Old 06-19-2011, 10:24 PM
notime's Avatar
notime notime is offline
Here are a few more.
ID:	247442   Click image for larger version
ID:	247443   Click image for larger version
ID:	247444   Click image for larger version
ID:	247445   Click image for larger version
WWW.SUPERCARCREATIONS.COM
  #142
Old 09-23-2011, 05:30 PM
Dave from England Dave from England is offline
Default 67 Firebird Restoration
Notime! glad to hear you finished the Firebird, from the photos looks like you did a great job.Havnt made much progress with mine through May June & July due to being extremly busy at work.Things have started to slow down now so Im back on the Fire bird with a vengance.Had hoped to have it finished for this summer but that didnt happen but Im extra determined to have it done for summer 2012.Need a little advice from yourself or anyone that can help me.Do I fit the fender extentions on the fenders before installing inner fenders & fenders or can it be left until afterwards.Im planing on doing this job next week so HELP please.Ill post some more photos towards the end of next week
Dave from England
  #143
Old 10-17-2011, 10:58 PM
notime's Avatar
Cant really remember now but i think we put fender ext on and fender well then mounted as an assembly. On the other hand we may have put fenderwell on loosely then fender then ext. Maybe someone will chime in to help. I know it was a pain in the @ss cause we chipped 1 door and had to repaint it.
  #144
Old 10-18-2011, 06:54 PM
Birdguy's Avatar
Birdguy Birdguy is offline
I found it easier to mount the wells to the fenders first and then mount the whole thing to the car/frame. It's a little more weight to handle, but they won't scratch each other up in the process.
I did tape thin cardboard to the edges to add a little more protection during the mating process. Good luck!
  #145
Old 10-19-2011, 04:42 PM
Can somebody help me please.
With both tie rods disconnected how can I tell when the steering is inthe central position.So that I am able to connect the tie rods & have a wheel alignment done.
Dave from England
  #146
Old 10-19-2011, 05:40 PM
JoePapa's Avatar
JoePapa JoePapa is offline
Dave from England
You could probably draw lines on the floor or use a straight edge across both fronts to get them to visually align with the rears. You want them both to be in alignment with the direction of the back. Then turn the steering wheel all the way to one side. Then count the number of turns to go to the other side. So turn it all the way left. If it takes 4 rotations to get to the right side then your "straight" up is 1/2 of that which would be two turns in this case. Make sense?
You should be able to connect your tie rods and trailer it to an alignment shop at this point.
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
  #147
Old 10-20-2011, 04:45 AM
Maybe I should explain in a little more detail.I have a friend who has all the alignment equipment but is a Mopar man and alignment it not done with shims on a Mopar.He brought the equipment to my shop to do the alignment there.Id had the steering components powder coated & I hadnt cleaned the theads out in the tie rod sleeves when I first coupled up the steering so it was nessesary to dissconnect the tie rods & clean out the threads.He set up the caster & camber but now needs to complete the job and set up the toe in but needs to be sure where the cental position is on the steering before reconnecting the tie rods,are there any markings to set this too to be sure the steering is in the central position.
Dave from England
  #148
Old 10-26-2011, 07:18 AM
Wheel alignment has now been completed but Im in need of a few bits so is there anyone who can help me out.Im in need of one tie rod sleeve clamp plus nut and bolt also I need two castle nuts for the tie rod ends.Ive looked through various catalogs including our hosts but no one seems to sell these bits and its imposible to buy them over here.As for the nuts for the tie rods weeve been using metric since the seventies and hardware stores and such like generally stock nothing else.So if someone has some to sell please contact me.
Dave from England
  #149
Old 10-28-2011, 10:41 AM
A few update photos since January plus more on photo album which will bring progress up to date. Is it possible that someone can help me out with my previous post regarding clamp and castle nuts?
ID:	261320   Click image for larger version
ID:	261322   Click image for larger version
ID:	261324   Click image for larger version
ID:	261325   Click image for larger version
