Old 04-05-2016, 08:17 AM
krisr's Avatar
krisr krisr is offline
Wow.... That's epic news! Next bonus methinks i'll be giving you a call about those cam sensors.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 04-05-2016, 08:24 AM
LPI's Avatar
LPI LPI is offline
Thanks Kris, email or call, email is best
[email protected]
(414) 5302704
Love Castle...he's my TV hero...LOL similar to the author Harold Robbins I think.
Holy cow Tom that's a dirt road...
www.luhnperformance.com
Old 04-05-2016, 08:52 AM
TransAm400 TransAm400 is offline
Nice. Will the coil bracket work with IGN 1a coils? I'm in on the cam sync for sure. Sending an email on the other stuff.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 04-05-2016, 10:21 AM
LPI's Avatar
LPI LPI is offline
Default LS smart coils
Yes, the current design is setup for the "LS1" smart coils. We have the ability to change the bolt pattern to work with other coils as well.
https://www.diyautotune.com/product/ign-1a-race-coil/
The cam syncs are in stock and ready to ship.
Old 05-08-2018, 06:57 PM
Marv Marv is offline
I just stumbled across this section and the EFI topics in here. I'd definitely like to lend my voice to those calling for a Boost/EFI section - particularly if we can get EFI in the section name or header!
I have a rebuilt E-headed 1964 389 that I'm putting full standalone EFI onto with a custom dual quad intake set-up. I was going to put a thread up in Street detailing the specs and mods done but I'll put it in here as it's better than the crap-shoot that Street often is.
Old 10-22-2018, 11:41 PM
avman avman is offline
Here are 2 different 3x2 fuel injection system options.
If Dick B. can't get our Rochester Tripower to do the built 421 justice, the next step is 3x2 throttle body injection.
Naturally, my wife (it's her car) wants one that "looks like a Tri-Power" so that means $8,000 by the time all of the supporting parts are added to a $6,000 system. The F&B is the one that I only have a picture of, the link is to the more costly system, but looks like 3x2 bbl Rochesters.
http://autotrendefi.com/efi-2g.html
F&B is first 3 pics and is direct port injection.
Auto trend is LAST pic and look like Rochesters
ID:	495804   Click image for larger version
ID:	495805   Click image for larger version
ID:	495806   Click image for larger version
Old 12-31-2018, 07:22 PM
frbformula's Avatar
frbformula frbformula is offline
Time to get into the efi game. I'm installing holley hp efi on my 73 bird. 83lb injectors running on e85. Should be a fun project. Wish we had an EFI section to post question and projects under.
ID:	501449   Click image for larger version
Old 01-01-2019, 09:37 AM
Tom Vaught's Avatar
Boost Engineer
On the other Boost Board that I moderate we have a ADVANCED TECH section.
Maybe we just need a Name Change on the PY Board for THIS Forum to ADVANCED TECH.
(for BOOSTED ENGINES and EFI ENGINES).
What do you think Bart? (and members)?
Tom V.
Old 01-01-2019, 12:07 PM
GTOGEORGE's Avatar
Now remember if you want to race in the Nolstolga races you can’t run electronic fuel injection.
GTO George
Old 01-01-2019, 03:54 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
We need to have a fuel injection section/Advance...whatever.
Old 02-01-2019, 10:32 PM
pokey1 pokey1 is offline
Yes I agree...
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and
9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches..
Old 01-01-2019, 11:29 PM
4bbl EFI is easy now. 3x2 EFI is a little less available and certainly more expensive, but in the case of my 440 and her 421, they both have 3x2 induction and that is how it always will be as long as we have them.
After investing $1k parts and labor with Promax in my 3 Holley carbs, with bad results (so far-I have to make the time to work on them, they are "as shipped" with some tuning on my part) I have to work with the Holleys for now, and give Dick B a shot at the Rochesters.
Not taking anything away from my expectations of what Dick B can do, and knowing that guys have had great results with Promax modded Holley carbs, that is what I hope for, but if EFI is the ultimate route for either or both cars, I hope that Holley's patent on a 3x2 Sniper EFI system will be a product available to buy by the time my decision has to be made, and I hope to hear of an additional alternative to the $6k-$8k all in system for the Pontiac.
Old 01-31-2019, 04:13 PM
LPI's Avatar
LPI LPI is offline
Default new 4150 style port EFI intake assembly
We have been working on a dedicated multi-port single plane EFI intake manifold in which we have a finished product.
It can be equipped with -6 AN male or -8 AN male end rail fittings. The standard 1/2" ID fuel rail uses a -6 AN ORB thread.
We have an optional upgrade for the high flow 11/16" ID fuel rails too.
This intake is setup with a set of 48 lb/hr Holley EV1 style injectors and the Holley 4150 throttle body with a bright silver coating. Both work with the Holley HP or Dominator ECU systems.
This intake is also equipped with our bright dip anodized billet O-ringed swivel water neck.
Name:	LPI_Holley MPFI intake T.jpg
ID:	504394   Click image for larger version
Name:	LPI_Holley MPFI intake S.jpg
Old 01-31-2019, 06:11 PM
HWYSTR455's Avatar
What intake is that based off of? And do you have a target range for the price?
Old 01-31-2019, 06:13 PM
krisr's Avatar
On the 2/4 runner it looks like it's the procomp manifold (copy of the tomahawk/PP). I've actually got one of those manifolds here, visually it looks good. It also ran pretty strong too on my motor.
Old 01-31-2019, 07:11 PM
Tom Vaught's Avatar
Boost Engineer
VERY NICE WORK FROM LUHN PERFORMANCE, (AS USUAL).
GOOD JOB MARK.
Tom V.
Old 01-31-2019, 10:59 PM
LPI's Avatar
LPI LPI is offline
It is the new Pro-comp brand "shootout" intake or what was originally the PP "Hurricane" intake.
It is a low profile single plane intake which in our opinion and experience is a very good intake for a N/A engine and it is an excellent intake for a boosted engine.
The intake with the "Johnny 5" epoxy coating, with the -6 AN fuel rails, -6 AN end fittings and rail supports and the anodized billet water neck would be $895.00
We also offer the intake in a multitude of colors with a baked Cerakote finish too.
The picture shows it with the Holley HP 4150 throttle body and a set of 48 LB./HR. EV-1 style injectors, those two items would be $820.00.
We have package deals on complete intake and EFI systems as well.
The next dedicated EFI intake will be a low profile front or rear mount throttle body style based on the "LS" Hi-Ram top. We also have provisions for a dedicated air to water inter cooler that will sandwich between the top and the mid plenum base. Very similar to what is on "The Raven" the 69 twin turbo RA V Firebird. This will be for more street/strip pro-touring vehicles.
Old 02-01-2019, 10:43 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Raven Intake Pic.
Give Mark a call, he can set you up
Pardon the large image.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 06-17-2019, 04:44 PM
Gator67's Avatar
Gator67 Gator67 is offline
On my shelf sets an EZ EFI 2.0 TB system that I've been planning to use on a 535, and because it all needs to fit under a Formula hood, been considering a shootout intake. I recognize I'd be leaving some potential on the table with that intake (relative to a Victor or even a Northwind), and so wondering if I would be giving up less if I went multiport, using one of your modified shootouts--either converting the Fast TB system to MP, or starting over with something different?
Old 06-18-2019, 08:18 AM
HWYSTR455's Avatar
A Holley HP ECU would work, or one of the others, Big Stuff, AEM, HalTech, MoTec, or the like. You can have injector bungs and rail stands installed on almost any intake. And remember, aftermarket throttle bodies (air only) are considerably lower than a carb, some up to 3" shorter, so you can actually go to a taller intake design. Or use an intake elbow, and an LS style throttle body.
FAST does have an EZ-EFI 2.0 multi-point setup, and think you can even send your TBi ECU in to be flashed. But, FAST is kind of expensive for the general off the shelf type, and you would be better to sell your existing setup as a complete, uninstalled system, and buy another system.
EDIT: On the 'bird, I'm doing a 535, and plan on using a Northwind, and a sniper for now. It will fit under the T/A type hood, even with the drop body mounts I have. Eventually I will go to a MPFI.
