68 Firebird Are you running with the wind or breaking it? |
Well, not that far south.
That motor sure would look good in my 67 firebird! It's for sale!
Tubbed, 4link, 12pt cage! I think it would still need some updating to handle 2200HP though
Chris Collier 1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans "There is no such thing as too much horsepower" |
Are you selling it running or rolling? |
selling it either way, but it is not certified, it would need updating. it is an older cage and is probably mild steel.
It is not really a race car. it was going to be before I bought it but I put it back on the street. It has alot of good parts and was well done but 2200 HP is A LOT!!! I think most of the cage would need redone. you would have to see it. http://s248.photobucket.com/albums/g...colt/firebird/
Chris Collier 1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans "There is no such thing as too much horsepower" Last edited by moparcolt; 01-13-2012 at 09:20 PM. |
"Boosted Engines" are not time bombs (if done correctly). At one time Steve Morris was using a 572 Chebby Boosted engine for a series of Carburetor Shoot-out tests. Video is available elsewhere.
Many, many, dyno pulls above 2000 hp on THAT engine BEFORE it was sent to the customer. Same deal applies to Rodney and Travis engine. You do it right and it will live a long time. You do it wrong and you kick the rods out of the engine or pop the boosting device off the engine much more than you like. A proper "Build/ Tune-up" is a proper "Build/ Tune-up" on any piece of metal. Tom Vaught
) IE those Super Charged Fords at 1000HP cant have the same durability as a normally aspirated? Those Super Charged engines are seeing almost 200HP per cylinder where as the comparable NA is what about 50HP? There has to be a difference. Ed's engine is designed hopefully for 100HP more than those Fords. Travis's post said it all. He does 90 passes? We can live with that, as race guys watch engines usually way different than street guys. We cut filters open, etc. A street engine is much different. 20 Saturday nights out, hit it 4-5 times. That is time for a race car to rebuild! I know I am exaggerating, but tell me when Ed is out playing he isnt going to blister a few Chevys. This is a street engine with HUGE Turbos and huge heads. He has the best parts money can buy. Tony says 2200HP is a bunch and it severely reduces the life of any style engine. It has 2x the race style horsepower. I think he wants to make it understood that he isnt offering a 100,000 mile 10 year warranty between rebuilds. Steve Morris does this all the time, I think this might be Ed's best option. Otherwise, we could do a pull that demonstrates power with X boost, and map out the rest according to the design chart from Turbonetics. This engine has the best that money can buy with one of the best engine builders in the country. I also know we have one of the best quality Turbos in the business.
Lynn McCarty dba/McCarty Racing www.RamAirV.com [email protected] www.ChemicalManagementIndiana.com 317-260-3486 Last edited by NHRASuperStock455SD; 01-14-2012 at 06:21 PM. |
I think that Ed has a great chance for success with Tony building the engine and Steve Morris putting the final high boost dyno pulls on the engine.
I would bet that when the engine actually hits the street it will be no where near 2000 HP on a normal cruise night. So if the engine runs on the street 80% of the time you look at the durability curve for that STREET HP number, not the 2000+ HP number. Tom Vaught
The one thing to keep in mind is that aluminum rods don't mix well with extended street driving and high power applicatioins, since it's not really possible to predict at exactly what point you have to start questioning the rods' life cycle. Valvesprings are another area to keep an eye on in a street high power turbo application. You must have lots and lots of spring pressure to make big power with high boost pressures with a turbo engine, and extended street driving will certainly take its toll on valvesprings. So you've got to keep a close watch on seat pressures. However, new spring materials allow you to get away with a whole lot more these days than we could even 10 years ago....some of the new PSI, Manley, and PAC valvesprings will allow you to stay well over 300 psi seat pressure, even with street driving/repeated thermal cycles. |
You really have three choices: 1) Build a lower HP engine (say 700 hp) and drive it on the street a lot. 2) Build a Higher HP engine, drive it on the street sometimes and work on it constantly. 3) Build a very high HP engine, trailer it to events, keep accurate records of every pass, figure out how many passes you can run before you get nervous with the parts, and spend a lot of money along the way having fun in the pits working on the car when the very expensive parts failed well before you thought they would. I have known many Racers who sold their high HP toys, bought a Street Rod, went on cruises all over the United States, drank a lot of beer, told a lot of stories about the old days when they were racers, and had the time of their lives with their friends. Tom Vaught The Ratrod movement has never been stronger.
We’re running Callies Ultra Billet Rods and Manly Nextec springs, I haven’t seen the build/blueprint sheet so I can't tell you what the seat pressure was set to. Overall lift will be less than .750. Do you take boost pressure into consideration when determining spring seat pressure? |
Okay Ed where's this engine now?
Carburetor building & modification services Servicing the Pontiac community over 25 years |
The engine is still at BES, long block assembled. Tony wants to break it in NA. I'll have to have the EFI, PCV, turbo stuff done somewhere else.
Turbo headers/hot side are at the Indycartel, I'm being told the turbos might not fit where I wanted them. Not sure how this happened as it was mocked up before JoeyB started the headers. From what I can see, the collector merge is too long. |
Maybe you should bring it all home and and N/A dyno it at Lenny Caverly's dyno.
We can find the right people in our own area to draw on for the turbo aspect rather than have it all spread around the country and not be there to have control over your own project.
You've ALWAYS got to take boost into account. That and intake valve area. Bigger intake valves require more spring pressure, since the boost acting on the valve has more surface area to act upon, and therefore "takes away" a larger amount of seat pressure. Also, stainless valves will need more spring pressure than a titanium valve will because of the mass of the valve itself. Of course, rpm range comes into play, too. More rpm requires more spring pressure.
For a stainless valve with a diameter of around 2.20 inches in a turbocharged application seeing 20 psi boost pressure @ 7500 rpm, I would want absolutely no less than 325 lbs on the seat. Titanium valves buy you the ability to run less pressure (at that boost level), but don't mix well with extended street driving. More boost will require more spring. As Tom alluded to, there is no free lunch. In one area or another, we must all pay the piper. There is always compromise when putting together a high powered engine, especially one that's going to be run on the street. The question is can we tolerate negative aspects of that compromise. Turbocharged engines allow us to have enormous power levels in street driven applications with less negative compromises. Still, there is no free lunch. |
Tony vacuum fit all valves with specials seats. There are a few ways to gain RPM like a head design w/relatively short valves/pushrods with 11/32 stems.(lighter valve/better seal/proper seat angles = less valve bounce = less seat pressure.) Quote:
Dyno will tell our street RAV we were so surprized making power to 6700RPM!!! Our RAV design parameters paid off! With race springs we project over 800HP@7600.(Remember no high dollar tricks like Ed's engine) Yes..so when we hear that the engine is to be occaisionally street driven we decide how to fit the application.
Lynn McCarty dba/McCarty Racing www.RamAirV.com [email protected] www.ChemicalManagementIndiana.com 317-260-3486 |
I got a guy out here that builds a killer rear end housing - -mine has been fine -- but when I changed to a th400 from a p/g It all went to hell - untill we found out what was causing it -- I just checked the bearings after last year and they look new -now once I get the paint fixed we will be good to go -
Well... The old cage wasn't going to make the 25.3 cut, so it was removed.
