#141
Thanks for the extra images!
I’m wondering if this was a casting run that Pontiac specifically produced for a class racer (or racers) running a 1967 Firebird or GTO who needed a 9786133 block for class rules. It would have likely taken someone with an inside connection to get it accomplished. |
#142
Here’s another interesting SR block presently on eBay.
https://www.ebay.com/itm/124991349056 Pontiac created a service-replacement 1966 389 fitted assembly (part number 9784021) using a typical 1968-1969 9790071 400 block casting and combined it with cast 389 pistons (notice valve pockets) with complementing valve reliefs machined into the tops of the cylinders. It's NOS to boot! A 66 GTO guy could snap it up. He might have a hard time convincing a judge that this particular 9790071 block is a correct SR block for the application though! |
#143
This SR block is ground different than any I have seen with the top of the numbers left.
#144
I always say never say never. I remember when people used to say Pontiac never made a shift light tach, or an aluminum block, or RAV dual quad engine, GME 428 RAV block- or special gear ratios. Blah blah blah. All have been proven false. They made all of that. I’ve also seen a RAII block with no casting pad at all cast C118 do a search there was one posted on here as well
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
