What process did you use to polish the glass? They look fantastic.
What was involved in trimming the headliner? Was it as simple as cutting and tucking into a trim piece?
I get that Hurst cut a ton of these when they were new, but I'd have probably left the job to my body guy - you are a brave and talented guy!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
Save your money, just use the roof cuts instead of buying t-top glass!
I installed the headliner. Before the weatherstripping was installed, I marked the opening with a marker, then with an ultra sharp knife, I cut out the headliner. On a first design Hurst Hatch, there is a huge lip on the interior side of the weatherstripping that covers the opening. The headliner is attached to the T Top frames using several small metal spring clips. I have done paint and body jobs for years. I just kept pretending this car was a Sunbird while I took the saws to it. Made it a lot easier.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
That's great!
Changes it from cool to cooler!
Mike/Illinois |
Yeah the drip from the roof . LOL
Butch |
Is that your classic 67-72 Chevy pickup, also?
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
Nice job...........
Thank you all.
Trashcan-That is my 1972 Cheyenne Super with factory A/C, 402, TH400, tilt, tach, AM/FM. It was top of the line for its time.
I have a 67 C10 LWB, getting a 406, disc brakes, looks aweful, but I like it and I have a 68 C10 LWB golden anniv. pickup. 396/TH400?PB/PS/AC in need of complete work over. I'm making progress...
A better pic of the truck:
My 1970 CST Blazer:
One of my local Pontiac buddies has I think a '72 truck maybe a Longhorn edition top of the line with an extra long factory bed. BBC powered.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
It was a nice spring day (finally!) I spent the entire day polishing the glass, sanding the metal surround, priming, sanding, repeating several times, then painting with SEM trim paint. After it cured, the top was treated to new Metro weatherstrip, and Phoenix stripe.
RH is next..
Thank you!
https://www.eastwood.com/glass-polis...ches-5658.html
or https://www.eastwood.com/pro-glass-polishing-kit.html I used the Eastwood glass polishing kit. The first kit is for deeper scratches that can catch your fingernail. The other kit is for hard water damage, or light scratches. They restore the brillance of the glass. Caution must be used to not polish too much to cause an optical distortion, or crack the glass due to heat buildup. Also, the slurry is very messy. That crap gets slung everywhere!
I have owned this car for two years. It has never gotten wet since that time.
I am well aware of the Hurst Hatches design flaws-mostly centered around leakage. I took every precaution during assembly, and everything that is available new has been replaced. If this was to be treated as a daily driver, I would have never even considered this modification.
You use a drill limited to less than 2000 RPM. Don't stay in one spot too long. The Hursts are laminated much like a windshield.
You did a fantastic job executing this modification. My hat is off to you.
I hope you have a great spring, summer and fall enjoying your handywork. |
