That being said if I workout a simulation for your run. 60 Foot ET = 1.2410 330 Foot ET = 3.2494 1/8 Mile ET = 4.9263 1/8 Mile MPH = 146.5352 1000 Foot ET = 6.3736 1/4 Mile ET = 7.6004 1/4 Mile MPH = 184.1309 I have no idea for your combination how much boost increase will add how much HP. Let just add 300 HP and keep the 60 time the same. The 300 HP is on the starting line and would need to be weather corrected for a dyno number. 60 Foot ET = 1.2410 330 Foot ET = 3.1933 1/8 Mile ET = 4.7808 1/8 Mile MPH = 155.0522 1000 Foot ET = 6.1455 1/4 Mile ET = 7.2994 1/4 Mile MPH = 195.9008 Stan
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Not a bad day at the track today. Still turning it up.
I'd love to have that time slip, since I'm certified to only 7.50 with my mild steel chassis. Congratulations! Don't stop there. ![]() Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Nice run. Congrats
Right Lane
Are you leaving off-idle?
The 60 foot looks slow but it's coming on stronger later. Probably making boost gradually? I would say it's got a lot more in it?
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
The 1.2x 60's will start to get better, getting used to the additional launch boost will take a few more passes. This was the first one. It's was a bit of a change going from 6lb to 10.7lb.
so what boost controller are you using ???
It's part of the Holley Dominator EFI ECU.
ok Im not sure how that one sets up but on the one I used it worked best by ramping up in small quick steps --all in by a second or less
Were you adding/removing fuel and/or Timing?
the boost controller was adding pressure to the back side of the waist gate in small increasing amounts very quickly -- the fuel pressure regulator added fuel based on boost pressure ie boost referenced and if I remember right timing was at about 25 degrees over 12-15 lb boost . Boost controller setup was 12lb springs in the waste gates and then every lb of c02 on the back side of the gate increased boost by aprox a lb -- data recorder will tell you exactly how much.
Cool very easy then. Just messy! lol I just changed my stator this weekend. I have a 9.5 ptc bolt together.
What "should" the 60ft be?
I’m thinking with the boost he’s running now he’s pretty darn close for a turbo car!
GTO George |
(mine in my slow dragster is 1.09-1.15) I suppose the turbos may be 'soft' on launch, but don't see why it should be. The guys that are hampered by small tires would probably have slower 60' times.
As for small tires having slow 60’ times. Most decent 275 tired cars will go in the 1.10 range on decent tracks. A good one on a radial prepped track will go low 1.00s. |
