Old 10-23-2019, 04:25 PM
77 Canamman's Avatar
Originally Posted by abefromen View Post
Do you still need this? I have an old harness and they may be on it.
No. I found one marked as for a 1969 Camaro/Firebird, and after moving a couple of the wires, it worked well.. However, it was $50...
It's in! I repaired the harness, and it went in without any fanfare. The front speaker is shot, so I ordered a new one. I wired a temp speaker in the meantime to properly load the radio.
Sent from my XT1650 using Tapatalk
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #142
Old 10-23-2019, 09:17 PM
1965gp 1965gp is offline
What a great find/progress on this car!
The Following User Says Thank You to 1965gp For This Useful Post:
  #143
Old 10-30-2019, 09:17 PM
The new dash speaker is in, as is a NOS lighter housing. The radio and lighter now work as they should.
  #144
Old 10-31-2019, 05:17 PM
Today I tackled the nasty steering wheel hub. The old wrinkle paint came off easily with a 180 grit sanding block. I used VHT wrinkle paint, which worked, but I have used better. Anyway, I baked it in the oven for an hour each coat at 200 degrees F. Total of 4 coats. It turned out good.
  #145
Old 11-11-2019, 05:50 PM
The original master cylinder finally went bad. Since the original one is very crusty in and out, I opted to locate a reman with the correct bleeders and main body. Through Rock Auto, I was able to purchase the last Cardone 10-1521BLV they had. I bench bled it, and it went on well. It had a spongy pedal, so the bleeders on the master were used to purge all of the air with the use of a Mity-Vac. Now, the pedal is excellent. The booster and proportioning valve bracket will be replaced when I replace the driver's side fender.
The original master was stamped "CS" with a 2356 date code. I'm assuming that is the 356th day of 1972.
  #146
Old 11-15-2019, 07:37 PM
Well I've secured these nOS GM beauties for the Formula. I didn't have to sell my extra organs to afford them either. Our board sponsor's founder is truly the best.
  #147
Old 03-05-2020, 09:35 AM
Car is up for sale... will be headed to Ebay and other venues soon
http://forums.maxperformanceinc.com/...29#post6117029
  #148
Old 03-07-2020, 09:37 AM
Brewster's Avatar
Brewster Brewster is offline
Nice project car and cool options. Love the NO A/C and column shift. Good luck to the new owner!
  #149
Old 03-10-2020, 06:56 AM
SD455DJ SD455DJ is offline
X2! I really like this car...I just wish I had more money and room!
Dennis
  #150
Old 03-15-2020, 11:52 AM
https://www.ebay.com/itm/1973-Pontia...5/184211910447
  #151
Old 03-20-2020, 08:27 PM
Held for Ransom's Avatar
I think someone got a good car for a fair price. Wasn't around to bid.
So long, farewell.
  #152
Old 03-20-2020, 08:34 PM
It sold for $7600 ?
  #153
Old 03-20-2020, 09:37 PM
When I first looked at it, I thought he had a BIN for $11,999 and someone bought it for that. But he ended it early, so I thought someone purchased it just south of that. I thought the $12K was a good buy. Shipping is what killed it for me.
So long, farewell.
