Old 06-08-2019, 01:44 PM
Dragncar Dragncar is offline
Originally Posted by slowbird View Post
My bottom end is no near Pro Stock and neither was Mike's at that time.
I have never had a goal of running 7s, my car will never run that, ever. And my junk will never make 1200hp. Those aren't my goals.
What did your HP engine make ? Well north of 1100HP I think. Was,t it 1150ish horsepower?
So you are spending close to 10K to "not" gain 50 HP ? Jessels and Barton are not cheap.
  #142
Old 06-08-2019, 01:57 PM
My normal race schedule is what amounts to 26-28 races a year. 2 classes at 12-14 races adds up.
Only reason I am not running now is my 461 just got back from machine shop. Putting it on engine stand today. Took crank to get balanced yesterday.
I could race the old 455 is a retired it from racing last year. I would be crushed if I raced it one more time and blew it up after such a long run. That pic I took with all the trophies was with one engine. But its last run was its best ever.
At the most this year I might take it out for a few passes to make sure the trans and rear and brakes are good to go after freshening. Do not want new engine on top of all that to worry about all at once.
  #143
Old 06-08-2019, 02:32 PM
slowbird's Avatar
slowbird slowbird is offline
Man you have no clue. Don't let facts get in your way. I've posted my dyno sheets here, hell your buddy Gach even posted one lol. Search around if you care for facts.
  #144
Old 06-08-2019, 03:15 PM
J.C.you's Avatar
J.C.you J.C.you is offline
....so, has Youman made any more hits?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #145
Old 06-08-2019, 03:41 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Heard he was switching to E-heads to turn up the wick some 💪😎😅
Go fast, see Elvis!
  #146
Old 06-08-2019, 04:35 PM
J.C.you's Avatar
Heard he was switching to E-heads to turn up the wick some ������
Heard the eheader guys were already running 100lbs and had 50 head bolts per side.
Was said any less bolts and the sheite went off like 8 potato guns
Also heard Youman was running 10-11 lbs and has a Gto george tune on it.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
  #147
Old 06-08-2019, 06:00 PM
Just tell us your highest HP for that engine. I sure do not want to start that dyno sheet mess.
  #148
Old 06-08-2019, 06:05 PM
Stan Weiss's Avatar
Brian,
I do not know what was your highest, I have a sheet that shows 1048 HP @ 8000 RPM.
Stan
Pontiac Pump Gas List
  #149
Old 06-08-2019, 07:22 PM
slowbird's Avatar
How is your 900hp pg build coming along? You should make huge power with all the great parts you have.
  #150
Old 06-08-2019, 09:05 PM
PAUL K's Avatar
They are in uncharted territory... you do whatever it takes to gitr done! It's not easy being at the top. ��
EHTTFMF!!!
Go fast, see Elvis!
  #151
Old 06-08-2019, 09:07 PM
PAUL K's Avatar
EHTTFMF!!!
Go fast, see Elvis!
  #152
Old 06-08-2019, 09:16 PM
Answering a question with a question. Your MO stays the same.
Its not like I do not want to see another 1200HP NA Pontiac, I do.
My junk ? Doing the pump gas 461 at the moment. Need intake finished, cam and oil pan. Have the rest for the 540.
  #153
Old 06-08-2019, 10:25 PM
slowbird's Avatar
No point in answering your questions?
What do uou think your 461 will make 800-850hp?
  #154
Old 06-09-2019, 01:25 AM
No point uh ? What I am trying to figure out is what you made with your HP engine on race fuel. And the difference in expected power with new build.
Its not like you are trying and putting serious effort into your program. I count a Victor cut in half, tons of pics on that. A custom Tiger made to fit HPs. A BOP and a Gustram tunnel ram. You are chasing something or lighting money on fire.
You posted that you have the 2500$ billet pistons and the 1500$ rings to go with them. Had a lightweight billet Scat crank and now a USA made 8 counterweight deal. And top shelf rods. I don't remember steel or aluminum. And had a 50mm cam and think you now have 55mm. I bet you have to end up with close to 20K in your new heads and custom intake.
Its going to scream whatever you end up with. Looking forward to hearing the big number it puts up.
The 461 will be a 650-670HP pump gas deal.
  #155
Old 06-09-2019, 06:56 AM
slowbird's Avatar
Never had a light weight Scat crank, never had a 50mm, all the intakes i bought used (but since you counting intakes ive also owned a T1, T2, RPM, SD, and Performer intake), rings pack wasn't that expensive.
How is that you think you know so much about what im doing but have no clue how much hp it made?
Others have have made 800+ with stock block and hp heads, why not you?
  #156
Old 06-09-2019, 10:31 PM
OK, so which brand lightweight crank was it, Crower ?? Had some bearing issues and thought it contributed to them.
I have quite a collection of intakes myself. Need to sell some.
I have a clue how much it made. You told me in a post years ago. I was impressed. Higher than I thought.
800HP? 800HP NA stock blocks eventually crack up the middle. Whitmores last engine will live a long happy life. When the 540 gets done 461 will end up in the 79 street TA with the HOs on it.
Heck, when I am done really racing I think I will sell the E head top end, put the High Ports on the 540. Make a custom grind 55mm solid flat tappet cam, run some Mopar .904 solids and drive it out to the track when I am a geezer and run high 10 and drive home.
Not shy about my plans. Whats yours with this new engine ? It will make big power not even trying.
  #157
Old 06-09-2019, 11:28 PM
slowbird's Avatar
No crank that i have sold was a "lightened" crank, they have all been heavy turds.
  #158
Old 06-10-2019, 09:50 AM
chiefbigb chiefbigb is offline
And the train runs off the cliff once again
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
  #159
Old 06-10-2019, 05:54 PM
GTOGEORGE's Avatar
Rumor has it, it went first pass 4.43 a partial 1/8 mile pass!
W6HTTF!
GTO George’s
  #160
Old 06-10-2019, 06:20 PM
Stan Weiss's Avatar
W6HTTF!
GTO George’s
So what was his 60 foot time and 1/8 MPH?
Stan
