#141
Here's MINE! (just a driver,needs paint)
It's pretty basic; M22,Blue custom trim. I've added the Honeycombs & bumper guards. Other than radial tires,744 cam & Flowmaster American Thunder (transverse muffler) exhaust system,it's original!(oops,almost forgot about the vintage "Ricky Recardo's") Had it to the track a few years back & it ran 13.9 on the T/A's. Haven't driven it for about three years but this spring it's comin' out,FOR SURE!
#142
just kidding 2manyt/a's.....
#143
They ARE on the LIST & I didn't drill ANY HOLES for them. Feel FREE to RIP on me for adding the "Ricky Recardo's",but they are FUN for NOW & I'll put the stock seats back in just as soon as SOMEBODY makes a respectable set of repro DELUXE seat covers. (can we have the right color,PLEASE????)
#144
I guess every week or so I have to prod the HO forum back to life....
Here is a question that is for the 455 HO experts. I can not find a definitive answer in any of the usual sources..... How many of the four fasteners that hold the exhaust crossover to the head were studs and how many were bolts? The parts book lists four studs and no bolts, but if memory serves my car had 3 studs and 1 bolt. One of the four is a bear to install as a stud (too long) so possibly a running change was made for ease of assembly. Anybody have an unmolested car, or taken one apart? |
#145
I have 2 relatively untouched 71 HO cars that I can check for you if you can wait a week or so. Do you want pictures or is a description ok?
#146
No hurry. No need for pictures either, just a description.
Please indicate either; 4 studs or a mixture of studs and bolts. If the latter, please describe where you found any bolts (ie LH side front, etc) Also please post the build week and plant (for example 04A Norwood) Thanks! |
#147
Paul,
Please post pictures too if possible. I would love to see an untouched 71 HO engine or two! Giles, Good questions on studs as people have asked me those questions, and I don't have the answers.
Mike/Illinois |
#148
$1,400 for an original 455HO Ram Air Air Breather
http://cgi.ebay.com/ebaymotors/ws/eB...m=300181061396
1971 GTO 455 HO 4-speed - Cameo White, White Vinyl Top, Jade Green Interior, Ram Air Hood, AC, Honeycombs and 8-track 1974 Formula 455 I Owned in 1975-1976. Now Own Its Twin From Same Dealership |
#149
I bid 1000.00 on an unrestored version on Sunday and was out bid. My original is missing the flaps. DDUB
71 SILVER AUTO JUDGE 70 RED AUTO III JUDGE 70 GOLD AUTO III JUDGE 70 SPECIAL ORDER SABLE BLACK 4SPEED III JUDGE 70 ATOLE BLUE AUTO GTO 69 C.RED 4SPEED III JUDGE 67 WHITE 4SPEED 400 VERT FIREBIRD 65 MAIZE 4SPEED TRIPOWER VERT GTO 65 TURQ. 4SPEED TRIPOWER VERT GTO WANTING A IV...... 20 other non-pontiacs which need to be thinned down so I can buy more PONTIACS |
#150
My '71 judge 455 HO ramair 70K miles had 4bolts with the coresponding washers, no studs. Very early car, E date on the block casting sept date on the car build...DDUB
#151
I've got one too that is missing the flaps. Been searching for a while to find originals out there, but afraid they may never be found. I ended up buying the repro kit that makes the repro air cleaners out there functional. They have the flaps and the air diaphrams and brackets. Not a bad repro, but is made for the repro air cleaner. The flaps are close, but don't connect to the diaphrams like the originals and are off about a quarter turn. I plan on using original donor diaphrams and brackets from other air cleaners, as they are the same and can be pulled from any two barrel carb air cleaner. One could cut out another attachment area from a donor flap and weld into the repro, but would be fairly difficult. I plan on cutting the attachment peg down to fit into the repro flap and should be pretty un noticeable once installed. This is going on a NOM car I am building so doesn't have to be exact. The fit of the hole plug on the flap is off just slightly too....but it's a great alternative to nothing!
Pat Brown |
#152
I saw that one too...it was restored. I just sold my NOS one a few weeks earlier for a little more than that one did. Surprised that one went that high. This stuff ain't getting any cheaper!
Pat Brown |
#153
This is one of the toughest 72 HO parts to find.
http://cgi.ebay.com/ebaymotors/1972-...QQcmdZViewItem A NEW set of wires are going to be even TOUGHER! Reserve is NOT met yet. (I figure he wants $500.00) It will be interesting to see where it ends.
#154
How about this 72 part, a 4 speed carb: buy it now is $3000:
http://cgi.ebay.com/ebaymotors/1972-...QQcmdZViewItem I am wondering why it has an upper vaccuum nipple on the top rear of the air horn. Anyone ever see this before? My 2071 July 71 dated carb does not have this. I bought my 7042273 carb from them 3 years ago for $1000. I must admit they did an awesome job refurbishing the carbs. The engine starts with a click of the key. Now if I could only get the body man to do his work..... Last edited by njsteve; 12-23-2007 at 09:55 AM. |
#155
I'd guess he wants more than 5 hunde. At least 1200 bucks I'd guess. Probably go for more but time of year may be factor.
Pat Brown |
#156
Perhaps the one on Ebay had the air horn changed out with a later/different one? (The rebuilders tend to swap out alot of parts) |
#157
Can anybody identify this part? Valley pan part #489824...DW
#158
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
#159
455 Block question: Were blocks with a 483677 casting# 455HO only, or were used in standard 455 applications as well?
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
#160
Someone with more block casting #'s experience may need to chime in here, though.
