Old 04-06-2007, 12:20 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
What were the results of the metallurgy testing of the sample taken by Tom V?
  #142
Old 04-06-2007, 11:45 AM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Thumbs up
The 4.250"-4.500" Cranks are being shipped today for those who had pre-paid for them.Check your E-mails or Wade may call you.
  #143
Old 04-06-2007, 11:56 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Talking
Got a call from Wade and my cranks is on the way, this is awesome. Thanks to all that made this happen.
Pontiac's Rule
  #144
Old 04-06-2007, 03:57 PM
Thanks for the call, Wade.
Can't wait to see it.
  #145
Old 04-06-2007, 04:12 PM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
Jack, Metalurgy checked out fine, as Tom said, the metal was very clean.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
  #146
All of the prepaid crank orders for both BOP and All Pontiac are now shipped and we have 4.00, 4.25 & 4.50 cranks in stock. If you ordered from BOP you should have recieved a call or email confirming your order shipped. I did not have the contact info other than addresses for the AP orders but all ahve shipped. If you have any questions or want a tracking # don't hesitate to email or call.
Wade Congdon
BOP Engineering
  #147
Old 04-07-2007, 05:02 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
Any 3" 4.21 stroke cranks in the mix, to use a stock length rod?
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
  #148
Old 04-08-2007, 03:47 PM
taff2's Avatar
taff2 taff2 is offline
You could use a 4.250" stroke crank and stock length rods ,just mock up the assembly and then get your piston tops cut to zero deck.
  #149
Old 04-08-2007, 08:59 PM
Half-Inch Stud's Avatar
hmmm, the slugs be lighter.
  #150
Old 04-10-2007, 11:56 AM
Thanks, BOP and Wade!
Recieved my crank yesterday while I was at work.
Looks like a winner.
  #151
Old 04-10-2007, 04:55 PM
JKrull66's Avatar
Default ROD JOURNAL SIZE
Are these Pontiac Sized rod Journals ?
66 GTO HT Cruiser
POLARIS 900 RZR
  #152
Old 04-10-2007, 04:58 PM
JKrull66's Avatar
OOps read the first post 2.20 journals.
66 GTO HT Cruiser
POLARIS 900 RZR
  #153
Old 04-10-2007, 07:14 PM
R J Staub R J Staub is offline
Got mine today. Sweet Looking !!! Thanks to AllPontiac, BOP, Tom Vaught and anyone else who had a hand in bringing this to market. I'll be sending ICE CREAM money to Norwalk this year with Troy Tribby for you guys.
I'm going to have Jack Gaydosh look it over on Sunday at our 1st race.
If anyone wants to see one and happens to be in the area this coming Sunday (Mason Dixon in Maryland), stop by the Outlaw tent. Just ask for Maddog.
Outlaw Pontiac Drag Series
Race Director
  #154
Old 04-10-2007, 08:07 PM
tempest455's Avatar
tempest455 tempest455 is offline
Got it today!
Tempest455
  #155
Old 04-10-2007, 09:05 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
Originally Posted by Tom Vaught
If I put a crank in a 3.25 main block with a spacer I would go all the way to a 2.75" main bearing and gain potentially a better bearing design vs the 3.25" stuff, I would use a 1/4" thick wall steel bearing spacer with a steel main cap arrangement. You can't do anything about the machining already done to the 3.25" block but you can do something about the main cap outer shell diameter and cap material.
Tom V.
Tom,
We looked that this very thing and we thought maybe we could use a 3.25 bearing as a spacer, then notch a tab for the 400 bearing. It is a no go as the dimensions don't line up. Doing spacers is easier said than done, it is a hell of a lot of machining for a precision race engine. I would love to do a 1.88 rod bearing and a 2.75 main, but getting a machine shop to do it is another thing.
I 100% agree with the cross-drilled issue, but now that we have all agreed, who makes a 455 crank without cross drilling with a 4.210 stroke? I can get there with a 4.250 stroke if it starts with a 2.25 rod. So, my cross drilled crank (going 7500 RPM) is going back in the motor this evening. (Even though Pontiac says about 90 PSI is required.)
Lynn
  #156
Old 04-11-2007, 12:21 AM
tom s tom s is offline
Lynn,Kaase made 2.75 spacers for him EMC engine.Might give him a call.tom
  #157
Old 04-11-2007, 02:43 AM
Tom- if you're talking about Kaase's 2006 EMC engine, he spaced down from the 3" mains to 2 1/2".
