thank You to 73_Lemans_350 For This Useful Post:
