Old 12-15-2018, 06:42 PM
shaker455's Avatar
shaker455 shaker455 is offline
Drove it!
Only get front brakes for tonight but enough to put in gear and tool around the yard.
Carburetor building & modification services
Servicing the Pontiac community over 25 years
  #142
Old 12-15-2018, 11:15 PM
lugnutx2 lugnutx2 is offline
Originally Posted by shaker455 View Post
I did run it again last night for very short times.
Not long enough for it to build any heat .
I think I hear the old noise I know too well with stock Pontiacs...Rod knock or pin.
Like I said it has not run on it's own long enough...I may have to replace the fuel pump...
Weird it was pumping well when I cleared the tank of the Beer it was brewing.
I put a filter before the pump before I started cranking it.
Carb runs fine on my truck so maybe new plugs & a pump.
Noise gone?
  #143
Old 12-16-2018, 12:24 AM
shaker455's Avatar
Yes,
Gone after running on it's own.
Runs smooth and quite after a 20 year sleep
I'm pretty certain I am this cars "last Chance"
  #144
Old 12-16-2018, 06:12 PM
stevep's Avatar
stevep stevep is offline
Awesome news!
  #145
Old 12-16-2018, 07:15 PM
shaker455's Avatar
Thanks Steve for all your help!
Car is now operable!
  #146
Old 12-16-2018, 08:07 PM
77 TRASHCAN's Avatar
Drove it!
LOL, is your yard large enough to get it into 3 gear???
Shut it off
Shut it off
  #147
Old 12-16-2018, 08:11 PM
shaker455's Avatar
Maybe!
I can just take it down my road....I live in the sticks!
  #148
Old 12-17-2018, 07:36 PM
stevep's Avatar
Default It went to a good home!
That's MINT!!!!
  #149
Old 12-30-2018, 09:28 AM
shaker455's Avatar
Brakes are now fully operable.
Got the headlight doors to open but going to have to do something with the vacuum actuator in the middle of front bumper.
Cleaned contacts and new rear tail light bulbs.
Distributor is still frozen in block, I'm thinking I can tackle it better once I take the intake off so I can run a better carb.
I think this car will get an early NH plate
ID:	501328   Click image for larger version
  #150
Old 12-30-2018, 07:00 PM
stevep's Avatar
Spray GM heat riser lube around the base of the distributor.
I may have a good actuator, but I'm not sure.
  #151
Old 12-30-2018, 07:34 PM
shaker455's Avatar
where do I get the GM product now a days?
  #152
Old 12-30-2018, 07:54 PM
Stuart's Avatar
Stuart Stuart is offline
I'd assume the parts counter at any GM dealership should be able to provide it, but you can also order it from Summit Racing or Amazon.
https://www.amazon.com/Genuine-GM-88.../dp/B00BK7MLKE
https://www.summitracing.com/parts/ado-10-4020
  #153
Old 12-30-2018, 08:16 PM
shaker455's Avatar
Thanks!
I haven't bought that stuff in Decades!
15" tires are so limited now I may get aftermarket wheels & 17's
  #154
Old 12-30-2018, 10:07 PM
Thanks!
No, no, no...you live in the Shire, not in the Hood!
Shut it off
Shut it off
  #155
Old 01-08-2019, 09:19 PM
shaker455's Avatar
Picked up a set of 1967 New Hampshire plates to register the car with.
  #156
Old 01-22-2019, 12:03 AM
What's the latest plan of attack on the GP?
Shut it off
Shut it off
  #157
Old 01-22-2019, 06:48 PM
shaker455's Avatar
Hey Jeff,
Getting some 7" Rally II's from a local PY member.
In process of modifying a less popular P4B
At the time of intake swap pulling the dist.
Start driving daily in spring and start preserving & fixing the body one panel at a time while in use.
Starting with the roof.
I may also go "gangsta" and get some other wheels like this:
  #158
Old 01-22-2019, 06:57 PM
Smart thinking. My TA is drivable doesn't look nice. Hope to make noticeable
Progress on it this year!! Same as your plan!
Having vehicles completely ripped apart can snowball into years...my advice to anyone is to do little things here and there, keep it drivable!
Shut it off
Shut it off
  #159
Old 01-22-2019, 07:37 PM
shaker455's Avatar
Yes I am also building it a Qjet.
Also I have a 65' Corvair Anti-cool car I'll be also driving.
I warmed up a 140 HP motor with better heads & custom cam...also going to modify IDF Webers for my Corvair buddy in Texas
Lets see your T/A seeing you had since new!
  #160
Old 01-22-2019, 11:27 PM
Very ugly right now...looking for a pic...
Shut it off
Shut it off
